GPS approach safety case
Old June 8th 04, 06:39 PM
Bob Gardner
If you have contacts at FAA HQ, check out Mitchell Narins, AND-702, whose
2002 paper "FAA Evaluation of Loran-C I-CNS Conference Briefing" laid a
foundation for many of the arguments in favor of continued funding. He is
not, to my knowledge, in the pocket of the loran manufacturers.
Bob Gardner
wrote in message ...
Bob Gardner wrote:
OK, then, go to www.avionicsmagazine.com, June 2004 issue, and see the
future. My point is that within a few years, enhanced loran will be
available when GPS is not.
That must be some joke fostered by the LORAN equipment manufacturers.
The high-end stuff that goes oceanic all have triple IRS units, which with
position mix will do far better than any LF "enhanced ADF."
  #32
Old June 9th 04, 02:22 PM
Jon Parmet
"Bob Gardner" wrote in message ...
I've seen him give several talks at ION and attended the ICNS
conference. Mitch is good people with a sound technical understanding
and has no problem dancing
Bob Gardner
Regards,
Jon
  #33
Old June 9th 04, 02:42 PM
Bob Gardner wrote:
I usually appreciate your input to these newsgroups because you obviously
have an insider's perspective. In this case, however, you have not done your
homework. Enhanced GPS meets the RNP 0.3 standard, which will make it good
for nonprecision approaches when the funding is solid and the whole system
is upgraded.
What's enhanced GPS in this context? GPS today meets RNP 0.3.
If you meant enhanced LORAN, no one I have dealt with is even talking about such
a requirement.
And, the airlines aren't about to spend any money on anything like that. Like I
said, "triple mixed" IRS does quite nicely in a pinch and they are already part
of the equation.
The GPS goes out and you use triple mix IRS postion until you get into a DME
environment, then DME/DME does the update until you get onto the ILS.
  #34
Old June 9th 04, 07:08 PM
Barry
such a requirement.
Like I said, "triple mixed" IRS does quite nicely in a pinch and they
are already part of the equation.
In June 2002 I attended a presentation on LORAN given by Mitch Narins. Here
are the key points I noted then:
- The goal would be to provide a backup to GPS, capable of RNP 0.3
non-precision approach.
- LORAN availability, accuracy, integrity, and continuity were all
insufficient, and were all considered medium technical risks. Integrity was
considered the biggest challenge.
- It was estimated that 5 to 7 years of development would be needed before
LORAN could serve as a backup to GPS.
- No market was seen for standalone LORAN receivers - the enhanced LORAN would
be used only as an integrated component in multimode receivers.
I don't know what progress, if any, has been made in the past two years.
Barry
  #35
Old June 9th 04, 11:07 PM
I have a goal to win the Lottery Jackpot, too. ;-)
I had an Azure portable Loran that I got in 1988, as I recall. Then, they filled
in the mid-continent gap a couple of years later. Nonetheless, here in Southern
California, where the goemetry goes tango-alpha, I often saw 1/2 nautical mile
errors.
Keep in mind that RNP is a total system commitment, from pilot, to avionics, to
accuracy and integrety of the sensor. The powers-that-be decreed that GPS could
deliver RNP 0.3 with RAIM and approach display scaling of 0.3 n.m. Thus, we got
GPS RNP 0.3 by fiat, rather than by the ICAO definition of RNP. The snake oil
salesmen have been working hard to get to .20 and even .11, but so far
(fortunately) the feds won't buy into it, except for local differential. Boeing
has a great demo system at Moses Lake that works at one airport with one very
advanced 737-900.
Fours years have passed and there is no RNP .20 or .11 except with Boeing's demo
at one airport with one very expensive airplane.
And, this is working with the best stuff, not with "computed ADF." ;-)
  #36
Old June 10th 04, 01:33 AM
Barry
Four years have passed and there is no RNP .20 or .11 except with Boeing's
demo at one airport with one very expensive airplane.
Doesn't Alaska Airlines have a special procedure into Juneau with RNP less
than 0.3?
  #37
Old June 10th 04, 02:04 PM
than 0.3?
Yes, but that is bogus RNP, in that they use terrain mapping radar and some
other enhancements to keep off the canyon walls.
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
