I have a Pilatus B4 and wish to install an ILEC audio variometer. A
TE probe on the tail is not going to happen, for a number of reasons. So I guess my choice is either a fuselage mounted probe, or no probe at all..which I guess would give me an uncompensated variometer. any advice for me, a rookie? Thanks, Bill |
Earlier, wrote:
...So I guess my choice is either a fuselage mounted probe, or no probe at all. I recommend the fuselage probe. Ten dollars worth of parts and you're good to go. See Nicks and Johnson for the original idea and its refinement. This article is pretty clear about it: http://wcsa.org/docs/TEprobe.pdf Also, see Sebald for an alternative installation that combines TE probe and radio antenna: http://www.soaridaho.com/Schreder/Co...E_ANTENNA.html Thanks, Bob K. |
On Nov 26, 6:21 pm, Bob Kuykendall wrote:
Earlier, wrote: ...So I guess my choice is either a fuselage mounted probe, or no probe at all. I recommend the fuselage probe. Ten dollars worth of parts and you're good to go. See Nicks and Johnson for the original idea and its refinement. This article is pretty clear about it: http://wcsa.org/docs/TEprobe.pdf Also, see Sebald for an alternative installation that combines TE probe and radio antenna: http://www.soaridaho.com/Schreder/Co...E_ANTENNA.html Thanks, Bob K. Bob, I like the idea of incorporating the Radio Antenna and TE Probe. Do you still have some of the parts, as said in the article? |
On Nov 26, 5:32 pm, wrote:
I like the idea of incorporating the Radio Antenna and TE Probe. Do you still have some of the parts, as said in the article? Yes, I've still got a couple of the antenna-length wands up at the shop. I think I have a couple of the machined bases as well, but I hold no particular confidence I could put hand to them, so you're probably out of luck there. Easy enough to make, though. Thanks, Bob K. |
wrote in message ... On Nov 26, 6:21 pm, Bob Kuykendall wrote: Earlier, wrote: ...So I guess my choice is either a fuselage mounted probe, or no probe at all. I recommend the fuselage probe. Ten dollars worth of parts and you're good to go. See Nicks and Johnson for the original idea and its refinement. This article is pretty clear about it: http://wcsa.org/docs/TEprobe.pdf Also, see Sebald for an alternative installation that combines TE probe and radio antenna: http://www.soaridaho.com/Schreder/Co...E_ANTENNA.html Thanks, Bob K. Bob, I like the idea of incorporating the Radio Antenna and TE Probe. Do you still have some of the parts, as said in the article? This system was designed for a metal sailplane. You will need to create a ground plane inside the fuselage of your Cherokee. Four 22 inch copper wire radials should do the trick. Wayne HP-14 "6F" http://www.soaridaho.com/ Amateur Radio W7ADK |
right now i have a homemade ground plane antenna. It is made of
fairly stiff copper wire, which makes it tricky to fit behind the seat in the glider. would it be equivalent to use some more malleable copper, run along the inside of the fuselage, curved with the frame, but still the 22-23 inch length that is important. any thoughts? |
Thank you. I already have an antenna in place. I've read, over and
over, that fuselage mounted probes (particularly those mounted aft of the wing - which, of course, is pretty much the only pace I'm going to be able to put it) really stink compared to those on the tail. Shall I infer from your comments that a ****ty TE probe is better than none at all? Let me tell you that the intended purpose is for fun flying in the vicinity of the airfield. There will be no cross-country to speak of...mainly climbing back up to play around a bit. Mostly I want this audio vario so I can generally tell up from down while looking out of the cockpit. |
On Nov 27, 8:09 am, wrote:
...I've read, over and over, that fuselage mounted probes (particularly those mounted aft of the wing ... really stink compared to those on the tail... I think this is one of those "sure, it works in practice, but does it work in theory?" topics. As I've cited earlier in this thread, both Nicks and Johnson agree that fuselage-mounted probe can be perfectly adequate. My experience building, installing, and using the Sebald/Nicks antenna/TE probe for a dozen years correlates what they've written on the topic. I'm not particularly opposed to tail TEs, and I agree that they can be more accurate. We plumbed our last three fuselages for them. But unless a) (preferred) you're working on your fuselage on the half- shell, b) the ID of your aft fuselage substantially exceeds the OD of your body, or c) your ferret is trained on AC43.13 plumbing strain relief, the slight accuracy advantage of the tail TE is likely not worth the trouble of installing the necessary plumbing. Thanks, Bob K. |
On Nov 27, 2:11 pm, Chris Reed wrote:
wrote: Shall I infer from your comments that a ****ty TE probe is better than none at all? Yes, definitely. I have a fuselage mounted TE on my glider, and I'm pretty sure I have a slight leak (to be fixed this winter). Even so, it's far, far better than none at all. Without TE, you pull back on the stick and the vario cries "lift". Push, and you hear "sink". Even local soaring, this will have you confused enough to be back on the ground faster than you intend. Having once flown a club glider with defective TE, so that in practice it was completely uncompensated, the only way I could soar it was to turn off the audio and fly by the seat of my pants, looking at the needle only when established in a circle at a steady airspeed. heh the funny thing is that my longest flight was without TE or audio. of course i guess i have a seat of the pants glider. and flying at a steady speed is important. |
| Thread Tools | |
| Display Modes | |
| WTB: Sage CVA variometer | Fox Two | Soaring | 0 | July 12th 06 10:59 PM |
| Wet Variometer Repair | Heinz Gehlhaar | Soaring | 1 | April 28th 06 03:41 AM |
| German on back of variometer | f.blair | Soaring | 3 | March 7th 05 10:26 PM |
| Cambridge variometer | f.blair | Soaring | 2 | January 14th 05 04:44 AM |
| Pellet Variometer wanted | Mark James Boyd | Soaring | 0 | March 11th 04 08:57 PM |
