Solar storms spell trouble for GPS
On Wed, 25 Oct 2006 07:24:58 -0700, "Aluckyguess" wrote in
: Im not worried. Perhaps you should throw your hat in the ring: http://politicalhumor.about.com/libr...bushworry2.htm |
On 25 Oct 2006 07:00:43 -0700, "Walt" wrote in
.com: FWIW, the last solar maximum occured around 2001, and GPS was in common use then; I know I was using mine on a pretty regular basis then. I don't recall any widespread disruptions. Not even slimspread disruptions. :) I'm thinking this may be much ado about nothing. Perhaps you might bring this up with Professor Paul Kintner ): http://people.ece.cornell.edu/paul/ Here's some more information: http://www.news.cornell.edu/stories/...es.gps.TO.html Sept. 26, 2006 Solar flares cause GPS failures, possibly devastating for jets and distress calls, Cornell researchers warn. Alessandro Cerruti of Cornell University, New York http://www.ion.org/meetings/gnss2006...D&session=3#p5 Observed GPS and WAAS Signal-to-Noise Degradation Due to Solar Radio Bursts A. Cerruti, Cornell University GPS signals, systems, and navigation accuracy are vulnerable to a variety of space weather effects that are caused mostly by the ionosphere. However, the sun, which is sometimes a strong radio source, is the cause of GPS signal interference presented here. The first direct observations of GPS L1 (1.57542 GHz) signal-to-noise ratio degradation on two different models of GPS receivers due to the solar radio burst associated with the 7 September 2005 solar flare are presented. Signal-to-noise ratio data from three identical, collocated receivers at Arecibo Observatory and also from four identical receivers of a different model located in Brazil, were available at the time of the solar radio burst. These receivers were all in the sun-lit hemisphere and all were affected similarly. The maximum solar radio burst power associated with the 7 September 2005 flare had a peak intensity of about 8,700 solar flux units (1 SFU = 10-22 W/m2-Hz) RHCP at 1,600 MHz, which caused a corresponding decrease in the signal-to-noise ratio of about 2.3 dB across all visible satellites. Only the right-hand, circularly polarized (RHCP) emissions affected the GPS signals. To confirm the effect, the solar radio burst associated with the 28 October 2003 flare was investigated. Although polarization data were not available for this event, the maximum degradation at GPS L1 was about 3.0 dB, and a degradation of 10 dB was observed on the semi-codeless L2 signal for a solar radio burst of 13,600 SFU. The event analyzed herein can be used to scale historical solar radio bursts of 80,000 SFU. Decreases of 12 dB (21 dB) in the L1 (L2, semi-codeless) signal-to-noise ratio are implied along with loss of tracking for inadequately designed GPS receivers. Since solar radio bursts affect all satellites in view of a receiver, all receivers in the sun-lit hemisphere, the new Galileo navigation system, and all space-based augmentation systems such as WAAS and EGNOS, they are a potential threat to life-critical systems. Institute of Navigation in Fort Worth, Texas: http://www.ion.org/ |
This is a rather alarmist exaggeration of reality.
-- Transpose mxsmanic and gmail to reach me by e-mail. |
Guess we'll have to fly at night.
-- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because we fly, we envy no one. Larry Dighera wrote: http://www.newscientisttech.com/chan...e-for-gps.html Solar storms spell trouble for GPS SOLAR flares can drown out GPS signals with potentially serious consequences for airlines, emergency services, and anyone relying on satellite navigation. It turns out these bursts of charged particles, which produce auroras and geomagnetic storms, also generate radio waves in the 1.2 and 1.6-gigahertz bands used by GPS. How was such a clash missed? Because GPS receivers only became common during a period of low solar activity. By 2011 solar flares will reach the peak of their cycle and receivers will likely fail. Or so Alessandro Cerruti of Cornell University, New York, told a meeting of the Institute of Navigation in Fort Worth, Texas, last week. The only solution would be to redesign GPS receivers or satellites, which may not be practical, says Cerruti. From issue 2572 of New Scientist magazine, 07 October 2006, page 27 |
Larry Dighera wrote: http://www.newscientisttech.com/chan...e-for-gps.html Solar storms spell trouble for GPS SOLAR flares can drown out GPS signals with potentially serious consequences for airlines, emergency services, and anyone relying on satellite navigation. The trouble with the Chicken Littles of the world is that they cry "Wolf!" far too often (how is that for mixing allegories?). When I was in college, the Club of Rome assured us we would be completely out of resources by 1980. Earlier than that, we were going to have a complete totalitarian takeover by 1984. The world was going to end with the Y2K "bug" on Jan 1, 2000. And when that didn't happen, then it was going to end on Jan 1, 2001. Every slot machine in Las Vegas was going to empty itself at midnight on Dec 31, 1999 because it would suddenly indicate that it had not paid since 1899 or something like that. The solar flares were supposed to destroy all radio communications in the 1980s, then the 1990s, then in 2000, now 2011. The peak activity cycle appears to be constantly pushed back by these doomsayers. Someday, of course, they will be right, and they will all get to say "I told you so!" except we will all be dead because we stopped listening to them. Someday the solar flares will shut down all the radios. And all the airplanes will fall out of the sky and all the ships will hit icebergs (if they have not all melted by then) and the earth's magnetic field will flip--flop and the asteroid