2K Paint Option on S-H Ventus?
Old February 4th 07, 04:48 PM posted to rec.aviation.soaring
V1
Default 2K Paint Option on S-H Ventus?
I'm buying a new Ventus from the factory, and considering the pro's
and con's of their "Special 2K-painting" option, which is about 3000
Euro. Would like to hear any real-world experience that other pilots
have.
From discussions with the dealer and some on-line research, the 2K
paint (a polyurethane paint, if I understand correctly) has the
advantage of a tougher, lower-maintenance finish, but the downside of
being more difficult to repair scratches or damage. While a pilot can
learn to do their own minor gel-coat repairs, 2k paint requires
special equipment and is highly toxic if not used with protective
gear.
I'm based in Houston - high humidity. Although I plan to race, I fly
mostly for fun and am more interested in simplicity and practicality
than in getting or keeping that last increment of performance.
I searched ras, and only found discussions several years back on 2k
and polyurethane. Would like to hear from anyone with experience with
the Schempp-Hirth 2K paint option in specific, or current thinking in
general about factory 2K paint vs gel-coat.
- Frank Allen, Houston
Old February 4th 07, 05:58 PM posted to rec.aviation.soaring
W.J. \(Bill\) Dean \(U.K.\).
Look at the DG web-site http://www.dg-flugzeugbau.com/index-e.html , go to
"Innovations" then to "Polyurethane Paint - The Better Alternative" ,
http://www.dg-flugzeugbau.com/pur-lack-e.html .
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"V1" wrote in message
have.
gear.
Old February 4th 07, 09:51 PM posted to rec.aviation.soaring
BB
If one does this, does it make the inevitable sanding after the spar
bump appears in a few years much harder? I have heard of pilots
ordering PU on control surfaces and fuselage, but leaving the wings in
gelcoat for this reason.
John Cochrane
Old February 4th 07, 10:12 PM posted to rec.aviation.soaring
John Galloway[_1_]
I have a D2cT with 2K paint. A friend has a V2CxT
with it and another is getting a D2cT in 2K in March
having seen the first two gliders. A super finish
at a fair price IMHO.
You can fill little chips with cheap gelcoat filler
(e.g Plastic Padding in the UK) and hardly notice them.
I dropped a wing and got some bigger scratches but
a repair shop painted them ( and replaced my temporary
gel patches) with the original MIPA 2K for reasonable
cost at the annual check and they are invisible now.
The advantages of not having gel deteriorate far outweigh
the minor inconvenience of sorting chips.
John Galloway
At 17:06 04 February 2007, W.J. \bill\ Dean \u.K.\.
, go to
'Innovations' then to 'Polyurethane Paint - The Better
Alternative' ,
Remove 'ic' to reply.
'V1' wrote in message
roups.com...
the pro's
and con's of their 'Special 2K-painting' option, which
is about 3000
that other pilots
have.
the 2K
has the
but the downside of
While a pilot can
requires
with protective
gear.
to race, I fly
and practicality
performance.
years back on 2k
experience with
current thinking in
Old February 5th 07, 03:53 AM posted to rec.aviation.soaring
Jack[_4_]
My experience is with the same type of finish, but a different
airplane. My PIK is 31 years old and has teh original finish...
polyurethane.
Can't get much better than that.
Jack Womack
Clear coat peeling: Suggestions? Mike Owning 15 December 20th 06 01:23 AM
Paint Shop Steve - KDMW Owning 3 March 20th 06 05:14 PM
Update on new paint job and leather seats Longworth Owning 3 November 21st 05 11:00 PM
Update on new paint job and leather seats - Trip back home Longworth Piloting 6 November 21st 05 07:52 PM
Thinning paint Michelle P Owning 12 June 4th 05 01:37 PM
