I want to add an aux tank & transfer fuel to main tank with a pump
during flight. I think it makes fuel management easier if the pump transfer close to the engine's burn rate, say 14 gph. I also want the pump to pick up fuel from the top of the aux tank via a tube to the bottom of the tank so no hole below fuel level is necessary. Does that mean I need a "self-priming" pump? What kind of pump should I get? Name & model no.? Oh, it should run on 12V. Many thanks, Robin |
"rmhou at yahoo.com" wrote in message
ups.com... I want to add an aux tank & transfer fuel to main tank with a pump during flight. I think it makes fuel management easier if the pump transfer close to the engine's burn rate, say 14 gph. Here's a recommendation for wiring. Use a timer switch as is used for bathroom fans. It has several advantages: 1. It is not likely to be confused with any other switch. 2. You can set it for an interval which will never overfill your main tank from the aux. 3. You can't forget to turn it off. 4. Your electric pump can transfer fuel faster than, say 14 gph, without a problem. Rich S. |
"Rich S." wrote Here's a recommendation for wiring. Use a timer switch as is used for bathroom fans. It has several advantages: 1. It is not likely to be confused with any other switch. 2. You can set it for an interval which will never overfill your main tank from the aux. 3. You can't forget to turn it off. 4. Your electric pump can transfer fuel faster than, say 14 gph, without a problem. I like the idea. I would want to see an over-ride, as a backup. Bathroom fan switches are "not quite" up to aerospace quality standards. How is this one, too? Put the transfer pump running off of a relay, that is hooked to a "full tank" sensor. Even if you used a timer, like above, it would prevent an over flow situation - if you set the timer for too long, too soon. -- Jim in NC |
"rmhou at yahoo.com" wrote in message ups.com... I want to add an aux tank & transfer fuel to main tank with a pump during flight. I think it makes fuel management easier if the pump transfer close to the engine's burn rate, say 14 gph. I also want the pump to pick up fuel from the top of the aux tank via a tube to the bottom of the tank so no hole below fuel level is necessary. Does that mean I need a "self-priming" pump? What kind of pump should I get? Name & model no.? Oh, it should run on 12V. Many thanks, Robin There is a certain amount of strategy in both designing and using auxilliary fuel systems. Also, I am confident that nearly everything that actually works, and a lot of things that are problematic, are already well known. If you are only tankering fuel due to a price differential, it is not too big a deal; but if you actually need the fuel, then you need some real advice with some real experience to back it up. I have also heard/read that you operated the aircraft differently for that kind of flying. With that in mind, I would strongly recommend that you ask around your local airport(s) and talk to ferry pilots as well as to mechanics in whom they express confidence. Peter Just my $0.02 |
"Morgans" wrote in message
... Bathroom fan switches are "not quite" up to aerospace quality standards. Used the way it should be, failure of the switch shouldn't be a factor. Put the transfer pump running off of a relay, that is hooked to a "full tank" sensor. Even if you used a timer, like above, it would prevent an over flow situation - if you set the timer for too long, too soon. What was that quote about idiots and failures? I can't remember right now but one cannot idiot-proof everything. I think adding a "full tank" sensor would be overkill. The setup in the Emeraude I had (which went in killing the pilot because of completely empty tanks) had a 20 gallon main and a 5 gallon aux tank. When the main got down to half, one would crank the "fan switch" over to it's stop and it would dump the five gallons into the main and then shut off, saving the pump and battery for the next time. A simple setup and one designed to save the pilot's brains from overload so he can deal with the lowering overcast he just flew into. ![]() Rich S. |
... Bathroom fan switches are "not quite" up to aerospace quality standards. Have you ever had a bathroom fan switch failure? That's got to be ugly. Rich (where's the match? hack,hack) S. |
rmhou at yahoo.com wrote:
I want to add an aux tank & transfer fuel to main tank with a pump during flight. I think it makes fuel management easier if the pump transfer close to the engine's burn rate, say 14 gph. I also want the pump to pick up fuel from the top of the aux tank via a tube to the bottom of the tank so no hole below fuel level is necessary. Does that mean I need a "self-priming" pump? What kind of pump should I get? Name & model no.? Oh, it should run on 12V. Many thanks, Robin Dont make this more complicated than it has to be. Fuel pumps work best when they are not SUCKING, but are already primed and PUSH the fuel to its destination. Cars do this best with submerged fuel pumps in the fuel tank. Next best is a pump below the low point of the tank, with a gravity prime. This is more common with small GA aircraft than the submerged pump approach. Think carefully before setting up a situation that requires siphoning fuel with a suction. This is a recipe for vapor lock. As for fuel management, you may find a pump with your flow rate. You can find stuff at automotive sites - Summit Racing, perhaps, but do the job right with AN fittings and rubber-free hoses - teflon lined, etc. What is possibly "easier" is to use a stopwatch and know the flow rate of your tank. Having a timer on the tank pump can make this even less of a hassle, and you can make it transfer, say... 10 gallons with every button press (over time, of course) Dave |
Rich S. wrote:
snip What was that quote about idiots and failures? I can't remember right now but one cannot idiot-proof everything. Probably a variation of "when someone invents an idiot proof device someone else will invent a better idiot. Dan, U.S. Air Force, retired |
I want to add an aux tank & transfer fuel to main tank with a pump during flight. I think it makes fuel management easier if the pump transfer close to the engine's burn rate, say 14 gph. I also want the pump to pick up fuel from the top of the aux tank via a tube to the bottom of the tank so no hole below fuel level is necessary. Does that mean I need a "self-priming" pump? What kind of pump should I get? Name & model no.? Oh, it should run on 12V. Many thanks, Robin To directly address your question: To achieve your goal, use a garden-variety Facet low pressure pump made for carb engines. I'd probably order from Van's since I'm building an RV-7. http://www.vansaircraft.com/cgi-bin/...duct=pump-carb or go to vansaircraft.com & search for 'fuel pump'. Install a restricter in the line from the pump to the main tank; size the orifice by experiment to get the flow you desire. The pump won't care about the restriction. Evidence: there are quite a few H-series 320's flying on low wing homebuilts with only 2 facet electric pumps (orimary & backup) to supply fuel to the carb. If you mount the pump low in the fuselage & reasonably close to the aux tank, it will self prime just fine unless you're talking about a tank that's several feet tall. (Seldom noticed fact: every 2 seat RV I've ever seen has the fuel line above the 1/2 fuel point of the tanks. Look carefully at the fuel selector.) Others have addressed some of the questions not asked. :-) Charlie |
| Thread Tools | |
| Display Modes | |
| fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 01:57 PM |
| Looking for a reversible fuel transfer pump | [email protected] | Home Built | 13 | April 12th 05 10:26 PM |
| Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 06:53 PM |
| Fuel Transfer Placards | Ben Smith | Owning | 22 | October 16th 03 03:32 PM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
