Instrument departure, non-IFR airport
Old March 2nd 07, 02:23 PM posted to rec.aviation.ifr
Sam Spade
Default Instrument departure, non-IFR airport
Steven P. McNicoll wrote:
On Mar 2, 3:56 am, Sam Spade wrote:
If controlled airspace was not involved you could do what you want.
But, the rub comes in them providing you a clearance into (presumably
1200-foot floor Class E airspace without some procedure that assures
obstacle clearance until reaching the minimum IFR altitude.
Why is that a rub?
The issue of no FAA procedure to provide obstacle clearance below the
MIA once entering the Class E 1200-foot floor area.
Old March 2nd 07, 03:15 PM posted to rec.aviation.ifr
Mark Hansen
On 03/02/07 05:11, Steven P. McNicoll wrote:
On Mar 1, 11:51 pm, wrote:
Recently I tried to depart from an non-tower airport that has no
instrument approach procedure, and hence no instrument departure. I
was told that I could not get a clearance on the ground, even with
VIFNO etc., and that I would have to depart VFR and pick my clearance
up while airborne. The recommendation made to me by both TRACON and
local FSDO for departing IFR with a low ceiling was to get a special
VFR clearance into the towered airport 6 miles away [which has an
approach and then depart IFR from there.
My question is, if I take responsibility for staying away from the
rocks [assume a low ceiling, above the tops of small hills, but below
minimum vectoring altitude], shouln't I be able to get a clearance on
the ground?
What's VIFNO?
Google says: "Void IF Not Off by".
Did they say why they couldn't issue a clearance while
you were on the ground? It's not prohibited by FAAO 7110.65.
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old March 2nd 07, 03:53 PM posted to rec.aviation.ifr
On Mar 2, 5:11 am, "Steven P. McNicoll"
the ground?
What's VIFNO? Did they say why they couldn't issue a clearance while
VIFNO = Void if not off by [sorry- old habits...]
Some specfics will be helpful now: the airport is Flabob, KRIR, field
elevation 764 MSL. I spoke with several folks and each seemed to
have a different take. The TRACON controller was the most helpful/
sympathetic; he told me his Minimum Vectoring Altitude in that area is
3200 [in addition to a small hill off the departure end of RWY 24
there are taller rocks to the North]. I heard from both the
controller and local pilots that zero-zero departures used to be
permitted until about 2 years ago and since then clearances while on
the ground have been unavilable. Now the airport is only 10 NM SE of
Ontario...so I'm guessing that my IFR departure off Flabob negatively
impacts their inbounds into ONT until they have identifed me on radar
or I'm through the MVA. I have suspected this is the funcamental I'm
not permitted a clearance and that until 2 years ago there may have
been a Letter of Agreement between ONT tower and SoCal departure that
permitted Flabob IFR departures. If so, am I not getting a raw deal
on "first come, first, served"?
BTW, the FSDO guy was the least helpful: "No instrument departure, no
clearances on the ground." When I protested that this was clearly in
error he just repeated what he said, adding some impatient attitude.
That was the end of that conversation.
Old March 2nd 07, 03:54 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
But why is that a rub? Obstacle clearance is the pilot's
responsibility, it's not a concern to ATC.
Old March 2nd 07, 03:59 PM posted to rec.aviation.ifr
On Mar 2, 5:41 am, Michelle P
the ground?
Alan, PP-AMEL-IA
What was your point of departure on your Flight plan. The Non-IFR
airport or a IFR fix?
Michelle
The non-IFR airport- KRIR.
Old March 2nd 07, 04:04 PM posted to rec.aviation.ifr
On Mar 2, 9:15 am, Mark Hansen wrote:
What's VIFNO?
FAAH 7340.1 says CVINO
Old March 2nd 07, 04:31 PM posted to rec.aviation.ifr
Sam Spade
You would have to ask the TARCON and FSDO the original poster dealt with.
Old March 2nd 07, 04:35 PM posted to rec.aviation.ifr
Mark Hansen
What's VIFNO?
You asked what he meant and I told you.
Sheeesh.
Old March 2nd 07, 05:02 PM posted to rec.aviation.ifr
Runway 24 takes you into the KRAL Class D almost immediately. I am sure
no one likes that when they can't see you.
Runway 6 is pointed towards terrain that causes the MVA to rise to 4000
quite close-in. The airport is in a terrible location both airspace and
terrain-wise for IFR procedures. If you takeoff on 6 not only do you
have a terrain problem there is an issue of the Ontario Class C with a
floor of 2700 in that area, below any MVA.
The issue witih KRAL is a non-issue as far as my question is
concerned. There are many cases in which multiple towered airports
are near each other and you can still get an IFR departure; both
Northern and Southern California have many examples: SFO and SQL, HWD
and OAK, SJC and RHV, HHR and LAX. The TRACON works it out; that is
part of their job.
Regarding terrain: I'm talking about a departure off 24 with a
ceiling high enough to see and avoid all obstacles which, in any
event, is not or should not be ATC's issue. I don't think either of
these concerns is the cause of the issue here.
Departure procedures notice Jim Macklin Instrument Flight Rules 12 January 27th 07 02:57 PM
Fedex Departure (MCO) Glen in Orlando Aviation Photos 0 November 29th 06 11:13 PM
Alternate same as departure? dlevy Instrument Flight Rules 34 December 11th 04 01:15 PM
Uncontrolled airport departure-again... endre Instrument Flight Rules 13 March 1st 04 12:42 AM
gliding back to your departure airport Harold Piloting 34 October 24th 03 11:12 PM
