Onward.
It's time for serious discussion of Collision Avoidance Systems and techniques. There is no substitute for a good lookout. Don't install all this instrumentation and expect to be able to fly blind. These equipment-based topics come to mind immediately. Batteries. Solar panels. Transponders. Transponder antenna mounting. Altitude encoders. Alternatives, ie: FLARM. and Use and Certification of transponder systems. Some people are installing Lithium Ion batteries instead of traditional Sealed Lead Acid. Your experience? Any more thoughts on the benefits and dangers of Li-Po? There are a few interesting photovoltaic panels available. For example, a 5 Watt "Powersheet" can be mounted on the fuselage above the spar. My only experience with transponders is the Becker ATC 4401 175 Watt unit. It is easy to fit in a glider panel. Eric Greenwell has written a great article on transponders. Look on this web page. http://www.soaringsafety.org/prevention/articles.html Transponder antennas need to point down, have a large ground plane, and have no metal or carbon between them and the outside. Other mounting problems include clearing the tail of the trailer, and proximity to the pilot. I have the plans for an LS-6 antenna mount which goes behind the gear, inside the fuselage. The shop where my system was certified was very happy with the output of the transponder. The encoder I used was the ACK. It is small, light, comes with a mount, and uses little electrical energy. John Carlisle just posted a good review of some alternative systems. http://groups.google.com/group/rec.a...3fca607295037b I am installing an Oz-FLARM in my Australia-based glider. Every aircraft in my club has one. See this article. http://www.users.bigpond.com/keepits...g/OzFLARM1.pdf If you install a transponder system, it must be turned on for the duration of each flight. If the glider batteries are running low, I would suggest contacting ATC and letting them know you need to turn it off to maintain the rest of your instrument panel. Then they shouldn't assume you fell out of the sky. The transponder and altitude encoder neet to be certified every two years. The glidere will not pass an annual inspection with an out of date transponder. Any experience with new technology or better use of old will be of help to all who have ever considered flying with some sort of CAS. Keep your eyes out the window. Jim |
JS wrote:
Some people are installing Lithium Ion batteries instead of traditional Sealed Lead Acid. Your experience? Any more thoughts on the benefits and dangers of Li-Po? I've seen a few people use an auxiliary battery (and associated charger) that was intended to be attached to the bottom of a laptop computer, which should be fairly safe (ignoring the recent experiences of Dell and Apple). If one is tempted to roll their own setup, I suggest they search around for a few videos of shorted or overcharged Li-Po cells, and ask themselves how many they want in the cockpit near them... The encoder I used was the ACK. It is small, light, comes with a mount, and uses little electrical energy. I don't know about that particular encoder, but some consume very little energy sitting in a nice warm hangar, but eat a lot more when the temperature is 0C or below... If you install a transponder system, it must be turned on for the duration of each flight. If the glider batteries are running low, I would suggest contacting ATC and letting them know you need to turn it off to maintain the rest of your instrument panel. Then they shouldn't assume you fell out of the sky. Gliders have a preassigned squawk in the Reno area, and the local ATC folks are aware that a lot of gliders have limited battery capacity, so they don't get uptight when we disappear... Marc |
Marc Ramsey wrote: the local ATC folks are aware that a lot of gliders have limited battery capacity, so they don't get uptight when we disappear... Nevertheless an aircaft that has a transponder is required by the regs to have it operating, or does it? Do Reno area gliders have an LOA that exempts them? ref 91.215 ... (c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an aircraft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC. So you can't use it unless it meets 91.413, but if it does it must be on. The regulation is convoluted and and lawyers may disagree on whether the exemption still applies after a transponder has been fitted to an airctaft that didn't need to have it. Andy |
Andy wrote:
Marc Ramsey wrote: the local ATC folks are aware that a lot of gliders have limited battery capacity, so they don't get uptight when we disappear... Nevertheless an aircaft that has a transponder is required by the regs to have it operating, or does it? Do Reno area gliders have an LOA that exempts them? Independent of the legality (and, I assume, it is not strictly legal), discussions with Reno ATC over the years indicate that they would rather we have transponders and turn them off outside of the high traffic area, then not have them at all... |
If you are out of juice, the transponder would not be "operable".
