X-plane vs FS2004
Old April 9th 06, 01:27 AM posted to rec.aviation.simulators
Default X-plane vs FS2004
I just came across a rave review of X-plane by Richard Collins, so was
curious how well it compares to FS2004 in terms of realism, anybody who
has used both? I have used FS2004 and its a pretty decent product and
fun to play with, but was wondering if X-plane is better.
thanks
Old April 9th 06, 07:16 AM posted to rec.aviation.simulators
Anyone who prefers X-plane will of course tell you that X-plane is better.
So I predict that what you're going to get in response to your question is a
bunch of X-plane fanatics tell you just that.
That said, there are certainly areas of the MSFS flight modeling that seem
suspect to me, as an actual pilot. I haven't used X-plane so I can't
comment on whether it does those things better, but it's certainly possible.
I was under the impression that one could try out X-plane for free. So it
seems to me that rather than asking a loaded question here, you'd be much
better off downloading a trial copy and seeing for yourself whether it's
better.
Pete
Old April 9th 06, 07:32 PM posted to rec.aviation.simulators
When I last used X Plane (maybe v6 or 7) it was noted for having very good
flight dynamics but the scenery wasn't as good but that may have changed by
now. I believe you can get a demo. It's really up to what you like. I'd
probably run both if I had the time!
a bunch of X-plane fanatics tell you just that.
possible.
better.
Pete
Brett I. Holcomb
Remove R777 to email
Old April 11th 06, 08:52 PM posted to rec.aviation.simulators
I was actually curious to hear about the differences between X-Plane 8
& previous versions. In nearly 20 years of simming, I've never seen
more than screenshots of any X-plane version. What do I miss if I opt
for 7 or 6?
Old April 15th 06, 04:42 PM posted to rec.aviation.simulators
In article .com,
| for 7 or 6?
X-Plane v8 is a big step up from v7 in terrain modeling. However, that
does come at the expense of requiring much more disk space and a bit
more CPU/GPU horsepower.
-- Tim Olson
Old April 21st 06, 07:02 PM posted to rec.aviation.simulators
Tim Olson wrote:
In article .com,
| for 7 or 6?
For a 3ghz CPU, but with less than a gig of memory, and no AGP
graphics, will v8 run well? If not, would a PCI card and/or more ram
make it run worthy?
Old April 9th 06, 07:22 AM posted to rec.aviation.simulators
FS2004 has better graphics and Air Traffic Control, while X-plane has more
accurate flight dynamics.
I use FS2004 for instrument practice and VFR cross-country touring. The
flight dynamics are smooth and pleasing for the most part; sometimes
unrealistically smooth. It doesn't work well for stalls, which also rules
out spins and most aerobatics.
I use X-plane for helicopters, especially since FS2004's formulas don't
allow autorotation at all.
Then I got Silent Wings for soaring and haven't used the other two in
months. I must be crazy :-0
Thanks,
Marc
thanks
Old April 13th 06, 02:22 AM posted to rec.aviation.simulators
FS2004 can be used to practice autorotations but you have to do
something a little unrealistic and after killing the throttle bring it
back to between 10 and 20 percent. Yes it's a nasty kludge but people
do use this method. Here's a good article on doing autorotations in
FS2004.
http://www.hovercontrol.com/artman/p...ticle_18.shtml
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
