Hi All,
I'm doing some research into the software flying clubs use for logging flights and aircraft usage. Am really interested in understanding what software clubs are using and what features are important? I assume that at some basic level clubs record the flight time, engine on time and other factors? Any help/insights greatly appreciated. Thanks a lot, Mark. |
Medic wrote: Hi All, I'm doing some research into the software flying clubs use for logging flights and aircraft usage. Am really interested in understanding what software clubs are using and what features are important? I assume that at some basic level clubs record the flight time, engine on time and other factors? Any help/insights greatly appreciated. Thanks a lot, Mark. At Penn Yan flying club we use www.tak-off.com/ as our resevation system. We looked at myfbo.com but decided no to go with it as it did not work well with the accounting software. It is much more comprehensive in what it can do though, and if you were starting from scratch may be a better for you. When we looked at it we had tak-off.com up and running and seperate accounts software, and so it would have been problematic to migrate to other software. Ithaca East hill flying club uses myfbo.com though. James. |
In a previous article, "Medic" said:
I'm doing some research into the software flying clubs use for logging flights and aircraft usage. Am really interested in understanding what software clubs are using and what features are important? I assume that at some basic level clubs record the flight time, engine on time and other factors? Any help/insights greatly appreciated. The Rochester Flying Club http://www.rochesterflyingclub.com/ uses ScheduleMaster for booking. We don't use software for logging flights, just paper tach slips. You can see our tach procedure at http://www.rochesterflyingclub.com/tach.pdf. A club volunteer collects the tach slips every month and enters them into Quickbooks for billing and Quickbooks generates the bills and emails them out. Each airplane has a maintenance coordinator (volunteer) who watches the tach numbers for that plane to see if it is getting to be time for oil changes and schedules annuals and takes care of squawks and the like. -- Paul Tomblin http://blog.xcski.com/ Did you know that "Gullible" is not in the dictionary? |
On Sun, 05 Nov 2006 15:23:03 +0000, Paul Tomblin wrote:
The Rochester Flying Club http://www.rochesterflyingclub.com/ uses ScheduleMaster for booking. We don't use software for logging flights, just paper tach slips. You can see our tach procedure at http://www.rochesterflyingclub.com/tach.pdf. A club volunteer collects the tach slips every month and enters them into Quickbooks for billing and Quickbooks generates the bills and emails them out. My partnership http://flyingclub.org/ also uses schedule master, but we use the flight logging capability too. This information is imported into Quickbooks, and this is apparently a very simple process (I've not done that myself). Each airplane has a maintenance coordinator (volunteer) who watches the tach numbers for that plane to see if it is getting to be time for oil changes and schedules annuals and takes care of squawks and the like. Since we use the flight logging in SM, and the MX scheduling capability, SM itself notifies the MX staff when periodic MX is required. MX can be scheduled by calendar or tach hour. The amount of warning provided can be customized on a per-MX-task basis. I cannot compare it to other packages, not being familiar with them. But SM does a very nice job of helping our partnership run. We've also asked for the odd customization occasionally, and they've been very accommodating. - Andrew |
In a previous article, Andrew Gideon said:
On Sun, 05 Nov 2006 15:23:03 +0000, Paul Tomblin wrote: The Rochester Flying Club http://www.rochesterflyingclub.com/ uses ScheduleMaster for booking. We don't use software for logging flights, just paper tach slips. You can see our tach procedure at http://www.rochesterflyingclub.com/tach.pdf. A club volunteer collects the tach slips every month and enters them into Quickbooks for billing and Quickbooks generates the bills and emails them out. My partnership http://flyingclub.org/ also uses schedule master, but we use the flight logging capability too. This information is imported into Quickbooks, and this is apparently a very simple process (I've not done that myself). Interesting. The people with access to Quickbooks in our club say that there is no import ability. Or maybe it's the fact that they're using the web-based Quickbooks. -- Paul Tomblin http://blog.xcski.com/ Like the man said: "Nothing good ever goes in /opt." -- Tim Foreman |
In a previous article, said:
I would NEVER want my books held on someone else's equipment, as you do with a web-based financial program. We tried running a Quickbooks server, but according to the guy running it it had to be a Windows server, and he couldn't get it to work reliably and some of the officers had problems connecting to it even when it was up. (I suspect their ISPs were blocking connections to the ports required.) The problem is that we've got 3 or 4 people who need access to the books, and so a non-shared version wouldn't work for us. -- Paul Tomblin http://blog.xcski.com/ "Science, freedom, beauty, adventu What more could you ask of life?" -- Charles Lindbergh, writing about aviation |
What's flight logging?
My club uses Schedue Master for booking. I was not aware that they have flight logging capability. Can this be used for logging Tach Time? How do you turn it on? Is it part of the Squawk module? I couldn't find anything at all about it. Or are you just using one of the numeric user fields to record tach time? Thanks. Andrew Gideon wrote in news
On Mon, 06 Nov 2006 02:51:01 +0000, Judah wrote:
What's flight logging? [...] Can this be used for logging Tach Time? You've answered your own question: "flight logging" is a way to enter tach (or hobbs, I suppose, if you use that) time for each flight. One schedules a flight via SM, flies the flight (w/o SM {8^), and then enters the starting and ending tach times into SM. How do you turn it on? Is it part of the Squawk module? I couldn't find anything at all about it. With that, I cannot help you. This has been used since before I joined the partnership. But I'm sure SM would be happy to answer your question by phone or email. As I wrote, we've found them to be quite helpful. Or are you just using one of the numeric user fields to record tach time? No. SM is very aware of the meaning of the entered times, using them to determine when hour-scheduled MX is upcoming. Since I expend my effort on the MX side of things, I'm very happy to have that. Those on the finance side of things are happy to have the download of flown hours into Quickbooks, but all I know about that is that it exists. - Andrew http://flyingclub.org/ |
| Thread Tools | |
| Display Modes | |
| Flying Club Memberships Available in Morristown, NJ | [email protected] | General Aviation | 0 | October 26th 06 04:49 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Flying Club Features | Andy | Piloting | 28 | April 14th 05 11:15 PM |
| Considerations for joining flying club | Marty Ross | Piloting | 17 | September 18th 04 07:24 PM |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
