In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? -c |
"gatt" wrote in
: In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer. ( slower) Bertie |
On Feb 26, 7:04*am, Bertie the Bunyip wrote:
"gatt" wrote : In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer.. ( slower) I thought it was purely due to a reduction in induced drag. This causes the lift vector to be larger. Cheers |
WingFlaps wrote in
: On Feb 26, 7:04*am, Bertie the Bunyip wrote: "gatt" wrote ews.com: In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer . ( slower) I thought it was purely due to a reduction in induced drag. This causes the lift vector to be larger. ??I'm not with you here.. bertie |
On Feb 26, 7:28*am, Bertie the Bunyip wrote:
WingFlaps wrote : On Feb 26, 7:04*am, Bertie the Bunyip wrote: "gatt" wrote ews.com: In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer . ( slower) I thought it was purely due to a reduction in induced drag. This causes the lift vector to be larger. ??I'm not with you here.. OK, I'll explain myself but I'm sure you know this stuff -you're not trolling me I hope ... The wing produces a force vector that is broken into 2 components lift and drag. The wing tip vortex is a major contributer to the rotation of the wing force vector. Within ~1.5 wingspans the wing tip vortex is suppressed by friction with the ground. This has two effects : a big reduction in drag (so you float a long way in landing as you do not shed energy so fast) and the rotation of the wing force vector towards vertical increases lift. In landing/takeoff configs the high AOA leads to a very backward wing force vector so ground effect increases lift a lot in those configs. This then easily explains a take off stall -as you rotate and climb out of ground effect drag increases and lift decreases. The loss of lift requireds you to further increases AOA which further increases drag. If drag becomes greater than thrust you stall. Cheers |
On Mon, 25 Feb 2008 18:04:57 +0000 (UTC), Bertie the Bunyip
wrote in : Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer. ( slower) I find it curious that an alleged airline captain has failed to mention the reduction in induced drag that results due to the interference with the wingtip vortices when operating in ground effect. http://www.faa.gov/library/manuals/a...83-25-1of4.pdf OUND EFFECT It is possible to fly an airplane just clear of the ground (or water) at a slightly slower airspeed than that required to sustain level flight at higher altitudes. This is the result of a phenomenon, which is better known than understood even by some experienced pilots. When an airplane in flight gets within several feet from the ground surface, a change occurs in the three dimensional flow pattern around the airplane because the vertical component of the airflow around the wing is restricted by the ground surface. This alters the wing’s upwash, downwash, and wingtip vortices. [Figure 3-7] These general effects due to the presence of the ground are referred to as “ground effect.” Ground effect, then, is due to the interference of the ground (or water) surface with the airflow patterns about the airplane in flight. While the aerodynamic characteristics of the tail surfaces and the fuselage are altered by ground effects, the principal effects due to proximity of the ground are the changes in the aerodynamic characteristics of the wing. As the wing encounters ground effect and is maintained at a constant lift coefficient, there is consequent reduction in the upwash, downwash, and the wingtip vortices. Induced drag is a result of the wing’s work of sustaining the airplane and the wing lifts the airplane simply by accelerating a mass of air downward. It is true that reduced pressure on top of an airfoil is essential to lift, but that is but one of the things that contributes to the overall effect of pushing an air mass downward. The more downwash there is, the harder the wing is pushing the mass of air down. At high angles of attack, the amount of induced drag is high and since this corresponds to lower airspeeds in actual flight, it can be said that induced drag predominates at low speed. -- However, the reduction of the wingtip vortices due to ground effect alters the spanwise lift distribution and reduces the induced angle of attack and induced drag. Therefore, the wing will require a lower angle of attack in ground effect to produce the same lift coefficient or, if a constant angle of attack is maintained, an increase in lift coefficient will result. [Figure 3-8] Ground effect also will alter the thrust required versus velocity. Since induced drag predominates at low speeds, the reduction of induced drag due to ground effect will cause the most significant reduction of thrust required (parasite plus induced drag) at low speeds. The reduction in induced flow due to ground effect causes a significant reduction in induced drag but causes no direct effect on parasite drag. As a result of the reduction in induced drag, the thrust required at low speeds will be reduced. Due to the change in upwash, downwash, and wingtip vortices, there may be a change in position (installation) error of the airspeed system, associated with ground effect. In the majority of cases, ground effect will cause an increase in the local pressure at the