VFR "picking his way thru" heavy cells with XM Radio weather
Old June 6th 07, 11:51 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default MXSmanic, fjukktard incarnate.
Mxsmanic wrote in
Marco Leon writes:
The more I fly, the more I believe that the body of pilots that
regularly do things that most will consider "stupid pilot tricks" is
larger than what many people think.
I think that body of pilots is quite large. It has to be, in order to
explain the relatively poor safety statistics of GA. Add poor
maintenance to that, and GA becomes pratically dangerous. And it
doesn't have to be.
How would you know, moron. You don't fly.
As the Italian lady said to the pope after his latest dissertation on birth
control..
You no playa da game, you no makea da rules.
Bertie
  #72
Old June 7th 07, 03:12 AM posted to rec.aviation.piloting
Dan Luke
Default VFR "picking his way thru" heavy cells with XM Radio weather
"Peter R." wrote:
What concerns me are those days where t-storms seem to be popping up
everywhere and returns go from light to intense in 15 minutes or less. In
those cases this relatively slow refresh rate makes flying through that zone
a bit of a butt clencher.
Indeed.
Experience and caution are necessary components in making optimum safe use of
the tool. After a while one develops a sense of what the NEXRAD is saying.
The time sometime comes when discretion is the better part of valor, and a
land-and-wait decision becomes the prudent course. However, since I've had XM
weather I've had a lot better information on which to base that decision, and
I've only had to make it once.
Dan
? at BFM
  #73
Old June 7th 07, 05:31 AM posted to rec.aviation.piloting
Jose
know
Thanks. I thought you were commenting on the lack of Japanese theater
in the cockpit.
Jose
There are two kinds of people in the world. Those that just want to
know what button to push, and those that want to know what happens when
they push the button.
  #74
Old June 7th 07, 12:09 PM posted to rec.aviation.piloting
Dan Luke
"Montblack" wrote:
As to the "stale" business, in 200+ hours of using the product in the most
thunderstorm-infested region of the U. S., I have found 6-8 minute maximum
lag a non issue for avoiding CBs.
RV-10: Cruise Speed .....200 (3+) miles/minute
OK, rub it in. Poor ol' Delta was doing the best she could.
Anyway, I'm beyond the reach of RV-10 temptation now. The deal for my next
airplane is almost done.
"It's like he flew right into the storm, as if he didn't no that it was
there," one witness reported. g
If the witness could see it, why couldn't the pilot?
Dan
? at BFM
  #75
Old June 8th 07, 12:43 AM posted to rec.aviation.piloting
Morgans[_2_]
next airplane is almost done.
Man, you can't leave us hangin' like that! What kind of airplane?
  #76
Old June 8th 07, 02:24 AM posted to rec.aviation.piloting
Dan Luke
T182T
Dan
? at BFM
  #77
Old June 12th 07, 11:58 AM posted to rec.aviation.piloting
George Graham
On Jun 4, 12:21 pm, "Peter R." wrote:
I was listening to LiveATC.net's feed of Syracuse, NY, yesterday (Sunday)
Thank you Peter, for introducing a neat web goodie!
After listening to the inflight, and reading some posts here, I am
amazed at your point of view.
As I see it, the controller is the dummy with his his head stuck up
his rear. How can you work full time in this business, and not know
what XM is ?
The controller got nervous by looking at his radar, when the pilot
(who said that he was IFR rated) had his window to look out.
Unsafe ? The pilot is using modern technology to overcome a problem
with ATC, they usually don't offer advice, and will let you fly right
into the soup without warning. Anyway, that is how I see it.
  #78
Old June 12th 07, 03:19 PM posted to rec.aviation.piloting
Peter R.
what XM is ?
I don't know this controller personally, but I fly into and out of SYR twice
to three times every week since 2002 and I know he is no dummy over the air.
My take on this? This is probably the controller's first experience in
dealing with a pilot who continually admitted that he was using the guidance
of his XM weather over the controller's weather assistance to avoid what
appeared to be extreme weather in the aircraft's path.
Recall also that a) XM weather is a relatively new concept, having only been
available for the last two years or so and b) most controllers including this
one are not pilots and therefore are not aware of the latest technology to
grace the GA cockpits.
You will note in the audio clip that at one point the controller reads the
latest ATIS at the airport and visibility was reported at 3 miles in haze.
The airport was perhaps 20 miles east of the pilot's location with no
significant geographical differences between it and the aircraft's location.
At another point the controller asked the pilot for the conditions and the
pilot reported visibility at 5 to 10 miles. Between the ATIS and the pilot's
admission to visibility starting at 5 miles, I think for discussion purposes
it is safe to assume that visibility was less than 10 miles.
Yes, the pilot certainly had his window as the primary weather avoidance tool
but it was a very hazy day and the first weather call by the controller
reported extreme weather 8 miles directly ahead, arguably out of the pilot's
sight at that point in the clip.
Unsafe ? The pilot is using modern technology to overcome a problem with ATC,
Based on my understanding and as a WSI downlinked weather customer and IFR
pilot myself, I was pointing out that XM NEXRAD (that which is displayed on
the pilot's Garmin 396) can be up to 9 minutes old, or perhaps even older
(*). This "modern technology" is *not* without limitations. Nine minute old
NEXRAD data will mislead a pilot into believing a strong cell is in one
location when in fact that cell has moved up to 10 miles from that point.
This difference should be enough to support the contention that downlinked
NEXRAD weather is NOT a tool for tactical weather avoidance, as this pilot in
the clip admitted using as such ("picking my way through").
Approach facilities like SYR have weather radar that is much more real-time
than nine minute old NEXRAD data. Why would a pilot fail to use ALL
information available to him and decline controller provided weather
deviations/recommendations, as this pilot seemed to be doing in this clip by
stating that he had his own weather?
(*) note in the clip that the pilot stated that XM NEXRAD could be up to 18
minutes old, which I incorrectly quoted previously in this thread as 8
minutes. If this is really the case, then 18 minute old data may as well be
yesterday's NEXRAD as far as using it as a tool to "pick" your way through a
line. No pilot who strives to avoid thunderstorm penetration would rely on 18
minute old data to circumvent cells.
Come on. Think about that above statement for a moment. Had you used
"thunderstorms" instead of "soup" you might have had an argument because
there are documented accidents where controllers failed to call out
thunderstorms in the paths of aircraft, but soup? Outside of the airport's
ASOS/AWOS/human observation, controllers have no idea whether every mile
within their airspace is IMC or VMC. Keeping an aircraft out of the "soup" is
simply not a service provided by ATC.
In any event, your point is moot in this example. The controller *was*
attempting to offer weather avoidance services using radar that was much more
current than XM NEXRAD.
Peter
  #79
Old June 12th 07, 05:18 PM posted to rec.aviation.piloting
B A R R Y[_2_]
I was thinking the controller understood how XM worked, and wanted to
see if the pilot was aware of the delays and limitations vs. actual
radar. He then trying to offer additional information, but he can't
force the pilot to use it.
  #80
Old June 12th 07, 06:26 PM posted to rec.aviation.piloting
Peter R.
The old, "give him enough rope with which to hang himself," or in this case
get the pilot to back into the conclusion that there actually is a
limitation. Yep, I could see the controller having that hidden agenda, too.
Peter
Radio "Squelch-type" Noise Kensandyeggo Owning 7 April 12th 06 07:20 PM
jeppesen "aviation weather" book Mike Instrument Flight Rules 0 March 26th 06 08:09 PM
