Has anyone interfaced an M3 with a PC?
I have a Motion LS-800 running Jeppview Flitedeck. I had succefully interfaced it with my previous aircraft that had a Trimble 2000 Approach. Trimble uses RS-232 w/ King aviation data format for its moving map output. I used an USB RS-232 coverter and Flitedeck was able to receive flight plan data & GPS position just fine. Now, I am installing a Northstar M3 to my new aircraft. Flitedeck does have M3 in its setup GPS selections, so I assume they should be able to talk in software if hardware connection is good. Unlike Trimble, M3 uses RS-485 for moving map output. After google USB RS-485, I found a converter from coolgear.com/usbgear.com (model USB- COM-I) for about $50. I wired the USB/RS-485 converter to M3 by connecting "Data-A", "Data- B" & "Ground" (P15 pins 6, 11 & 5 on M3 and pins 1, 2 & 5 on USB-COM- I). I then turned on M3 in demo mode. In M3's serial data spec (Doc No. GM342), it says on page 2 that in "flight sim" mode baud rate is 9600. I then run Hyper Terminal on LS-800 w/ 9600 baud on COM-5 which is assigned to USB-COM-I, but received no data from M3. After that, I tried Hyper Terminal on 1200 baud, but no joy. I then run Flitedeck Setup to test for GPS multiple times w/ different setting. Still no joy. Does M3 output its moving map data in demo mode? Is M3 demo & flgiht sim the same mode? Any comment on what else to try? |
On Dec 28, 11:41*am, " wrote:
Does M3 output its moving map data in demo mode? I attached an GPS antenna to M3 and it did ouput to PC via the USB/ RS-485 converter just fine. I think M3 does not output its GPS data in demo mode, and demo mode is not the same as flight sim mode. But Flitedeck only gets M3's position data and no flight plan data. Work in progress. Robin |
| Thread Tools | |
| Display Modes | |
| Northstar M3 Antenna | [email protected] | Aviation Marketplace | 0 | December 4th 05 05:06 AM |
| Northstar web page? | Brinks | Owning | 2 | January 27th 05 08:16 PM |
| Need Help with Northstar M1 Loran | Jerald Malin | Owning | 4 | December 8th 03 06:38 PM |
| WTB: Northstar M3 GPS | Bill Zaleski | Aviation Marketplace | 0 | October 29th 03 12:10 PM |
| WTB: Northstar database | Bill Zaleski | Aviation Marketplace | 0 | September 8th 03 03:53 PM |
