Stall Recovery
Old January 24th 07, 06:32 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Danny Deger
Default Stall Recovery
I am looking for other people's technique for stall recovery. Before I flew
F-4s, I dropped the nose to gain airspeed well above stall speed and then
recovered well away from stall angle of attack. After F-4 training, I would
lower the nose to get just below the stall and recover with the airplane of
the verge of a stall. This is done by the feel of the airplane buffet and
handling characteristics and not by looking at airspeed. While training for
air to air combat, I flew the F-4 by feel to be close to stall. This is
done to turn rate in combat.
The key to the later stall recovery technique is to be very good at flying
the airplane very close to the stall by using aircraft feel, i.e. practice
slow flight a lot. The advantage is very little altitude lost in the
recovery.
Danny Deger
Old January 24th 07, 06:44 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
John Carrier
Basically true for any swept wing, non-digital flight control, aircraft.
The F-4 hard wing had variations of buffet that could be flown to quite
precisely: light, moderate, heavy, Jimmy? Best technique for stall
recovery is to reduce AOA to max lift or slightly below, pretty much what
you describe. Feel and buffet cues can be adequate, sometimes it's
necessary to check the AOA.
The soft wing had little buffet. AOA gauge was essential. Easy to maneuver
yourself into an energy hole. Saw a lot of F-4S guys do this.
Modern A/C can generate so much AOA that they can maneuver while enduring
massive induced drag (resulting in rapid airspeed and/or altitude loss ...
Kinetic or Potential, its all PsubS).
R / John
"Danny Deger" wrote in message
flew F-4s, I dropped the nose to gain airspeed well above stall speed and
then recovered well away from stall angle of attack. After F-4 training, I
would lower the nose to get just below the stall and recover with the
airplane of the verge of a stall. This is done by the feel of the airplane
buffet and handling characteristics and not by looking at airspeed. While
training for air to air combat, I flew the F-4 by feel to be close to
stall. This is done to turn rate in combat.
recovery.
Danny Deger
Old January 24th 07, 10:44 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Danny Deger writes:
Diminish the angle of attack. You can do this by changing pitch or
changing speed to change the angle at which the airstream meets the
wings. Modulate this in accordance with circumstances. If you don't
have much altitude, pitching downward may not be the way to do it. If
you are already at maximum thrust, increasing speed may not be an
option.
Old January 27th 07, 10:27 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Tankfixer writes:
If you have a combination of these two it may be time to give the
aircraft back to the taxpayers....
Some aircraft are designed specifically to fly in a "coffin corner"
(e.g., the U-2). I hope they have automated systems, as it would be
very tiring to maintain that hour after hour.
Old January 28th 07, 10:20 AM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Roger[_4_]
On Sat, 27 Jan 2007 19:52:07 GMT, Tankfixer
mumbled
If you don't have much altitude, pitching downward may not be the way to do it. If
you are already at maximum thrust, increasing speed may not be an option.
It is considered poor form to run out of airspeed, altitude, and ideas
all at the same time.
Old January 28th 07, 02:31 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Jay Somerset
mumbled
Unless you have just executed a pefect landing, and that was what you
intended to do. :-)
Old January 29th 07, 02:34 AM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Roger[_4_]
On Sun, 28 Jan 2007 08:31:31 -0500, Jay Somerset
mumbled
intended to do. :-)
But the perfect landing doesn't include all three. Air speed and
altitude I'd agree, but you still have ideas left as in not it's time
to taxi to the hangar or go get gas. :-))
www.rogerhalstead.com
Old January 24th 07, 10:47 PM posted to rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Roger[_4_]
On Wed, 24 Jan 2007 11:32:05 -0600, "Danny Deger"
recovery.
That works for Debonairs, F33s, Cherokees, and most others as well. On
my last biennial flight review the instructor wanted to see if I could
stall the plane in a departure stall and not lose any altitude. We
could and even in a stall from slow flight with every thing hanging
out the loss was about 30 feet.
Danny Deger
Cable break recovery spin entry... as previously discussed [email protected] Soaring 26 July 3rd 05 09:28 AM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Proper stall recovery technique Chris OCallaghan Soaring 0 February 2nd 04 11:33 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
