All,
My flying club has a 98 Cessna 182. Unfortunately, the yoke mounted chart clip is in the way of the standard Garmin 396 mounting bracket. This chart clip is not removable easily enough that I'd want to remove and re-mount it everytime I fly (it's a shared aircraft... If it were mine, I'd just permanently remove the thing.) I am considering the purchase of a RAM mount "RAM-B-121-GA7". Does anyone have any experience with this thing on Cessna Yokes? Can I come _under_ the yoke with the bracket? Do I need to order any accessories to make it work, or will that part # include everything I need? This might work good on the Comanche yoke also, since I have to have the GPS slightly tilted due to the full crossmember at the top of the yoke, and AP disconnect/PTT "plate"... Unfortunately, my local shop does not have the RAM part in stock, and it's a little difficult to know for sure what to order on something like this if you can't lay eyes on it. Any advice is welcome. Thanks, Dan |
In article om,
Dan wrote: I am considering the purchase of a RAM mount "RAM-B-121-GA7". Does anyone have any experience with this thing on Cessna Yokes? Can I come _under_ the yoke with the bracket? Do I need to order any accessories to make it work, or will that part # include everything I need? I use the suction cup mount and attach it to the side of the windscreen. This brings it up and closer to eyelevel and into my line of sight as I look outside. |
Not quite the same, to be sure, but here are solutions for the Cub: www.pipercubforum.com/garmin.htm I rent, so for me the G Force suction cup has been the solution. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 from HarperCollins on August 21 www.flyingtigersbook.com |
I've used a suction cup mount for several years, and it mostly works
fine. However, it has fallen off a couple of times. I would hate for that to happen in the middle of an ifr approach so am looking for an alternative. |
In article .com,
Paul kgyy wrote: I've used a suction cup mount for several years, and it mostly works fine. However, it has fallen off a couple of times. I would hate for that to happen in the middle of an ifr approach so am looking for an alternative. As long as you keep it wet, it will stay in place. On a hot day, it may be possible for the water between the window and the suction cup may evaporate. |
Don't know if this is comparable or not. I have a 296 and fly a rented
Cessna 152 or 172. I have a beanbag bracket which just sits on top of the dash and holds it. It's very secure, has never fallen off, and I can use it on what ever I'm flying. Martha "Dan" wrote in message ps.com... All, My flying club has a 98 Cessna 182. Unfortunately, the yoke mounted chart clip is in the way of the standard Garmin 396 mounting bracket. This chart clip is not removable easily enough that I'd want to remove and re-mount it everytime I fly (it's a shared aircraft... If it were mine, I'd just permanently remove the thing.) I am considering the purchase of a RAM mount "RAM-B-121-GA7". Does anyone have any experience with this thing on Cessna Yokes? Can I come _under_ the yoke with the bracket? Do I need to order any accessories to make it work, or will that part # include everything I need? This might work good on the Comanche yoke also, since I have to have the GPS slightly tilted due to the full crossmember at the top of the yoke, and AP disconnect/PTT "plate"... Unfortunately, my local shop does not have the RAM part in stock, and it's a little difficult to know for sure what to order on something like this if you can't lay eyes on it. Any advice is welcome. Thanks, Dan |
"Russ and/or Martha Oppenheim" wrote: Don't know if this is comparable or not. I have a 296 and fly a rented Cessna 152 or 172. I have a beanbag bracket which just sits on top of the dash and holds it. It's very secure, has never fallen off, and I can use it on what ever I'm flying. You don't fly in much turbulence, do you? Even the suction cup mount can come loose when the bumps reach a given level. The most solid mount is the yoke mount, it remains firmly attached during the roughest of rides. |
john smith wrote:
The most solid mount is the yoke mount, it remains firmly attached during the roughest of rides. The yoke mount hits my leg. The best mounts I've seen are Ram mounts. My current installation has the Ram mount clamped to a support brace, holding the GPS slightly above the glareshield at the far left side of the panel. |
B A R R Y wrote: john smith wrote: The most solid mount is the yoke mount, it remains firmly attached during the roughest of rides. The yoke mount hits my leg. The best mounts I've seen are Ram mounts. My current installation has the Ram mount clamped to a support brace, holding the GPS slightly above the glareshield at the far left side of the panel. Check out these mounts. I have one in my Bo. Absolute top of the line quality. http://www.angerole.com/ |
On Wed, 08 Aug 2007 14:39:18 GMT, B A R R Y
wrote: john smith wrote: The most solid mount is the yoke mount, it remains firmly attached during the roughest of rides. The yoke mount hits my leg. The best mounts I've seen are Ram mounts. My current installation has the Ram mount clamped to a support brace, holding the GPS slightly above the glareshield at the far left side of the panel. There's quite the assortment of Ram mounts at http://www.e-mount.com/page_results.php?uid=723 The new one that clamps to the glareshield looks interesting. |
| Thread Tools | |
| Display Modes | |
| Garmin Pilot 3 yoke mount | The Ponderosa | Owning | 1 | December 13th 05 03:30 PM |
| Panel mount for handheld Garmin GPSMap X96 series | Brock Boss | Owning | 2 | September 25th 05 02:26 AM |
| manual for garmin 100 panel mount. | Ray Toews | Home Built | 1 | September 11th 05 11:28 PM |
| Need a Cessna 120 engine mount | Jerry | Aviation Marketplace | 0 | November 28th 04 03:16 AM |
| Good panel mount COM radio and intercom w/push-to-talk? | John Huebbe | Home Built | 10 | November 27th 04 08:58 PM |