will hit and the giant super-volcano will erupt and a tsunami 5 kilometers high will hit the coast and California will fall into the sea and we will not be able to do anything about it because we will have used all of our nuclear weapons to knock ourselves back to the stone age and all the resources will be gone and we will be reduced to driving horse and buggies but the hoof and mouth will get the horses and we will have to support ourselves by selling our kidneys but someone will already have stolen one of them and, anyway we will all be living on rafts because the icecaps will have melted and our rafts will be sliding around on the global ice sheets caused by the icecaps melting. Maybe I am just an old fool, but I suspect that if there is really a problem that somebody else who has an actual engineering degree will solve it and make a lot of money doing it. Or maybe somebody will just convince all the politicians that there is a problem where there is not one and we will just have our taxes doubled to pay for an unneeded solution. |
Garner Ted Armstrong and the Worldwide Church of God predicted all
sorts of things that never came true. Thing is, his disiples dont care that he was wrong. They just edited all that out and kept on preachin'... |
Recently, cjcampbell posted:
Larry Dighera wrote: http://www.newscientisttech.com/chan...e-for-gps.html Solar storms spell trouble for GPS SOLAR flares can drown out GPS signals with potentially serious consequences for airlines, emergency services, and anyone relying on satellite navigation. The trouble with the Chicken Littles of the world is that they cry "Wolf!" far too often (how is that for mixing allegories?). (rest snipped for brevity) My sentiments, exactly. Neil |
On Wed, 25 Oct 2006 11:12:07 GMT, Larry Dighera
wrote: http://www.newscientisttech.com/chan...e-for-gps.html Solar storms spell trouble for GPS SOLAR flares can drown out GPS signals with potentially serious consequences for airlines, emergency services, and anyone relying on satellite navigation. As almost any pilot can tell you, this is old news. It turns out these bursts of charged particles, which produce auroras and geomagnetic storms, also generate radio waves in the 1.2 and 1.6-gigahertz bands used by GPS. How was such a clash missed? Because GPS receivers only became common It wasn't except for those who weren't looking. Why do you supposed the government decided we needed to keep a non satellite based backup system operational. during a period of low solar activity. By 2011 solar flares will reach the peak of their cycle and receivers will likely fail. Or so Alessandro Cerruti of Cornell University, New York, told a meeting of the Institute of Navigation in Fort Worth, Texas, last week. The only solution would be to redesign GPS receivers or satellites, which may not be practical, says Cerruti. From issue 2572 of New Scientist magazine, 07 October 2006, page 27 Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
wrote: http://www.newscientisttech.com/chan...e-for-gps.html Solar storms spell trouble for GPS I wonder where Cerutti has been for the last few years. The military has talked about it, hell, it's even been discussed on here. SOLAR flares can drown out GPS signals with potentially serious consequences for airlines, emergency services, and anyone relying on satellite navigation. It turns out these bursts of charged particles, which produce auroras and geomagnetic storms, also generate radio waves in the 1.2 and 1.6-gigahertz bands used by GPS. How was such a clash missed? Because GPS receivers only became common It wasn't, at least not by those paying attention. Just a bit over two years ago we had some of the strongest solar flares on record. Not *the* strongest, but that was because they pretty much missed us. The aurora was visible all the way to Mexico and there have been at least two instances of interruptions to GPS in the last five years. during a period of low solar activity. By 2011 solar flares will reach the peak of their cycle and receivers will likely fail. Or so Alessandro Cerruti of Cornell University, New York, told a meeting of It's happened twice already. How come he didn't know. the Institute of Navigation in Fort Worth, Texas, last week. The only solution would be to redesign GPS receivers or satellites, which may If you blanket a frequency used by a system with signals stronger than the system generates, or strong enough to block the receivers, redesigning them is not going to help unless you move the operational frequency to something that is not interfered with by anything. Maybe they could 2.4 Gigs:-)) not be practical, says Cerruti. As with past interruptions they only lasted a few hours. Of course if we ended up with a coronal mass ejection in the record class pointed straight at us we might lose more than a few satellites, hardened or not. This has also been discussed concerning the safety of astronauts, but they *think* they'd be safe in the most heavily shielded parts of the space station. From issue 2572 of New Scientist magazine, 07 October 2006, page 27 I have talked to stations on nearly every continent using signals reflected off the Ionosphere during an aurora. OTOH I have seen aurora so strong instead of reflecting signals it absorbed them. That was just about two years ago. When it gets that strong few signals make it through. I think that one created about a two hour outage. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Similar Threads | ||||
Removing Ethanol from Gas? | Jay Honeck | Piloting | 67 | August 16th 06 03:29 PM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Piloting | 7 | March 14th 05 07:36 AM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Soaring | 7 | March 14th 05 07:36 AM |
