O2 Bottle for ASW27B
Old January 25th 07, 04:54 AM posted to rec.aviation.soaring
Jim Cumiford
Default O2 Bottle for ASW27B
I need a solution for an O2 bottle and EDS regulator
that fits my 27B with the seat back in the full aft
position. Any excellent ideas floating around out there?
Old January 25th 07, 05:28 AM posted to rec.aviation.soaring
Easy. The EDS regulator fits directly on top of the bottle. You can
rotate the regulator outboard such that the seat back does not
interfere with the assembly. I used a heavy duty 3M Velcro like
product to attach the EDS Control head to the side of the cockpit
between the Landing gear Up and Down detents.
http://www.gliderforum.com/photos/sh...&currentpos=12
http://www.gliderforum.com/photos/sh...&currentpos=11
On Jan 24, 8:54 pm, Jim Cumiford
Old January 25th 07, 02:19 PM posted to rec.aviation.soaring
Andy[_1_]
Old January 25th 07, 02:24 PM posted to rec.aviation.soaring
Andy[_1_]
For my 28 I used what seems to be the same bottle as Paul but found the
valve knob contacted the seat back. I replaced the valve knob with a
modified smaller knob from a water faucet (tap). I'm using a Nelson
regulator and had to extend the pressure gage so it could be seen in
flight.
Andy
Smoke system using used propane torch bottle? Scott Home Built 9 August 18th 06 01:55 AM
Military bailout bottle refill [email protected] Soaring 3 June 30th 06 06:59 PM
Using European Oxygen Bottle in DG-1000? Where to buy? Jeremy Zawodny Soaring 3 September 20th 05 04:14 PM
DG-400 Oxygen Bottle Problems [email protected] Soaring 23 September 8th 05 11:43 PM
Kerry's BITCH, Teresa...caught deep throating ketchup bottle George Z. Bush Military Aviation 1 August 10th 04 03:31 PM
