Glue it to it
To All:
A few days ago I responded to Lou's question about the cold weather performance of T-88... http://groups.google.com/group/rec.a...40a97c3fdfa121 ....where in closing I said, "Marvelous as epoxies are they don't even come close to resorcinol when it comes to durability." Boy, did I catch hell :-) One feller politely provided me with a table of specifications for various epoxies showing their shear strength, modulus of rupture and modulus of elasticity. At least half of the figures were better than the specs for Weldwood Resorcinol. Another less polite message informed me I didn't know what I was talking about. It seems this particular person had been using T-88 since it was introduced '...during the Second World War..' and stated it was the best glue ever invented. - - - - - - - - - - - - - - - - - - - - - - - - - Allow me to repeat the obvious: Bum Dope can get you killed. At least half of the information on the internet is incorrect to some degree. Anyone offering an opinion should be willing to back it up, if not with facts, at least with the basis for their opinion. So here goes :-) - - - - - - - - - - - - - - - - - - - - - - - - - - 'Epoxy' as a chemical term dates from the early 1900's with the first patents applied for in Germany during the 1930's. During World War II some epoxies were developed for various roles - - adhesives, insulators, paints and so forth - - but commercial exploitation of epoxies was not seen on any scale until the late 1940's with the development of methods for making the stuff from natural gas. With regard to T-88, as best I can recall it didn't arrive on the scene until the early 1970's, not '...during the Second World War.' I'll be more than happy to admit my error here if someone can offer a better reference. (I'm old. I fart a lot and forget things.) As I said in my response to Lou, epoxies are marvelous stuff as adhesives but when it comes to their durability they don't do as well as plain old-fashioned resorcinol. At least, not if we are talking about gluing wood, and specifically so when the task is gluing birch plywood to softwood stringers. Shear strength remains high but peel strength declines with age. Fortunately, it's rare for a birch-spruce joint in an aircraft structure to be subjected to a delaminating load. Something else would have to fail first. (Hint: Given enough time, simply allowing moisture to collect inside the structure would be sufficient.) This comes under the heading of Old News since the problem has been around as long as epoxies themselves. But in the late 1960's there were indications that certain chemical 'coupling agents' could facilitate a CHEMICAL bond between an adhesive and whatever it was applied to. This created an enormous amount of interest because it hinted we might be able to GLUE metals together and end up with a joint equal to welding, riveting, brazing and so on. As you may have noticed, that hasn't happened. Yet. At least, not with metals on an industry-wide scale. But it HAS happened with wood and some plastics. In 1995 a fellow named Charles B. Vick from the Forest Products Laboratory presented a paper in Portland describing tests with a coupling agent called HBR (hydroxymethylated resorcinol) as a means of enhancing the adhesion of epoxy to wood. The results of the tests were so promising that it lead to the academic equivalent of dancing in the streets (which means more studies. :-) The key point here is that the tests compared epoxies, enhanced or otherwise, to plain old-fashioned resorcinol, which I believe justifies my statement to Lou. In the decade since Mr. Vick presented his paper on epoxy and HBR he has completed a number of other studies, read with the keenest interest by folks selling epoxy glues. And by guys like me who occasionally trust their lives to an assemblage of glued joints. In responding to Lou's message I felt I was doing what any other homebuilder would have done had he gotten to the keyboard first. But if I erred in doing so, please have the courtesy to state your correction publicly since doing so privately makes it little more than a personal attack and contributes nothing to the sum store of information. - - - - - - - - - - - - - - - - - - - - As I've mentioned in earlier articles ('Glue Wars,' etc.) ALL modern adhesives are stronger than the softwoods normally used for airplane construction. That means the question of strength drops out of the equation when selecting what we're going to use to gluit toit. While epoxies are the near-ideal adhesive for airplanes the gritty reality is that it's more expensive than other equally useful glues. Such considerations fly right over the head of someone who thinks a thirty thousand dollar kit is 'inexpensive' and it's $25,000.00 engine 'affordable' but the hundred dollar difference between an epoxy from Aircraft Spruce and a few pounds of Weldwood 'Plastic Resin' from the local Borg is a CRITICAL factor to the tens of millions of Americans who can simply no longer afford to be a part of the General Aviation community. -R.S.Hoover |
Similar Threads | ||||
resorcinol = Carpenter's glue | [email protected] | Home Built | 13 | June 12th 05 11:01 PM |
Removable glue | Lou | Home Built | 2 | April 14th 05 06:57 AM |
Glue question | [email protected] | Owning | 1 | December 6th 04 03:25 PM |
Drywall Gussets | Veeduber | Home Built | 5 | October 27th 03 09:03 PM |
Qn: Casein Glue recognition | Vassilios Mazis | Soaring | 0 | August 20th 03 10:00 PM |
