Ok, my instructor did a simulated engine failure in the pattern; winds
were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
On 1 Nov 2006 15:22:16 -0800, "Nik" wrote:
Do you guys have any ideas Yes: Run, don't walk away from that instructor. Tobias |
One simplified way would be to say you want to spend less time in the
headwind. Oversimplified, but it might at least get him to consider it. Might use some simple math with convenient figures to prove it to him. Best glide isn't in the books because it varies with weight and, as you can see, wind conditions. If you can't get it through to him, take the previous posters advice...run. mike "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. ... But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? You might try pointing him to http://www.av8n.com/how/htm/power.ht...nd-penetration. Or you might try to convince him to let you fly it both ways and see which way gets you further. If that doesn't persuade him, you might decide do it his way when you fly with him, and do it the right way at other times. --Gary |
I'll bet that instructor will get dizzy looking at that web page and stick
to his guns... even though he's carrying blanks. BT "Gary Drescher" wrote in message ... "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. ... But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? You might try pointing him to http://www.av8n.com/how/htm/power.ht...nd-penetration. Or you might try to convince him to let you fly it both ways and see which way gets you further. If that doesn't persuade him, you might decide do it his way when you fly with him, and do it the right way at other times. --Gary |
On 1 Nov 2006 15:22:16 -0800, "Nik" wrote in
. com: But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Go to the Chief Pilot at the FBO, and ask him to explain it to your CFI. |
On Wed, 01 Nov 2006 23:53:05 GMT, Larry Dighera
wrote: Go to the Chief Pilot at the FBO, and ask him to explain it to your CFI. Hey, I like this idea! Then go find another instructor. z |
Remember what you're trying to do he get ready for/pass a checkride!
Barry Schiff recently wrote an article about how he was being checked out for a rental and he set his speed to 55kts during the engine-out exercise because that is the "rate of least descent" for an airplane with a best glide speed of 67 knots. He was trying to set the "least descent" speed to give him time to choose an adequate landing site at which time he would have set the nose for the best glide speed. While Mr. Schiff was right, he got gigged on it and found himself having to prove himself and educate an instructor instead of getting the sign-off and an airplane for an afternoon. He'd have been much better off, for his own purposes, to have been selfish, done as the instructor expected and then rent the airplane. I suspect you might want to think the same way since you're not in a position of credibility as a student and this particular piece of knowledge is probably not universally taught to instructors of powered aircraft. I'm also betting you are correct and that the rules of physics do not change just because you add 300 lbs of dead weight and a motionless propeller to the front of the glider. But, what is it you're trying to do? Prove something he doesn't know? Or are you more interested in proving your competence by his standards? In other words, for what you're trying to get done, please the professor first. Engage in the debate after you get your license. Odds are that you'd have the same tough sell in front of you if you attempt the same argument during your checkride. You can prove you're right later. Does that seem sensible? Humbly, Greg Chapman Nik wrote: Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
Mxsmanic wrote in
: Correct the instructor if he is wrong. If this creates an obstacle to attaining your own objectives, find another instructor. You're kidding, right? |
| Thread Tools | |
| Display Modes | |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Air Force seeks to increase military participation in 8th annual . | Otis Willie | Military Aviation | 0 | June 18th 04 11:53 PM |