static source and produce a lower indication of airspeed and altitude. Thus, the airplane may be airborne at an indicated airspeed less than that normally required. In order for ground effect to be of significant magnitude, the wing must be quite close to the ground. One of the direct results of ground effect is the variation of induced drag with wing height above the ground at a constant lift coefficient. When the wing is at a height equal to its span, the reduction in induced drag is only 1.4 percent. However, when the wing is at a height equal to one-fourth its span, the reduction in induced drag is 23.5 percent and, when the wing is at a height equal to one-tenth its span, the reduction in induced drag is 47.6 percent. Thus, a large reduction in induced drag will take place only when the wing is very close to the ground. Because of this variation, ground effect is most usually recognized during the liftoff for takeoff or just prior to touchdown when landing. During the takeoff phase of flight, ground effect produces some important relationships. The airplane leaving ground effect after takeoff encounters just the reverse of the airplane entering ground effect during landing; i.e., the airplane leaving ground effect will: • Require an increase in angle of attack to maintain the same lift coefficient. • Experience an increase in induced drag and thrust required. • Experience a decrease in stability and a nose-up change in moment. • Produce a reduction in static source pressure and increase in indicated airspeed. These general effects should point out the possible danger in attempting takeoff prior to achieving the recommended takeoff speed. Due to the reduced drag in ground effect, the airplane may seem capable of takeoff well below the recommended speed. However, as the airplane rises out of ground effect with a deficiency of speed, the greater induced drag may result in very marginal initial climb performance. In the extreme conditions such as high gross weight, high density altitude, and high temperature, a deficiency of airspeed during takeoff may permit the airplane to become airborne but be incapable of flying out of ground effect. In this case, the airplane may become airborne initially with a deficiency of speed, and then settle back to the runway. It is important that no attempt be made to force the airplane to become airborne with a deficiency of speed; the recommended takeoff speed is necessary to provide adequate initial climb performance. For this reason, it is imperative that a definite climb be established before retracting the landing gear or flaps. During the landing phase of flight, the effect of proximity to the ground also must be understood and appreciated. If the airplane is brought into ground effect with a constant angle of attack, the airplane will experience an increase in lift coefficient and a reduction in the thrust required. Hence, a “floating” effect may occur. Because of the reduced drag and power off deceleration in ground effect, any excess speed at the point of flare may incur a considerable “float” distance. As the airplane nears the point of touchdown, ground effect will be most realized at altitudes less than the wingspan. During the final phases of the approach as the airplane nears the ground, a reduced power setting is necessary or the reduced thrust required would allow the airplane to climb above the desired glidepath. http://aerodyn.org/Wings/wings.html#ground Wings in Ground Effect The use of ground effect is generally regarded as a very efficient means to increase the lift and decrease the drag. |
On Feb 26, 8:07*am, Larry Dighera wrote:
http://www.faa.gov/library/manuals/a...ook/media/faa-... * * OUND EFFECT HUGE snip That's what I said -albeit more succinctly... Cheers |
On Mon, 25 Feb 2008 18:04:57 +0000 (UTC), Bertie the Bunyip wrote in : Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer. |
Larry Dighera wrote in
: On Mon, 25 Feb 2008 18:04:57 +0000 (UTC), Bertie the Bunyip wrote in : Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer. ( slower) I find it curious that an alleged airline captain has failed to mention the reduction in induced drag that results due to the interference with the wingtip vortices when operating in ground effect. Bwawhahwhahwhahwhahhwhahwhahwhahhwhahw! Go **** your alleged self Larry. Bertie |
WingFlaps wrote in
: On Feb 26, 8:07*am, Larry Dighera wrote: On Mon, 25 Feb 2008 18:04:57 +0000 (UTC), Bertie the Bunyip wrote in : Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longe r. ( slower) I find it curious that an alleged airline captain has failed to mention the reduction in induced drag that results due to the interference with the wingtip vortices when operating in ground effect. Perhaps it did note poke the induced drag memory cells? Maybe our Bertie actively suppresses his drag memories? Groan! Bertie |
| Thread Tools | |
| Display Modes | |
| Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 06:32 PM |
| Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 06:32 PM |
| Can I still get "Bad day for JFK ground Controller"? | [email protected] | Piloting | 8 | October 19th 07 05:52 AM |
| V-22 Osprey "ground effect" question | Robert | Naval Aviation | 6 | January 2nd 07 04:44 PM |
| Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 08:48 AM |
