I recently got my high performance checkout and have taken a 182Q for
a couple of X-C flights. I love the ability to put four people in the plane and still climb out at 500 ft/min at over 100 knots. If it wasn't for the additional costs, I would never fly an C172 again. On both flights, the cruise speed was around 125 knots. Fuel burn was around 12 gph. I can rent a Cherokee 6/260 for the same price ($95 dry). I doubt I would need the extra seats, but I was wondering what the average cruise speed and fuel burn would be. I have rented a Cherokee 140 and the fuel burn was much higher than the C172 with the same engine, (8-9 vs 6) I know the Cherokee's larger engine should mean a larger fuel burn, but would the additional speed make up for it? thanks John |
john wrote:
I recently got my high performance checkout and have taken a 182Q for a couple of X-C flights. I love the ability to put four people in the plane and still climb out at 500 ft/min at over 100 knots. If it wasn't for the additional costs, I would never fly an C172 again. On both flights, the cruise speed was around 125 knots. Fuel burn was around 12 gph. I can rent a Cherokee 6/260 for the same price ($95 dry). I doubt I would need the extra seats, but I was wondering what the average cruise speed and fuel burn would be. I have rented a Cherokee 140 and the fuel burn was much higher than the C172 with the same engine, (8-9 vs 6) I know the Cherokee's larger engine should mean a larger fuel burn, but would the additional speed make up for it? thanks John What size engine in the Cherokee 6? 260 or 300? Generally the 260 will net you about 135 Kts in a 6 at about 14G/hr. (this can be imporoved at optimum altitude/power settings and leaning). Either way its about a wash... (I am suprised you are getting 12gph for the 182... the ones I've flown burn more than that). All things being equal I'd rather have speed. |
john wrote:
I recently got my high performance checkout and have taken a 182Q for a couple of X-C flights. I love the ability to put four people in the plane and still climb out at 500 ft/min at over 100 knots. If it wasn't for the additional costs, I would never fly an C172 again. On both flights, the cruise speed was around 125 knots. Fuel burn was around 12 gph. I can rent a Cherokee 6/260 for the same price ($95 dry). I doubt I would need the extra seats, but I was wondering what the average cruise speed and fuel burn would be. I have rented a Cherokee 140 and the fuel burn was much higher than the C172 with the same engine, (8-9 vs 6) I know the Cherokee's larger engine should mean a larger fuel burn, but would the additional speed make up for it? thanks John A 6-300 will cruise about 167 Knots and burn about 16gph. I think a 260 is a little under 140 knots at about 13 or 14gph. I've flown both but the 260 was a long time ago. |
Gig 601XL Builder wrote:
A 6-300 will cruise about 167 Knots and burn about 16gph. I think a 260 is a little under 140 knots at about 13 or 14gph. I've flown both but the 260 was a long time ago. I think you've been overly optomistic with the speed figure for a Cherokee Six with the 300 hp engine. I used to figure about 145-150 knots with a full load, which is the only way I ever flew one. Your fuel figures are about right. The sweet spot for the Six was between 6,000 - 8,000 feet. Your 167 knots could be achieved with a Lance... which is just a Six with retractable gear. If the length of available runway was a factor there's no contest; take the C-182. If load was the factor, take the Six. The PA-32 cabin in all its forms is more spacious than the C-182s and basically if you can get the doors closed with the load balanced correctly, it's gonna fly. The Six carries more than the Lance, and the 260 HP version (oddly enough) has the greatest useful load of any of them. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
Mortimer Schnerd, RN wrote:
Gig 601XL Builder wrote: A 6-300 will cruise about 167 Knots and burn about 16gph. I think a 260 is a little under 140 knots at about 13 or 14gph. I've flown both but the 260 was a long time ago. I think you've been overly optomistic with the speed figure for a Cherokee Six with the 300 hp engine. I used to figure about 145-150 knots with a full load, which is the only way I ever flew one. Your fuel figures are about right. The sweet spot for the Six was between 6,000 - 8,000 feet. When I was regularly flying a 300 it was usually me two pax. No extra load. Probably about 650lbs total. AS was almost always just above 165. |
john wrote:
I have rented a Cherokee 140 and the fuel burn was much higher than the C172 with the same engine, (8-9 vs 6) . This is more a function of the pilot's choice in altitude, power setting and mixture control than anything else. Since they have the same engine, they should burn about the same amount a fuel at identical power settings (about 8gph at 75% power is normal for both types). If you fly one fast and low, 9 gph is not unheard of. Slow and high, and 6 gph is doable. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200801/1 |
"JGalban via AviationKB.com" u32749@uwe wrote in message
news:7e4f78808f995@uwe... john wrote: I have rented a Cherokee 140 and the fuel burn was much higher than the C172 with the same engine, (8-9 vs 6) . This is more a function of the pilot's choice in altitude, power setting and mixture control than anything else. Since they have the same engine, they should burn about the same amount a fuel at identical power settings (about 8gph at 75% power is normal for both types). If you fly one fast and low, 9 gph is not unheard of. Slow and high, and 6 gph is doable. Back in 2001, I flew my 140 to Oshkosh along with 2 Warriors and 2 Skyhawks. All had Lycomong O320 160HP engines. When we stopped for fuel, we all took almost the exact same amount. |
When I was regularly flying a 300 it was usually me two pax. No extra load. Probably about 650lbs total. AS was almost always just above 165. Had I known it was costing me 15-20 knots, I'd have made those other *******s walk. G -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
Gig 601XL Builder wrote: When I was regularly flying a 300 it was usually me two pax. No extra load. Probably about 650lbs total. AS was almost always just above 165. Had I known it was costing me 15-20 knots, I'd have made those other *******s walk. G As well you should. I just remembered that the 300 I was flying did have some speed mods so some of that 15-20 knot difference probably came from there. |
I was surprised at the difference on fuel consumtion. I have tried to
fly both of them at the same altitude, RPM and fuel/air mixture. Over several flights the consumption stays about the same. I asked an instructor about it and he mentioned he can't get the high fuel consumption down either. It doesn't matter whether it was in the lower or higher altitudes (up to 7500 feet), and aggressive leaning, the Cherokee doesn't have the fuel economy of the Cessna. The engine had been rebuilt recently, (less than 200 hours), but I'm not sure that has anything to do with it. On Jan 16, 2:21*pm, "JGalban via AviationKB.com" u32749@uwe wrote: john wrote: *I have rented a Cherokee 140 and the fuel burn was much higher than the C172 with the same engine, (8-9 vs 6) . * This is more a function of the pilot's choice in altitude, power setting and mixture control than anything else. *Since they have the same engine, they should burn about the same amount a fuel at identical power settings (about 8gph at 75% power is normal for both types). * If you fly one fast and low, 9 gph is not unheard of. *Slow and high, and 6 gph is doable. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200801/1 |
| Thread Tools | |
| Display Modes | |
| C182 Oil Temperatures | Steve Leonard | Soaring | 0 | October 9th 07 05:53 AM |
| C182 questions | Frank Whiteley | Soaring | 5 | October 8th 07 11:54 PM |
| C182 Oil Temp | Steve Leonard | Soaring | 1 | October 8th 07 11:33 PM |
| C182 overhaul | Chris | Owning | 7 | September 9th 06 06:58 AM |
| Nearly new C182 checklist | Brinks | Owning | 7 | December 18th 04 05:00 AM |
