Modular Gliders
on aircraft with removable wings, how do the regs approach the
possibility of you using wings from some other glider on your fuselage? I suspect that on certified gliders, there is some sort of serial number associated with the wings that match it to the glider, but how about experimentals? Could I take some wings off someone elses Cherokee II and put on my fuselage and go fly? what if those wings hadnt had a condition inspection in the last year but my fuselage has? Would it be legal if the wings had had a condition inspection? Lets say you are landing out in your long winged certified glider and take out a tree with one wing. rest of glider is ok but that one wing is toast. Is the wing technically "rebuilt" where the serial number from the busted wing is attached to a good wing? In other news, anyone know where a Cherokee II project is laying around? Not for me but I know of a need for a set of wings. Otherwise Im consiering taking the other fuselage, bolting it to mine and making the worlds first two cockpit glider, similar to the two cockpit P51 from late WWII. I figure itll be a great way to teach other people how to fly cross country in crappy gliders. plus when they want to move up in performance, i can just remove one of the fuselages. If you havent figured it out, the season in Iowa is pretty much over, let the real fun begin! |
Modular Gliders
Assuming the gliders are of the same type [not a Cherokee
with Nimbus wings] then you will need to send a F337 to your local FSDO plus a logbook entry. I think this applies both to certified and experimental aircraft. Also to one wing or both wings being replaced. Don't know about you, but I would certainly want the new wing inspected before flying with it [or even before buying it] and then annual and W+B the whole mule before flight. Ian At 20:36 02 November 2006, Tony wrote: on aircraft with removable wings, how do the regs approach the possibility of you using wings from some other glider on your fuselage? I suspect that on certified gliders, there is some sort of serial number associated with the wings that match it to the glider, but how about experimentals? Could I take some wings off someone elses Cherokee II and put on my fuselage and go fly? what if those wings hadnt had a condition inspection in the last year but my fuselage has? Would it be legal if the wings had had a condition inspection? Lets say you are landing out in your long winged certified glider and take out a tree with one wing. rest of glider is ok but that one wing is toast. Is the wing technically 'rebuilt' where the serial number from the busted wing is attached to a good wing? In other news, anyone know where a Cherokee II project is laying around? Not for me but I know of a need for a set of wings. Otherwise Im consiering taking the other fuselage, bolting it to mine and making the worlds first two cockpit glider, similar to the two cockpit P51 from late WWII. I figure itll be a great way to teach other people how to fly cross country in crappy gliders. plus when they want to move up in performance, i can just remove one of the fuselages. If you havent figured it out, the season in Iowa is pretty much over, let the real fun begin! |
Modular Gliders
Earlier, Ian Cant wrote:
Assuming the gliders are of the same type [not a Cherokee with Nimbus wings] then you will need to send a F337 to your local FSDO plus a logbook entry. I think this applies both to certified and experimental aircraft... Actually, that does not apply to sailplanes that carry Experimental, Amateur-Built certificates. This article by Earl Lawrence of the EAA Government Programs Office spells out most of the requirements for maintaining and modifying homebuilt aircraft: http://www.wanttaja.com/avlinks/MAINT.HTM The way I understand FAA form 337, it describes deviations between an aircraft and its FAA type certificate. However, note that many US homebuilt sailplanes carry operating limitations that specify that the operator must notify the FAA of any major repairs or alterations. The FAA may require a test period to validate the changes. This was the case when I developed and installed a retrofit center stick control system for my HP-18. The FAA guys came out to the airport, inspected it, made sure the paperwork was in order, and gave me a new airworthiness certificate and operating limitations. Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
Modular Gliders
Tony wrote: Otherwise Im consiering taking the other fuselage, bolting it to mine and making the worlds first two cockpit glider, similar to the two cockpit P51 from late WWII. This has been done already. In Lithuania, Sportine Aviacija, (aka The LAK factory) used two L-13 Blanik glider fuselages to make a two fuselage glider. On the wing between the fuselages was mounted a test rig into which airfoil sections could be mounted. The idea was to test airfoils in the real atmosphere. I was told it flew very poorly and was disasembled after a short time. Robert Mudd Moriarty, New Mexico |
Modular Gliders
that twin blanik is pretty cool! I totally forgot about 337 forms,
that makes sense. I guess it would apply as a major repair or alteration. of course i wouldnt want to fly wings without them being inspected, i just couldnt remember how it worked. Derek Ruddock wrote: See here for a photo. No wonder it didn't fly well http://discovery.ot.lt/cfair97/images/misc04.htm At 01:00 03 November 2006, wrote: Tony wrote: Otherwise Im consiering taking the other fuselage, bolting it to mine and making the worlds first two cockpit glider, similar to the two cockpit P51 from late WWII. This has been done already. In Lithuania, Sportine Aviacija, (aka The LAK factory) used two L-13 Blanik glider fuselages to make a two fuselage glider. On the wing between the fuselages was mounted a test rig into which airfoil sections could be mounted. The idea was to test airfoils in the real atmosphere. I was told it flew very poorly and was disasembled after a short time. Robert Mudd Moriarty, New Mexico |
Modular Gliders
Tony wrote: on aircraft with removable wings, how do the regs approach the possibility of you using wings from some other glider on your fuselage? Helped rig Ventus C wings on a B once, took a while to sort out the mixer. That one had a wing that was run over by a truck during a retrieve. Jim |
Similar Threads | ||||
Engine noise recording in Motor Gliders | Ian Strachan | Soaring | 2 | October 16th 06 12:32 PM |
Special Airworthiness Cert'd-Exp, Exhib&Racing Gliders | Jim Culp | Soaring | 0 | July 30th 06 07:04 AM |
Hanger and gliders hit by storm. | [email protected] | Soaring | 6 | February 1st 05 01:44 AM |
Production rates? | Ed Byars | Soaring | 38 | November 24th 04 04:13 PM |
Underwater Gliders | Burt Compton | Soaring | 6 | November 25th 03 04:43 AM |
