Anyone fly into Stafford on an IFR flight plan? I'm planning on going there
this weekend and I was wondering if there were special procedures considering it's so close to the ADIZ. Do IFR flights keep their squawk until touchdown just in case? I'm coming from the NY area. I'd appreciate any feedback on the cleared route from the northeast. Do they normally route you around the ADIZ or just around the FRZ? Thanks, Marco |
There is a handout on the AOPA web site for flying near in and around the DC
ADIZ http://www.aopa.org/whatsnew/newsite...1403_check.pdf Also check out the online training program at FAAST http://faasafety.gov/gslac/ALC/cours...?categoryId=11 BT "Marco Leon" wrote in message ... Anyone fly into Stafford on an IFR flight plan? I'm planning on going there this weekend and I was wondering if there were special procedures considering it's so close to the ADIZ. Do IFR flights keep their squawk until touchdown just in case? I'm coming from the NY area. I'd appreciate any feedback on the cleared route from the northeast. Do they normally route you around the ADIZ or just around the FRZ? Thanks, Marco |
Anyone fly into Stafford on an IFR flight plan? I'm planning on going there this weekend and I was wondering if there were special procedures considering it's so close to the ADIZ. Do IFR flights keep their squawk until touchdown just in case? I'm coming from the NY area. I'd appreciate any feedback on the cleared route from the northeast. Do they normally route you around the ADIZ or just around the FRZ? There aren't any special procedures I know of. First, the ADIZ is transparent to IFR fliers, so you should have little to worry about there. Depending on how you enter the ADIZ, you'll likely get the "Grand Western Tour" or the "Eastern Shore Tour" around the FRZ and away from KBWI/KIAD traffic. I've actually gotten routed directly over KIAD/AML twice in the last six years, so it is possible. ![]() If you're at all concerned about go-arounds or missed approaches getting you anywhere near the ADIZ boundaries, just keep your code until you're down or cancel on the ground. (Also, as you probably know, flights into ADIZ airports do keep their squawk until on the ground.) -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
"John T" wrote in message:
There aren't any special procedures I know of. First, the ADIZ is transparent to IFR fliers, so you should have little to worry about there. Depending on how you enter the ADIZ, you'll likely get the "Grand Western Tour" or the "Eastern Shore Tour" around the FRZ and away from KBWI/KIAD traffic. I've actually gotten routed directly over KIAD/AML twice in the last six years, so it is possible. ![]() If you're at all concerned about go-arounds or missed approaches getting you anywhere near the ADIZ boundaries, just keep your code until you're down or cancel on the ground. (Also, as you probably know, flights into ADIZ airports do keep their squawk until on the ground.) Thanks John. I've flown into airports within the ADIZ already but RMN is a bit weird in that it butts up right against the ADIZ. I have visions of having to do an extended pattern or something then inadvertently clipping the ADIZ. Your recommendation of keeping the squawk code is a good one. Thanks. Marco |
Thanks John. I've flown into airports within the ADIZ already but RMN is a bit weird in that it butts up right against the ADIZ. I have visions of having to do an extended pattern or something then inadvertently clipping the ADIZ. Your recommendation of keeping the squawk code is a good one. Thanks. FWIW, locals tend to keep the ADIZ squawk for a few miles when leaving the ADIZ - even if ATC comes confirms we're outside. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
... FWIW, locals tend to keep the ADIZ squawk for a few miles when leaving the ADIZ - even if ATC comes confirms we're outside. I actually did just that and kept my squawk until I landed. I figured it can't hurt and only help. As an aside, the routing they gave me to RMN was changed to a shortcut with a direct-to to Nottingham (OTT). It put me *very* close to the FRZ. I had my Garmin 496 with the XM-provided TFR data so I had the equipment to stay clear but I requested a slightly better vector anyhow to be sure. I also wanted it on record that I was cognizant of the FRZ in case anything gets screwed up. Thanks for the tips John. Marco |
| Thread Tools | |
| Display Modes | |
| Lancair down near Stafford | Wiz | Piloting | 7 | February 25th 06 08:30 PM |
