I have an EGT gauge and sensor arrangement that came out of a Jabiru.
I want to install it in my Sonerai. What distance from the Exhaust port should I drill the hole for the sensor probe? |
Generally, not further than 2" from the exhaust port.
Andre wrote: I have an EGT gauge and sensor arrangement that came out of a Jabiru. I want to install it in my Sonerai. What distance from the Exhaust port should I drill the hole for the sensor probe? |
Thanx,
Is it possible to mount it too close? "Jerry Wass" wrote in message ... Generally, not further than 2" from the exhaust port. Andre wrote: I have an EGT gauge and sensor arrangement that came out of a Jabiru. I want to install it in my Sonerai. What distance from the Exhaust port should I drill the hole for the sensor probe? |
Hey, Andre, was the Dyno mount too complicated---It's only useful to compare
changes in carb, timing, different props, etc. Andre wrote: I have an EGT gauge and sensor arrangement that came out of a Jabiru. I want to install it in my Sonerai. What distance from the Exhaust port should I drill the hole for the sensor probe? |
Hey Jerry, I'm still in the planning stages.
I'm busy constructing my engine mount for my engine overhaul and my plan is to modify this engine mount with the necessary bearings etc. so that it serves the dual purpose as my out of aircraft working engine stand as well as a Dyno to see the effects of my efforts. "Jerry Wass" wrote in message ... Hey, Andre, was the Dyno mount too complicated---It's only useful to compare changes in carb, timing, different props, etc. Andre wrote: I have an EGT gauge and sensor arrangement that came out of a Jabiru. I want to install it in my Sonerai. What distance from the Exhaust port should I drill the hole for the sensor probe? |
| Thread Tools | |
| Display Modes | |
