GNS 430W vs GNS 480
Old January 4th 07, 01:03 PM posted to rec.aviation.ifr
Sam Spade
Default GNS 430W vs GNS 480
Ron Rosenfeld wrote:
Perhaps what you are asking is whether the MDA on an LNAV approach with
advisory vertical guidance can be treated as a DA. When last I checked
(with the local FSDO) this was in a state of flux. However, the written
guidance from Garmin indicates that LNAV approaches should be flown using
the MDA concept, even if there is advisory vertical guidance.
I was actually asking all of the above. ;-) My take on it would be the
case of advisory vertical guidance on an LNAV-only approach with the
"approved operator" note cannot be used as a DA unless you have a letter
of authorization.
  #62
Old January 4th 07, 02:26 PM posted to rec.aviation.ifr
Ron Rosenfeld
of authorization.
When I spoke with the local FSDO, which was shortly after the advisory
vertical guidance became available, that was their take also. But they
were not sure what the eventual status would be for Part 91 small a/c
operators.
  #63
Old January 4th 07, 03:22 PM posted to rec.aviation.ifr
Sam Spade
of authorization.
operators.
As a practical matter it is much to do about very little ;-)
When you arrive at MDA using the "advisory" vertical guidance (which,
according to my contact at Garmin is more than advisory, in the sense it
is primary vertical guidance and assures stepdown fixes) you are at the
same place as the approved operator with DA would be. So, if you see
the right stuff you land, if not you can either level off at MDA and go
to the MAP or just missed immediately.
If the feds eventually say you will use the DA concept then you would
have to miss immediately if you did not have the required visual references.
  #64
Old January 4th 07, 03:43 PM posted to rec.aviation.ifr
Sam Spade
Ron Natalie wrote:
Robert M. Gary wrote:
The 480 is more capable (has holds, etc), but the 430 is *MUCH* easier
to use.
I disagree. If you are unsullied by having used the 430, it's much
easier to run the 480. The user interface is FAR superior on the
480. The only thing that the 430 has going for it is it carries
forth the legacy of the entire Garmin previous handheld/panel mount
behavior.
The other thing the 400/500 carries is the foundation for understanding
the nav aspects of a G-1000, irrespective of aircraft the G-1000 is
installed in.
  #65
Old January 4th 07, 05:14 PM posted to rec.aviation.ifr
Robert M. Gary
That's a motivation to upgrade the G1000 to WAAS. However, I just read
somewhere that the rumor is that the WAAS G1000 systems will not drive
VNAV to the KAP140. So you won't be able to fly fully coupled VNAV
approachs with the KAP140 (even though you can fly a fully coupled ILS
with it).
If an LNAV approach has VNAV minimums will you be able to use DA or will
you have to use the MDA concept?
I don't believe a coupled autopilot is a requirement for the VNAV so I
assume I would be able to fly to DA once the G1000 has WAAS.
-Robert
  #66
Old January 4th 07, 05:47 PM posted to rec.aviation.ifr
Ron Rosenfeld
of authorization.
operators.
Which would be a shame since, in many instances, the intersection of the
generated glide path with the MDA may be further from the AER than the
minimum visibility. e.g. at EPM it is 1.3 mi from the MAP but the
visibility minimum is 1.0 miles.
  #67
Old January 4th 07, 06:45 PM posted to rec.aviation.ifr
Sam Spade
with it).
-Robert
I would agree for L/VNAV but not for LNAV+V
