Phrase "landing runway" vs. "cleared to land"
Old January 15th 08, 07:37 PM posted to rec.aviation.piloting, rec.aviation.ifr
Robert M. Gary
Default Phrase "landing runway" vs. "cleared to land"
On Jan 15, 11:04*am, kontiki wrote:
What are the vis minimums for that approach? Probably than 1/8 SM.
I'm sure you got cleared for the approach but perhaps since the vis
minimums were below that published for the approach tower didn't issue
you a clearance. That's my guess.- Hide quoted text -
There is no min reported visibility requirement for the approach.
-Robert
Old January 15th 08, 07:41 PM posted to rec.aviation.piloting,rec.aviation.ifr
B A R R Y[_2_]
Robert M. Gary wrote:
Yea, we teach (or are suppose to teach) IFR pilots not to do that. Its
not very helpful for the intended purpose (to let everyone know where
you are).
I was taught, and it was reinforced by the DE, to use distance and
direction over waypoints.
If you think about it, it's not difficult to do, as the distance from
the named point to the airport is usually right on the plate. Also,
since most of us have at least a VFR GPS onboard, we have another
reference for distance out in between fixes.
Old January 15th 08, 07:47 PM posted to rec.aviation.piloting, rec.aviation.ifr
Robert M. Gary
That's good but just make sure you use waypoints that a VFR pilot
would know (like VORs, etc). Remember the point is for traffic to know
where you are so you don't want to use references that some pilots may
not know. Personally I prefer using relative location to the airport,
since you're only about 10 miles out anyway.
-Robert
Old January 15th 08, 08:17 PM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll
On Jan 15, 11:30 am, "Steven P. McNicoll"
He erred. The proper phraseology is "not in sight, runway 22L cleared to
land." "Own risk" is used when a pilot insists on landing on a closed
runway, "unable to issue landing clearance, landing will be at your own
risk."
That's what I thought but he said it 6 times. Must be training week
in Sacramento.
A qualified instructor is supposed to correct those things on the spot.
Old January 15th 08, 08:24 PM posted to rec.aviation.piloting,rec.aviation.ifr
kontiki
I can't see much sense in demanding that VFR pilots learn about IFR
and buy or download the approach plates so they can understand a radio
message from an IFR flight doing practice in VFR conditions (or when
conditions are VFR at the relevant airport).
If an instructor can't explain to a student (with a simple diagram)
what the fixes are for the common instrument approaches at the airport
they are doing their students a disfavor.
Since there is no requirement to use the radio at class E fields,
though, then there's really nothing to be said if an IFR pilot just
doesn't want to be bothered.
Hmmm... by that logic then why does it matter if they make any
radio calls at all? The whole point is to say give the most amount
of information in the fewest words. That's best for everybody, but
it does require a small amount of training.
This will probably never be such a big problem (ie, an accident or two
or three) that the FAA has to write a regulation on it. If they do
regulate, I'd bet money on the rule requiring IFR pilots to announce
position rather than the FAA requiring IFR knowledge from VFR pilots.
However annoying to the IFR pilot it might be.
Sorry we bothered you.
Old January 15th 08, 08:25 PM posted to rec.aviation.piloting, rec.aviation.ifr
Brian[_1_]
in Sacramento. Sunday night I flew into SAC and was told "Cleared to
land runway 22". I assume they hadn't built a new runway over night.
-Robert
I agree it sounds like an error on the part of the controller. But it
should be easy for you as the pilot to fix. Your response should be
"XXX Tower please confirm Mooney XXX is cleared for Runway 22"
Brian
CFIIG/ASEL
Old January 15th 08, 08:39 PM posted to rec.aviation.piloting, rec.aviation.ifr
Robert M. Gary
There is no requirement for VFR pilots to visit an airport with an
instructor before they first fly to that airport. Likewise there is no
requirement for VFR pilots to purchase approach plates and enroute
charts for cross country airports.
-Robert
Old January 15th 08, 08:55 PM posted to rec.aviation.piloting,rec.aviation.ifr
kontiki
Of course there "is no requirement...". No one said anything about
VFR pilots purchasing approach plates and teaching them IFR (perish the
mere thought!). Re-read my post. Where I trained (and where I now teach)
there are constantly people practicing instrument approaches and we
hear calls like "...N1234a is procedure turn inbound ILS23.." or
"N1234a is YUPPY inbound ILS 32..." Most students want to know what
that means. In any case it behooves an instructor to explain.. once
explained the student will no longer be ignorant and will ultimately
be a safer pilot when he's out soloing.
Old January 15th 08, 09:07 PM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll
"Brian" wrote in message
It doesn't just sound like an error, it's definitely an error.
FAA Order 7110.65R Air Traffic Control
Chapter 3. Airport Traffic Control- Terminal
Section 10. Arrival Procedures and Separation
3-10-7. LANDING CLEARANCE WITHOUT VISUAL OBSERVATION
When an arriving aircraft reports at a position where he/she should be seen
but has not been visually observed, advise the aircraft as a part of the
landing clearance that it is not in sight and restate the landing runway.
PHRASEOLOGY-
NOT IN SIGHT, RUNWAY (number) CLEARED TO LAND.
NOTE-
Aircraft observance on the CTRD satisfies the visually observed requirement.
CTRD is Certified Tower Radar Display.
Old January 15th 08, 09:13 PM posted to rec.aviation.piloting, rec.aviation.ifr
It's not logic, it's simply not required by the FARs for class E.
I wasn't bothered, and I don't think you're sorry.
When I get IFR certified I'll make sure and also give my position
reports during VFR conditions in language I think VFR pilots will
understand -- mainly because I value my own life and want to make
every reasonable effort to preserve it. Speaking ONLY a language
others may not comprehend won't help me out in that regard.
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Piloting 168 February 5th 08 05:32 PM
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" Mike[_7_] Naval Aviation 50 November 30th 07 05:25 AM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
"Airplane Drivers" and "Self Centered Idiots" Skylune Piloting 28 October 16th 06 05:40 AM
