ATC Handling of Low-Fuel American Flight
Old February 24th 07, 12:21 AM posted to rec.aviation.ifr
Roy Smith
Default ATC Handling of Low-Fuel American Flight
In article , Mitty
On 2/23/2007 9:01 AM, Robert Chambers wrote the following:
I gotta wonder if the approach
controller told the local controller that there was an emergency
declared, it didn't appear on the video but my have been edited out.
and what was AA squawking? A 7700 should have made sure everyone knew.
If you've already told the controller you have an emergency, squawking 7700
doesn't add anything to the situation. The 7700 stuff is for when you're
out of radio contact.
Old February 24th 07, 12:55 AM posted to rec.aviation.ifr
Sam Spade
tscottme wrote:
Yeah, that is what struck me about the video, the approach controller didn't
mention "emergency" in the phone call to tower controller. It that indeed
happened, I wouldn't put much blame on ATC, except the approach controller.
I'm thinking that runway assignment and suitable vectors would have been in
use befor AA crew ever talked to tower freq.
I first expected the video to show yet another "ahhhh approach we got us
here this little ol' situation and we're just wondering how ol' 17 center is
lookin..." that some pilots seem determined to use when they have an
emerigency. I understand the psychological need to keep a lid on things,
and understand denial as well as the next guy, but many pilots need to
better understand that declaring an emergency should come more easily than
they often assume.
You are absolutely correct. Airline pilots, as a group, tend to be the
worst about this because of subtle company intimidation.
ATC could have very well taken this as a declaration of minimum fuel,
which is NOT a declaration of emergency.
The magig words are, "American 123 is declaring an emergency." ATC
response, "American 123 what is the nature of your emergency?" And,
then the trolly is on the track.
If ATC fails to respond to that properly and gives the run around, the
pilot should then be resourceful to get them to understand they will
give him what he needs. "Mayday, mayday, mayday" is one option that
hopefully should not be needed.
Old February 24th 07, 01:12 AM posted to rec.aviation.ifr
Mitty
On 2/23/2007 6:21 PM, Roy Smith wrote the following:
Au contraire. With a 7700 squawk then if the emergency situation wasn't
mentioned in the handoff (which it possibly wasn't) then the next controller
would still have known something was seriously wrong.
(Now possibly if AA had squawked 7700 he would have been asked to switch off
that code at some point, but we don't even know from the video whether he tried it.)
Old February 24th 07, 01:14 AM posted to rec.aviation.ifr
Mxsmanic
Sam Spade writes:
Fortunately, in practice, ATC will bend over backwards to accommodate any
aircraft with an emergency, and so will other pilots.
Old February 24th 07, 01:25 AM posted to rec.aviation.ifr
Robert Chambers
He declared an emergency, but somewhere along the line the ball got
dropped. The pilot shouldn't have to plead his case and hope for the
best, he's got an emergent condition to deal with and the life of his
crew and passengers to worry about.
When he got stick from the local controller he should have repeated his
emergency declaration and done whatever he needed to do to meet that
situation. A tower controller can clear the airspace of aircraft fairly
expediently if they want to.
If he had flamed out on a wide downwind and not made it back to the
runway he'd have been crucified for "not doing everything in his power
to deal with the emergency"
If I were the pilot, and AA, I'd be plenty ****ed at the controller, and
from what else is coming out, the FAA supervisor who makes the decisions
that the local controller is not allowed to.
Hopefully this won't happen again eh?
7700 doesn't add anything to the situation. The 7700 stuff is for
when you're out of radio contact.
controller would still have known something was seriously wrong.
off that code at some point, but we don't even know from the video
Old February 24th 07, 02:17 AM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
No **** Dick Tracy.
Old February 24th 07, 02:37 AM posted to rec.aviation.ifr
Mitty
All true. BTW, the handoff on the video is between Center and Approach. Center
told the pilot that he was going to request 17C from Approach and that's what he
did. Apparently without mentioning the emergency.
On 2/23/2007 7:25 PM, Robert Chambers wrote the following:
squawking 7700 doesn't add anything to the situation. The 7700 stuff
is for when you're out of radio contact.
wasn't mentioned in the handoff (which it possibly wasn't) then the
next controller would still have known something was seriously wrong.
switch off that code at some point, but we don't even know from the
Old February 24th 07, 02:58 AM posted to rec.aviation.ifr
Matt Whiting
C J Campbell wrote:
On Fri, 23 Feb 2007 05:41:03 -0800, Sam Spade wrote
(in article ):
http://www.kvue.com/sharedcontent/Vi...dId=122817&cat
Id=104
It appears somebody forgot what pilot in command means.
Actually, at least two people forgot.
Matt
Old February 24th 07, 04:23 AM posted to rec.aviation.ifr
Roger[_4_]
http://www.kvue.com/sharedcontent/Vi...2817&catId=104
Doesn't that give you a warm fuzzy feeling?
www.rogerhalstead.com
Old February 24th 07, 01:17 PM posted to rec.aviation.ifr
Sam Spade
Not exactly.
Handling Characteristics of the Flight Design CTSW John Piloting 9 March 14th 07 03:38 AM
American Flight 191 - Recovery Procedure Rick Umali Piloting 17 November 5th 06 03:35 AM
Angel Flight fuel discounts John Doe Piloting 4 January 20th 06 01:24 PM
Passenger attempts to hijack American Eagles flight C J Campbell Piloting 5 January 11th 04 04:04 PM
American Safety Flight Systems seat belts -- Help! Paul Millner Owning 1 July 7th 03 10:10 PM
