Flying IFR with Garmins
Old June 17th 04, 02:33 AM
Newps
"Andrew Sarangan" wrote in message
Why not use a VOR receiver for airway navigation? Using a GPS for airway
navigation kind of seems backwards.
Have you tried it? Putting a flightplan in the GPS and then flying the line
on the moving map eliminates having to worry about crosswind correction.
None of this flying a heading for awhile and seeing how that works. Then
adjusting that heading constantly for constantly changing conditions. With
a GPS you don't need a DG to fly an airway.
Old June 17th 04, 03:37 AM
Roy Smith
There are lots of reasons to use GPS to fly airways instead of VORs.
1) GPS is more accurate.
2) GPS's cross-track error display on the CDI is easier to interpret
than a VOR's angular displacement, especially near the navaid.
3) GPS gives you distance from every fix, not just navaids with
co-located DME. And it's horizontal distance, not slant distance.
4) With GPS, you don't have to worry about navaid service volumes and
poor reception at low altitudes.
Old June 17th 04, 04:19 AM
Andrew Sarangan
Roy Smith wrote in
airway navigation kind of seems backwards.
All of the above are good reasons, but what I meant was, why would you
want to fly airways with a GPS when you can go direct?
Old June 17th 04, 04:41 AM
Michael 182
. 158...
Because lots of times ATC doesn't give me direct, especially in the East.
  #29
Old June 17th 04, 01:44 PM
Roy Smith
Roy Smith wrote in
Ah. I see; a good answer to the wrong question :-)
OK, a couple more (hopefully good) answsers:
1) Because that's what your clearance is.
2) Because it guarantees terrain clearance.
3) Where there's lots of SUA, airways are often designed to avoid the
SUA's.
4) Because they're printed on sectionals, so it helps with situational
awareness.
All that being said, if the route was my own choice and I had GPS, I'd
probably just punch in "direct destination" and off I go :-)
  #30
Old June 17th 04, 03:49 PM
John Bell
Do you define them between two airway points (one behind you) or do
you have to direct to the next fix and just guess how far off the
airway you are?
Robert,
Download my book at www.cockpitgps.com. It's free. Start at GPS Route
Planning, then the Navigation section, then the Route Intercepts Section.
Even though my examples do not use a 296, they are still applicable.
John Bell
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 01:58 PM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 01:53 PM
restarting instrument flying Matthew S. Whiting Instrument Flight Rules 13 November 21st 03 01:04 PM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 03:04 PM
