Maximum PT entry altitude Notation
Old November 23rd 06, 03:20 AM posted to rec.aviation.ifr
Default Maximum PT entry altitude Notation
Can anyone explain the reason for the note "maximum procedure turn
entry altitude 6000 feet" on the ILS or LOC RWY 20 at KALW, Walla Wala
Regl, WA? Is this a TERPs thing? Other approaches the same?
Here's the link, I think
http://i41.photobucket.com/albums/e2.../KALWils20.gif
Old November 23rd 06, 03:58 AM posted to rec.aviation.ifr
Roy Smith
My guess is that if you enter the PT above 6000, you can't make it down to
the runway without exceeding some TERPS-mandated maximum descent profile.
If you flew the PT as a teardrop entry, 1 minute outbound, roughly 1 minute
to turn around, 1 minute inbound, that's 2700 feet to lose in 3 minutes, or
900 ft/minute. Pretty steep.
Old November 23rd 06, 04:14 AM posted to rec.aviation.ifr
John R. Copeland
"Roy Smith" wrote in message ...
Yet, no similar note accompanies the NDB RWY 20 approach.
Old November 23rd 06, 06:10 PM posted to rec.aviation.ifr
Everett M. Greene[_2_]
Roy Smith writes:
Is there anything that says you can't make more than one
lap around the loop?
Are there enroute altitudes in the area that would lead
to being quite high when nearing the approach area?
Is there a reception problem with the navaid(s) defining
the pattern?
Old December 11th 06, 04:50 PM posted to rec.aviation.ifr
Sam Spade
Everett M. Greene wrote:
Roy Smith writes:
The PT completion altitude is permitted to be as much as 2,000 feet
above the inbound altitude. That maximum is not close to being reached
at RDL, OLM, or ALW.
Several years ago TERPS was amended to have three pattern sizes for
procedure turns from the former one pattern (speaking only of 10-mile
turns).
In Change 18 of TERPS the former single pattern became the new "small"
pattern for minimum possible altitude to 6,000. The new, midsize
pattern was introduced to handle 6,000 to 10,000, and the large size
pattern was introduced to handle above 10,000.
The selection process was the highest feeder route altitude or procedure
turn completion altitude, whichever is higher.
This worked fine until someone in the FAA decided that pilots are stupid
and might come barreling in at 17,000 feet or so. So, enters the cap.
There was no coordination with industry groups, nada.
Now, the pot is being stirred.
They were getting ready to do it at HQM (VOR Runway 6) but that has been
objected to in coordination and is now on hold.
http://www.avn.faa.gov/folderdetail....-HQM&replace=1
Old November 26th 06, 03:37 AM posted to rec.aviation.ifr
As a follow up, looking at the low level enroute, there is no
restricted or otherwise airspace that may have affected the altitude.
Secondly, there are a few other airports in WA with similar 6000 max
altitude for the PT. RLD Richland is one, so is OLM Olympia.
In fact the RLD PT descends you to 1900 feet for a total descent of
4100 feet, so it doesn't seem to be a TERPS descent gradient
limitation for ALW.
Of note, all the 6000 foot max notations are on very recently amended
approaches, so they appear to be recent additions. I'm only guessing
it's some new TERPS criteria, possible to limit the TAS and help keep
the pilot within the 10 nm PT distance.
Roy, I've appreciated reading your responses over the years. Am I
right to think you've been contributing for 15+ years?
Dave
Old November 26th 06, 07:55 PM posted to rec.aviation.ifr
limitation for ALW.
They don't do a descent in PTs? Best I can do is 800 fpm so take 500
as a standard that lets me do 1000 feet each time I go around. It
keeps the speed normal and the distances normal.
Roger, by limit the TAS, I meant that for the same IAS, the TAS will
be higher at higher altitudes. And so easier for the pilot to exit
the PT distance
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Accurate plane performace? R Simulators 27 December 19th 03 05:54 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
