Alternator whine
Old March 13th 07, 12:39 PM posted to rec.aviation.owning
Darrel Toepfer
Default Alternator whine
"RST Engineering" wrote:
but I've got this friend Ernie ...
Thats my dad... GRIN
Old March 13th 07, 04:12 PM posted to rec.aviation.owning
On Mar 12, 6:17 pm, "Travis Marlatte"
"RST Engineering" wrote in message
A coup'la questions & comments:
1. Why would you disconnect the battery to replace the alternator?
I suspect it was in an attempt to reseat all connections that could
contribute to the problem. I had already done this as well as "moving" all
of the alternator mounting bolts. I didn't try any magic juice, however.
2. One presumes certain basic troubleshooting procedures prior to
throwing parts at the problem, like back all heavy nuts grounding the
alternator, squirt in a little magic juice, and retighten.
I'll emphasize that I did my own diagnosis and concluded that it was an open
diode. I took it to the shop not to have them diagnose but to swap the
alternator - which they did quite well and it (or the process of doing it)
solved the problem.
Travis
Lake N3094P
PWK
We once had an alternator whine in a 172. The alternator
wasn't the problem; there was a ground loop somewhere. After messing
endlessly with ground straps and filters and other connections, I
finally got fed up and ran the alternator using our table saw motor--
wheeled the saw up to the front of the airplane and used the belt to
spin the alternator while I got under the panel wearing the headset
and used a jumper to try grounding/ungrounding various jack points.
Managed to minimize the whine by moving a groundpoint to a point where
a bunch of other avionics grounded. Old airframes develop resistances
at riveted joints, causing a voltage drop across certain components
and introducing noise that's supposed to be filtered out in the radios
or audio panel. I think. Anyway, it worked.
Dan
And the Faggot Left continues to whine and Snivel T Bird Naval Aviation 1 June 13th 05 08:31 PM
Alternator field cycling & alternator damage Nathan Young Owning 7 November 14th 04 09:02 PM
q alternator 152 Euromotors Piloting 2 July 16th 04 09:34 AM
Japanese Whine Over Enola Gay Display [email protected] Military Aviation 42 December 19th 03 11:32 PM
Electric whine in the light circuit - Help Victor J. Osborne, Jr. Owning 1 July 29th 03 11:36 PM
