VW Conversion
Old June 2nd 07, 05:56 AM posted to rec.aviation.homebuilt
Default VW Conversion
To All:
I've uploaded some of the HVX drawings & photos to my blog.
(bobhooversblog.blogspot.com)
-R.S.Hoover
Old June 2nd 07, 04:42 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Fri, 01 Jun 2007 20:56:46 -0700, "
To All:
-R.S.Hoover
Bob
when you do a conversion what do you do to get all the oxide off the
crankcase? the case I'm looking at converting is oxided a dark grey.
I'd like to get it all clean again before painting it. ...without
stuffing it up.
Stealth Pilot
Old June 2nd 07, 06:26 PM posted to rec.aviation.homebuilt
On Jun 2, 7:42 am, Stealth Pilot
crankcase?
Trick question, right? (Most conversions begin with a new crankcase.
No corrosion.)
stuffing it up.
Dark gray may not be bad. (It depends on the corroding elements.) A
good de-greasing followed by a good scrubbing with a detergent having
a neural pH, followed by a boiling-water rinse, may be all you need
before painting.
A wash with dilute phosphoric acid, ideally with chromate extenders,
will brighten the surface. It produces a black phosphate residue in
doing so that must be removed. You won't see the black stuff if you
scrub-on the phosphoric with a paint brush cut down to make the
bristles stiffer, but it will show up if you just allow the thing to
sit.
But if there is any corrosion due to salts you'll probably have to
boil the case to get rid of the salt before you can address the
corrosion.
Worse-Case: (Old, salvaged bus engine.) Degrease, wash, then blast
with crushed walnut shells.
There are commercial products available specifically for prepping
magnesium alloys. Some customers include the surface-prep & finish
specs in their order. But some of that stuff costs the earth and I
frankly haven't seen much difference compared to the methods I use.
I'm not a chemist but the dividing line would seem to be between
simple oxidation of the surface, which does not alter its heat-flow
properties and which may be painted without further prep, and
destructive corrosion that etches the parent metal and produces
various crusty-looking residues that act as thermal insulators.
Removing the SYMPTOMS of such corrosion does not address the cause and
painting over the apparently clean surface ensures the corrosion will
re-appear.
I know that sounds sorta wishy-washy but there is some overlap between
the types of 'corrosion.' On old/used crankcases I usually do a few
tests before deciding which surface-prep procedure to follow.
Since paint itself acts as an insulator, use the thinnest coat
possible. And NEVER use any 'high temperature' paint, such as that
advertised for wood stoves, barbeques, exhaust pipes or what-have-
you. Such paints get their hi-temp qualities from clays or metallic
salts and are excellent thermal insulators.
-R.S.Hoover
PS -- A boat yard can usually point you toward products containing
phosphoric acid meant to prep non-ferrous alloys for paint. Ditto for
a good paint store that deals with aluminum siding and window
screens.
Old June 3rd 07, 12:36 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 02 Jun 2007 09:26:40 -0700, "
crankcase?
No corrosion.)
appreciate the details bob. sorta what I thought.
no trick question. the engine is a 1600vw intended for a non aerobatic
open cockpit druine turbulent. it comes out of a vw varian.
I'll be using something like ian peacock's PFA conversion details.
1600 is enough power for the turbulent. there is a 20 year history of
using these engines in turbulents in england.
I've been dithering for weeks whether I'd bolt the halves back
together, tape up all the port faces and lightly bead blast the outer
faces of the block.
The paint I'm going to use is tempo aircraft engine enamel in the
rattle cans.
stop thinking. just get on and do it.
Stealth Pilot
Australia
Old June 3rd 07, 08:43 PM posted to rec.aviation.homebuilt
On Jun 3, 3:36 am, Stealth Pilot
faces of the block.
I've had mixed results using beads -- glass and phenolic -- on
magnesium, in that specs of corrosion would appear after six months or
so. With walnut shells, I've had engines come back through the shop
after many years with the original paint intact.
rattle cans.
Probably over-kill.
See if you can find a junked VW crankcase -- real junk; totally
unusable. Clean small areas using different methods; paint with
different paints. Keep good notes. Throw it out back of the shop
where the weather can get at it. Check it every now & then, and
update your notes. (Ditto for steel, WOOD(!), fibergals, aluminum and
so forth.) I think you'll be surprised at how well some of the
traditional methods/finishes hold up.
-R.S.Hoover
cub to sua conversion Tuno Soaring 2 March 23rd 07 01:23 PM
LS-4 to LS-4a conversion Dan Peters Soaring 1 September 1st 06 02:29 AM
LS-4 to LS-4a conversion Dan Peters Soaring 1 August 29th 06 07:50 AM
Need Information To Do A 150 Hp Conversion On My C-150 spar Owning 25 March 3rd 05 04:21 PM
Need Information To Do A 150 Hp Conversion On My C-150 spar Restoration 23 March 3rd 05 04:21 PM
