Source for new Schweizer tailwheels?
Old August 7th 06, 10:55 PM posted to rec.aviation.soaring
Default Source for new Schweizer tailwheels?
Our club 1-34 needs a new tailwheel. Anyone know of a source of new
Schweizer tailwheels, or their equivalent?
TIA,
Kirk
66
Saint Louis Soaring Association
Old August 7th 06, 11:05 PM posted to rec.aviation.soaring
quietman
Mine has been sportin' color coordinated tail and wing tip wheels of
MUCH higher quality than original for the past five years, cost about
$5 total from the bargin bin at 'play it again' sports.
They were made to be used as in-line skate wheels...
....different sizes/colors and nice ball bearings...
John Roe "ZR"
www.roenation.com
Old August 8th 06, 01:58 AM posted to rec.aviation.soaring
BTIZ
most sporting good stores that carry inline skates will have wheels with
sealed bearings, may need to modify the axle bolt or bushings and you are
there.
We modify hockey pucks for wing tip wheels
TIA,
Kirk
66
Old August 8th 06, 05:31 AM posted to rec.aviation.soaring
Mike the Strike
Wheel? Sounds a bit high tech for a Schweizer - put a skid on it!
there.
TIA,
Kirk
66
Old August 8th 06, 06:01 AM posted to rec.aviation.soaring
Hmm, so what I'm hearing is that there is no source of "official"
Schweizer tailwheels? Does that mean we need a 337 to use a
rollerblade wheel?
JUST KIDDING!
I've been using rollerblade wheels for years myself on my Ls6 (got a
spare one in the car - might just try it on the 1-34). I'm just not
sure what the federales consider legal on a certified glider. And we
have plenty of federales in our club, if you know what I mean...
And like Mike says - it would be a bit pathetic if the highest
technology on the 1-34 was the tailwheel!
Kirk
66
Old August 9th 06, 03:37 AM posted to rec.aviation.soaring
ContestID67
You need to worry about replacing the wheel with something certified to
be used on an airplane as all (?) Schweizer gliders carry Standard
Airworthiness Certificates, not Experimental. You can't just put any
old thing into/onto these gliders.
- John
Old August 12th 06, 04:02 PM posted to rec.aviation.soaring
COLIN LAMB
"You can't just put any old thing into/onto these gliders."
Heavens no. If you crash the news media will cite the cause of the crash as
failing to file a flight plan and using a roller blade wheel as a tail
wheel.
Colin
Old August 13th 06, 12:40 AM posted to rec.aviation.soaring
Kilo Charlie
"COLIN LAMB" wrote in message
ink.net...
as failing to file a flight plan and using a roller blade wheel as a tail
wheel.
Colin
And that your nail polish was most likely an explosive device!
Casey
KC
Phoenix (where soaring has been pretty much shut down)
Schweizer Parts? [email protected] Soaring 1 February 19th 06 01:01 AM
Sikorsky To buy Schweizer Aircraft Vaughn Simon Rotorcraft 0 August 27th 04 03:41 PM
Paul A. Schweizer, 1913-2004 Peter W. Smith Soaring 1 August 26th 04 05:13 PM
Paul Schweizer 1913-2004 BTIZ Piloting 0 August 19th 04 02:58 AM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 11:43 AM
