Single engine CV trap
Old June 2nd 07, 12:07 AM
Larry Cauble Larry Cauble is offline
Junior Member
First recorded activity by AviationBanter: Aug 2005
Default Single engine CV trap
Twin engine aircraft have been operating routinely from USN carriers for nearly sixty years now. The earliest to routinely operate was the AJ Savage, (which actually had three engines, of course), I guess. The F2H was in the Fleet about that time as well - 1950ish. (I figure the F7F doesn't count since as far as I know no squadron ever deployed on a cruise.)
Anyway...
Has any twin-engine aircraft been authorized (per manual or NATOPS) to land with an engine inoperative? Has any twin-engine aircraft ever landed aboard with an engine out?
Old June 2nd 07, 05:47 AM posted to rec.aviation.military.naval
John Weiss[_1_]
"Larry Cauble" wrote...
Don't know of one off hand that has NOT!
A-6, E-2, F-4, F/A-18...
Old June 3rd 07, 01:38 AM
Junior Member
So when an A-6, F-4, F-14 or F-18 with one engine out lands, is it into the barrier like the props?
Old June 4th 07, 02:15 AM posted to rec.aviation.military.naval
John Weiss[_1_]
In general, no. The pilot will usually get a couple chances to make a normal
approach and landing. However, bad weather may dictate the barricade for the
first try.
Old June 3rd 07, 04:17 PM posted to rec.aviation.military.naval
TV
Any done at night? THAT would be a superman story!
TV
Old June 4th 07, 01:13 AM posted to rec.aviation.military.naval
Allan Rypka
I have one each S2 and S3 trap with one out, the S3 trap was at night.
Neither case had the barrier rigged. Neither was a particular problem.
In the case of the S3, the a/c was a bit more sensitive to glide slope
control since the operating engine was at much higher power than either
engine if both were operating.
Allan Rypka
VS 38, VS 22, VS 41
TV
Old June 4th 07, 10:23 PM posted to rec.aviation.military.naval
Charlie Wolf
On Fri, 1 Jun 2007 20:47:11 -0700, "John Weiss"
Also S-3A/B. Bingo was always preferred if available, however, the
S-3 had a fairly decent single engine profile. I don't recall ever
rigging the barricade for a single engine S-3.
Regards,
Old June 5th 07, 05:04 AM
Junior Member
Thanks, all. I woulda figured a higher pucker factor.
Just another day at the office!
ATP wants a single engine add on Emily Piloting 33 September 22nd 06 12:06 AM
Working on the ideal single engine tug! TugMan Piloting 13 June 9th 06 01:37 AM
single engine owner? [email protected] Owning 0 May 31st 06 11:47 PM
Single-engine plane with the best range? Bob Piloting 24 February 25th 04 05:52 PM
Is taking off on single mag bad for engine flyer Home Built 10 September 21st 03 10:43 PM