Mike Schumann "Andy" wrote in message oups.com... Marc Ramsey wrote: the local ATC folks are aware that a lot of gliders have limited battery capacity, so they don't get uptight when we disappear... Nevertheless an aircaft that has a transponder is required by the regs to have it operating, or does it? Do Reno area gliders have an LOA that exempts them? ref 91.215 ... (c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an aircraft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC. So you can't use it unless it meets 91.413, but if it does it must be on. The regulation is convoluted and and lawyers may disagree on whether the exemption still applies after a transponder has been fitted to an airctaft that didn't need to have it. Andy |
"JS" wrote in message ups.com... These equipment-based topics come to mind immediately. Batteries. Solar panels. Transponders. Transponder antenna mounting. Altitude encoders. Alternatives, ie: FLARM. Anytime you are discussing the combination of solar panels and batteries, we also need to be discussing charge controllers. Since you have broached the subject of Lithium Ion batteries, you would need to find a controller that is approved for those batteries. Be aware that the dangers of Lion batteries, largely (but not exclusively) concern charging. There are a few interesting photovoltaic panels available. For example, a 5 Watt "Powersheet" can be mounted on the fuselage above the spar. Not to discourage PV panels, but you only get your entire five watts when the entire panel is flat and pointed directly at full sunlight, and probably not even then. With solar panels, always derate the manufacturer's claims by at least 50% to approach real-life expectations of results. (As they say, your mileage may vary) Vaughn |
Vaughn Simon wrote: Anytime you are discussing the combination of solar panels and batteries, we also need to be discussing charge controllers. Vaughn Thanks. .. Yes, add PV charge controllers to the Liszt! I bought one a while ago on E-Bay for $30. It works fine on SLA batteries. Jim |
For sailplanes, there's an upside though. The PV manufacture's specs list
panel temperature for rated output. Since PV panels make more voltage at colder temps, and as you go up it gets colder, you can turn this into more power from a given PV array. Assuming you pay just a bit more for your solar charge controller and buy a Maximum Power Point Tracker type, your MPPT controller will trade the higher output voltage for up to 30% more current from a given PV panel. MPPT charge controllers, suitable for glider use, are available for under $100. bumper purveyor of QuitVent & MKII "high tech" Yaw String Minden, NV "Vaughn Simon" wrote in message ... "JS" wrote in message ups.com... These equipment-based topics come to mind immediately. Batteries. Solar panels. Transponders. Transponder antenna mounting. Altitude encoders. Alternatives, ie: FLARM. Anytime you are discussing the combination of solar panels and batteries, we also need to be discussing charge controllers. Since you have broached the subject of Lithium Ion batteries, you would need to find a controller that is approved for those batteries. Be aware that the dangers of Lion batteries, largely (but not exclusively) concern charging. There are a few interesting photovoltaic panels available. For example, a 5 Watt "Powersheet" can be mounted on the fuselage above the spar. Not to discourage PV panels, but you only get your entire five watts when the entire panel is flat and pointed directly at full sunlight, and probably not even then. With solar panels, always derate the manufacturer's claims by at least 50% to approach real-life expectations of results. (As they say, your mileage may vary) Vaughn |
| Thread Tools | |
| Display Modes | |
| Removing Ethanol from Gas? | Jay Honeck | Piloting | 67 | August 16th 06 04:29 PM |
| Solar Race Around The World | Larry Dighera | Piloting | 1 | May 11th 06 11:19 PM |
| Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Piloting | 7 | March 14th 05 08:36 AM |
| Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Soaring | 7 | March 14th 05 08:36 AM |
| Thin flexible solar panels | Eric Greenwell | Soaring | 11 | November 28th 03 05:35 PM |
