Flap Settings
Old July 10th 07, 05:49 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
Default Flap Settings
I understand, a wing will perform optimally when the flap is set at
the proper angle for the airspeed ... any mismatch of flap to airspeed
will result in some performance losses vs. the correct setting. Of
course, we have a couple of compromises here ... the flaps are set at
fixed increments and the airspeed varies continuously ... so by
design, you will rarely have the flap and airspeed matched up
perfectly.
I remember seeing a story where one of the German schools modified an
LS-3 with springs, etc. so it automatically put in the correct amount
of flap for the airspeed ... did this result in a measurable
improvement?
Along the same lines, I have heard some pilots say they put the flap
in a position where they feel no pressure ... does this work?
I myself tend to go negative quicker or maintain a negative setting
longer ... then pulling in positive flap ... thinking being too
positive is more costly then too negative ... is this valid?
KK
Nav radio settings in FMC Mxsmanic Piloting 5 January 10th 07 09:39 PM
Warrior cruise RPM settings lardsoup Piloting 35 October 10th 05 12:59 AM
Altimeter settings: QNH versus QFE stephanevdv Soaring 25 June 7th 05 09:06 AM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 09:07 PM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 05:14 AM
