Wonder what kind of 'low rider' trailer you are running
that cannot get a bottle jack under the side of it with a flat tire on the trailer? Or maybe you needed to buy a smaller bottle jack? Two important tips. ALWAYS loosen the lug nuts before jacking. And I would recommend placing the jack aft of the axle. Not too far, as you don't want to adversely load the trailer. This way, you aren't going to try and lift the tongue off the ball. Good advice about sloping ground and always carrying a roll of duct tape with you! Check at an auto parts store for those small capacity floor jacks. That could be very handy, and can fit into the trailer, as we don't all drive pickups. And if the ground is really unsteady, or if it is really windy, might consider also carrying a jack stand. Cheap insurance. Man, the front end of this trailer is getting full! Wing stands, tail dolly, wing wheel, tow bar, one man rigger, spare tire, jack, lug wrench, jack stands, kitchen sink, toilet plunger. THAT is where the TV Remote ended up! Steve Leonard Wichita, KS |
Steve Leonard wrote:
Wonder what kind of 'low rider' trailer you are running that cannot get a bottle jack under the side of it with a flat tire on the trailer? Or maybe you needed to buy a smaller bottle jack? Sorry, I wasn't clear about the problem. If the tire is flat, I can't get the bottle jack under the axle, like I could when it was sitting in the driveway with a good tire. So, I can put it under the side of the trailer. Oops! The jack doesn't raise the trailer high enough to get the spare on the axle, because the spring relaxes as I jack up the trailer side and I run out of jack extension before the axle is very high. At least, that's the way it goes with my Cobra trailer. I'm sure it depends on the details of the axle, tire size, and springs. A scissors jack will still fit under the axle when the tire is flat, so that's what I carry. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
| Thread Tools | |
| Display Modes | |
| Glider Trailer Wiring Tips | jcarlyle | Soaring | 10 | July 15th 06 12:36 AM |
| Glider and Trailer Transport | Paul | Soaring | 5 | March 12th 06 06:58 PM |
| Bad publicity | David Starer | Soaring | 18 | March 8th 04 04:57 PM |
| Need (glider&) trailer transport - Sante Fe, NM > Santa Cruz, CA, late Aug | Eric | Soaring | 1 | August 8th 03 04:21 PM |
| Glider trailer towing | Jeff Landfield | Soaring | 0 | July 21st 03 05:25 AM |
