A question on Airbus landings
Old July 10th 06, 05:54 AM posted to rec.aviation.piloting
Default A question on Airbus landings
I've heard that in FBW Airbuses, if your sink rate on finals is low for
whatever reason, the computers might not consider it to be a landing at
all, and might actually prevent reverser deployment and even inhibit
brake application on the landing roll?
Thanks in advance,
Ramapriya
Old July 10th 06, 01:57 PM posted to rec.aviation.piloting
Thomas Borchert
And I hope this isn't what happened yesterday at Irkutsk.
Repeat after me: Not all Airbusses are FBW. Not all Airbusses are
FBW...
Besides that, no, your scenario is not a valid one.
Thomas Borchert (EDDH)
Old July 10th 06, 09:32 PM posted to rec.aviation.piloting
John Clear
In article om,
I assume that I didn't convey myself adequately because I wasn't asking
about what the aircraft use in detecting terrain.
My question was if in a low sink rate situation - possibly a flatter
profile during finals (a no-flaps situation) or you came in slower and
touched down gently at the initial section of the touchdown roll, does
FBW technology prevent reverser deployment until too late? When I first
read about it, it struck me as the exact opposite of a safety feature
(if at all it's that) because these are the situations when you'd need
reversers the most. I also similary wondered about brakes too, and
whether onboard computers can (or do) inhibit application in some
circumstances.
I think you are referring to an A320 accident that happened awhile back.
http://www.savive.com.au/casestudy/warsawa320.html and
http://sunnyday.mit.edu/accidents/warsaw-report.html have the details.
Basically, it landed fast, and with a tailwind, didn't get weight
on the wheels, and the runway was wet so the wheels didn't spin
up, but hydroplaned instead. Weight on wheels is needed for thrust
reversers to be enabled, and wheel spin is needed for brakes.
This accident, and many many similar ones, are pilot training issues
more then aircraft systems issues.
John
John Clear - http://www.clear-prop.org/
Old July 10th 06, 01:46 PM posted to rec.aviation.piloting
Thomas Borchert
You may be referring to the accident in Warsaw some years back. It was
the gear switches that didn't report landing, IIRC. It makes absolutely
no sense to connect landing detection to sink rate on final.
As for the incident in Russia yesterday, the A310 is not FBW.
Old July 11th 06, 02:15 PM posted to rec.aviation.piloting
Yes Thomas, I was.
It was the gear switches that didn't report landing, IIRC. It makes absolutely
Pardon my ignorance but aren't the two connected, in the sense that
you'd touch down lightly if your sink rate is lower?
Ramapriya
Old July 11th 06, 05:09 PM posted to rec.aviation.piloting
Thomas Borchert
Yes, but if you are down, you are down, i.e. the gear is compressed by
the weight of the plane. The problem in Warsaw was that the wheels
didn't start spinning because of aqua planing.
And just to make sure the point gets across: The Airbus 300 and 310
(the early models) are not FBW. The 320 and its derivatives, as well as
the 330 and 340 (and 380) are. As is the Boeing 777.
Old July 11th 06, 07:28 PM posted to rec.aviation.piloting
Big John
The switch on a main gear strut is called the "Squat Switch". It's
position is used for lots of things on airplane. Pilot can by pass the
"squat" switch if needed in cockpit, ie bypass the "Squat" switch to
pull the gear up on the ground.
Haven't seen the wiring diagram but would guess that reverse thrust
would not be available until you had activation of "Squat" switch, ie
no reverse thrust until you are on the ground.
All the current birds have ASB. Failure in that system (very rare)
prevents any braking.
Lots of what ifs.
Big John
On Mon, 10 Jul 2006 13:46:20 +0200, Thomas Borchert
Old July 11th 06, 11:39 PM posted to rec.aviation.piloting
The Visitor
It doesn't sense wheel spin up?
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 06:15 AM
182RG question Paul Anton Owning 11 May 16th 05 10:45 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Information on A310 that lost it's rudder enroute to Canada from Cuba Corky Scott Piloting 3 March 27th 05 04:49 PM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
