Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
FS Aviation trash (or treasure)
Old January 16th 05, 08:31 AM
Default FS Aviation trash (or treasure)
http://webs.lanset.com/aerorv for those not using HTML to see images
Hangar Debris
Ignore this Kern 32 thing he holds no rank
Miscellaneous aviation related articles for sale
I will ad items to this page as they come up so if you have already been
here be sure to refresh your brouser
1/15/2005
Email link on the website
Click on links for pictures, additional pictures available on request.
Engine and rotor tachometer, $250 3.125 in diameter. Complete system new
dual scale Westach brand.
(best suited to four cycle engines and rotor systems over 20 feet in
diameter for helicopter use or gyroplanes)
See pictures for details Tachometer face
MA-4 Marvel Shebler metal float carb $350
Model# MA4 ASP A Serial #A-5-6016 PART #10-3678-32 For Lycoming O-320
Jetranger vertical fin beacon, Red ( no power supply) $25
Of course you can put this on any civil aircraft but as removed from
Jetranger L3
two rolls of engine baffle material, $21
This is two rolls, one has had 18 inches removed for a project so is 7.5
feet long. The other is a full 9 feet long by 2 inches
Prop extension $175
4 inch SAE 2 Prop extension (Lycoming) $225 with two sets of Prop bolts
Mini-500 clutch (Stitt supplied) balanced $500
Add $50 for belt
Retractable shoulder harness for Mini-500 $50
Air Speed Indicator $50
Lighted knots Airspeed indicater 40-200 Knots
Tailrotor Gear box $500
For Mini-500 14 HTTSN however has some output shaft runout. Otherwise seems
perfect and would be still much cheaper to straighten shaft or replace shaft
than build new from billit. Will provide detailed images on request
Prop spinner for Lycoming $125.
SAE 2 prop hub. Maximum 3.500 inches thick at hub, takes a two bladed metal
propspinner is12" Dia 12" long .
PMA stamp faded but believed to be from a PA-24
Mini-500 seat $25.
photo on request
Rotax 582 DCDI LC complete with radiator,hoses,header tank from a MINI-500
helicopter
I have a Rotax 582 grey head with 75 hours TTSN including Radiator and PEP
package, price $3500 with clutch $3K without. Will trade for a running low
time Solar T62-2A1 or considering a Tiernay TT-10 Turbine Starter cart.
David Clark H10-37 helicopter headsets $150 for pair
pair 1 set is perfect the other set needs a new cable and both have NEW
Oregon Aero Seals (soft leather) that are far superior than any gel seals. I
use these seals on my ANR headsets to prevent feedback and to provide
comfort.
CASH & Carry
(Mini-500, not Studebaker) click links below to view full size image
NOTE: The skids on this helicopter are 14 inches shorter than a stock
Mini-500. They span 48 inchs
NOTE: I will sell the balanced clutch and pully assembly for $500 belt for
$50 more. Belt seperately $100
This helicopter has 75 hours TTSN , Clutch is 38 HTTSN No damage history
however the mast mods to the airframe still need to be welded on the inside
the frame rails in the front. If you really sweet talk me I may sell some
other parts
I have Tail rotor gearbox/swash plate assembly less Tail rotor. Has some
runout of shaft on the output shaft $500. detail images on request. Serial
no. 413
Mini-500 airframe for sale
What is in the photos only $1000. 5 images
A B" C" D" E"
I have a few Formsprag free wheeling (Sprags, actually these are Roller Ramp
clutches) units specs on request $100 outright plus ($10 USA only) shipping
@ 7 lb UPS from 95815 .
Note: This page changes at any time (my mind does the same) . I never know
what is going to be here the rest of the day.
Old February 10th 05, 02:19 AM
Interstara
Jim,
Get back to me on the 3678-32 Carb please
AL
FS aviation treasure or trash Jim Aviation Marketplace 1 January 10th 05 02:25 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 12:55 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 11:43 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide Aviation Marketplace 1 January 13th 04 09:26 PM
