All,
I've just embarked on a project to extract US (CONUS) airspace data from the FAA National Airspace System Resource files and process it into more accessible formats (such as OpenAir and Tim Newport-Peace). This is a little more complicated than it sounds, because the NASR uses ESRI shapefile formats for Class B-E airspace, and the conversion isn't straightforward. I do, however, think it is possible, and I expect to complete the project before spring flying begins. I'm also working on extracting airport data from the same source into turnpoint files. I should be able to produce .CUP and .NDB turnpoint files from the NASR data by springtime as well. When I'm done, I'll submit the results to the Worldwide Turnpoint Exchange. Note: The NASR files are available free of charge to the public through the National Flight Data Center, but you do have to go through a registration and approval process that includes a request for permission to access the data. 2KA |
2KA,
I'm about to announce a web page that converts FAA National Flight Database (NFD) files into both of the airspace formats you describe (Tim Newport-Peace and OpenAir(tm)). It also provides a KML version for viewing the airspace in 3D with Google Earth. I'm not familiar with the NASR files. The NFD is subscription only, and it is because of FAA requirements for maintaining the subscription that I'm charging for it on my webpage ($20/year). Users will be able to provide a Cambridge-formatted turnpoint with which to specify their area of interest, or provide latitudes & longitudes for the bounding rectangle. Look for the announcement in a few days. ~ted/2NO |
Ted,
Your website sounds really great -- I'll subscribe for sure. I think I'll still go ahead with my project in the interest of providing something portable and open source. I'll be interested to compare the results. 2KA |
On Dec 20, 4:44 pm, Tuno wrote:
2KA, I'm about to announce a web page that converts FAA National Flight Database (NFD) files into both of the airspace formats you describe (Tim Newport-Peace and OpenAir(tm)). It also provides a KML version for viewing the airspace in 3D with Google Earth. I'm not familiar with the NASR files. The NFD is subscription only, and it is because of FAA requirements for maintaining the subscription that I'm charging for it on my webpage ($20/year). Users will be able to provide a Cambridge-formatted turnpoint with which to specify their area of interest, or provide latitudes & longitudes for the bounding rectangle. Look for the announcement in a few days. ~ted/2NO Thanks to both of you ! I've got John Leibacher an ILEC SN10 conversion utility that runs on his computer (replacing our less-than-reliable SOAP implementation). This plus your efforts should yield better NDB's on his web site ! Thanks again, Best Regards, Dave "YO" |
Dave,
My web site will be announced sometime today. If someone can send me a specification for the NDB format, I can add it to the supported formats. ~ted/2NO |
On Dec 21, 10:44 am, Tuno wrote:
Dave, My web site will be announced sometime today. If someone can send me a specification for the NDB format, I can add it to the supported formats. ~ted/2NO Hi Guys - See my website for updated resources on ILEC SN10. Under the "airspace" section, you'll find NDB format information and all of the gory info about converting TNP to NDB as required for SN10... Enjoy, Best Regards, Dave http://www.nadler.com/sn10/SN10_Resource_Index.html |
Thanks Dave. I'd tabled the notion of producing NDB output since
learning there are tools to convert from TNP. Nothing left to do there ![]() |
2KA wrote:
All, I've just embarked on a project to extract US (CONUS) airspace data from the FAA National Airspace System Resource files and process it into more accessible formats (such as OpenAir and Tim Newport-Peace). This is a little more complicated than it sounds, because the NASR uses ESRI shapefile formats for Class B-E airspace, and the conversion isn't straightforward. I do, however, think it is possible, and I expect to complete the project before spring flying begins. I'm also working on extracting airport data from the same source into turnpoint files. I should be able to produce .CUP and .NDB turnpoint files from the NASR data by springtime as well. When I'm done, I'll submit the results to the Worldwide Turnpoint Exchange. You'll be in my prayers for the entire 2008 season! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
2KA,
I haven't dived into the gory details of the NASR, but after browsing the SUA table of the primary data, the format descriptions for all the tables, and the class B-E shapes in the "Additional" data, I have the following observations: * The APT table can be used in conjunction with the FAA NFD (what I'm using on www.justsoar.com) to provide the comm frequencies missing from the latter. (They have a common key.) * Similarly, the SUA table provides active times missing from the NFD, for Restrictive, Alert, and MOA areas. (Alas the good news seems to end there.) * The SUA table does not provide precise descriptions of the restrictive areas. Arcs and circles, instead of being described by [center, radius, begin point, end point, and direction to travel], are lists of approximated points. They are not suitable for navigation purposes, and I believe the NASR description even says so. * The shapes data (for class B-E) have nice vector renderings (I used TNTatlas), but this data appear to be 2 dimensional only, and also not suitable for navigation purposes. (To be useful for navigation, top and bottom elevations must be provided.) It seems this data are useful only for 2D plotting. Also, at least the Class B file is out of date; I got the 20 Dec 07 - Feb 08 download, but it still has the old Phoenix Class B. I don't want to discourage you from your project, but potential users should be aware of these limitations. I do think that creating an airport turnpoint list from the APT table would be very useful. I hope you don't mind if I add this feature to what I provide on justsoar.com. 2NO |
On Dec 21, 11:01 pm, Tuno wrote:
2KA, I haven't dived into the gory details of the NASR, but after browsing the SUA table of the primary data, the format descriptions for all the tables, and the class B-E shapes in the "Additional" data, I have the following observations: * The APT table can be used in conjunction with the FAA NFD (what I'm using onwww.justsoar.com) to provide the comm frequencies missing from the latter. (They have a common key.) * Similarly, the SUA table provides active times missing from the NFD, for Restrictive, Alert, and MOA areas. (Alas the good news seems to end there.) * The SUA table does not provide precise descriptions of the restrictive areas. Arcs and circles, instead of being described by [center, radius, begin point, end point, and direction to travel], are lists of approximated points. They are not suitable for navigation purposes, and I believe the NASR description even says so. * The shapes data (for class B-E) have nice vector renderings (I used TNTatlas), but this data appear to be 2 dimensional only, and also not suitable for navigation purposes. (To be useful for navigation, top and bottom elevations must be provided.) It seems this data are useful only for 2D plotting. Also, at least the Class B file is out of date; I got the 20 Dec 07 - Feb 08 download, but it still has the old Phoenix Class B. I don't want to discourage you from your project, but potential users should be aware of these limitations. I do think that creating an airport turnpoint list from the APT table would be very useful. I hope you don't mind if I add this feature to what I provide on justsoar.com. 2NO 2NO What you say about the SUA is absolutely true. The line segments are accurate, but arcs and irregulars are only approximate. I hope the FAA will add them. The shapefile descriptions actually do include the elevation data you mention, as well as the name of each segment. The shapefiles are currently beta only; the FAA says they will be official and updated regularly sometime in mid-2008. Please do add the airport turnpoint list to turnpoint.com. I'll send over some of my source code for comparison, so you can see how I handle things like unique short name generation. 2KA 2KA |
| Thread Tools | |
| Display Modes | |
| DAFIF data for creating SUA files | [email protected] | Soaring | 0 | November 7th 07 03:36 PM |
| Wichita Airspace Question and overlapping airspace | Owen[_4_] | Piloting | 1 | February 14th 07 10:35 PM |
| Solution to DAFIF data going away? | Paul Tomblin | Piloting | 1 | June 5th 05 01:36 PM |
| DAFIF data | Paul Tomblin | Piloting | 1 | January 2nd 05 11:13 PM |
| DAFIF going away? | Paul Tomblin | Piloting | 2 | August 10th 04 04:30 PM |
