Hi all,
I'd like to hear from anyone who has used the EasyPulse 5 while flying, and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. -Dan |
"Dan Youngquist" wrote in message ell.org... Hi all, I'd like to hear from anyone who has used the EasyPulse 5 while flying, and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. Oxygen system oxymoron. (Had to throw that in) |
Matt Barrow wrote:
a good but low-buck oxygen system. Oxygen system oxymoron. (Had to throw that in) Well, not necessarily. (I assume the above is what you're referring to.) I'll have a better system for less than 1/3 the cost of the least expensive aviation oxygen systems I've seen. Including adapters to refill from any medical or welding oxygen cylinder, I'll still be at around half the cost. -Dan |
Dan Youngquist wrote: Matt Barrow wrote: a good but low-buck oxygen system. Oxygen system oxymoron. (Had to throw that in) Well, not necessarily. (I assume the above is what you're referring to.) I'll have a better system for less than 1/3 the cost of the least expensive aviation oxygen systems I've seen. Including adapters to refill from any medical or welding oxygen cylinder, I'll still be at around half the cost. -Dan Do tell/share! |
Do tell/share! I would also like to have a cheaper than average o2 hook up for the few times I need to go high. Can you advise, or others, ideas? |
thanks!
and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. I use a Nelson (Precise Flow) demand regulator, with their special cannula, and it works very well. Tested to FL160. I've had my Precise Flight demand valve oxygen regulator to 17,500 ft with the cannulas and they worked fine. --- Ken Reed M20M, N9124X -- Ken Reed M20M, N9124X |
"Ken Reed" wrote in message ... I'd like to hear from anyone who has used the EasyPulse 5 while flying, and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. I use a Nelson (Precise Flow) demand regulator, with their special cannula, and it works very well. Tested to FL160. I've had my Precise Flight demand valve oxygen regulator to 17,500 ft with the cannulas and they worked fine. Any oxygen (delivery) system will work to quite a high altitude; it's the cannulas and mask fit that are critical. Also, your own metabolic (?) use of oxygen. If you're a flatlander, smoker, poor condition, you'll use a lot more at ANY altitude than a mountain dweller, etc. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO (MTJ) |
Peter wrote:
Dan Youngquist wrote Hi all, I'd like to hear from anyone who has used the EasyPulse 5 while flying, and can confirm whether it works at 12K-18K altitudes. Trying to put together a good but low-buck oxygen system. -Dan I use a Nelson (Precise Flow) demand regulator, with their special cannula, and it works very well. Tested to FL160. Agreed. I have the same. It stretches the bottle time, works well, and you tweak it to a higher flow if you want. It's entirely passive (works like a scuba regulator). The Mountain Air one uses more O2, is not really adjustable, and requires a 9V battery. |
| Thread Tools | |
| Display Modes | |
| Oxygen regulator | Roger Fowler | Soaring | 3 | December 26th 05 12:29 PM |
| What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 08:35 PM |
| Scott oxygen mask and diluter demand regulator for sale | nzuri | Soaring | 0 | October 5th 03 09:18 AM |
| Oxygen mask and regulator sale - update | nzuri | Soaring | 0 | October 1st 03 10:31 AM |
| Scott oxygen mask and diluter-demand regulator for sale in UK | nzuri | Soaring | 0 | September 28th 03 11:46 PM |
