Why a Swept-Wing?
Old January 11th 04, 06:37 PM
Tarver Engineering
"Ed Rasimus" wrote in message
On Sun, 11 Jan 2004 09:55:02 -0500, Air Force Jayhawk
An aircraft is only unstable if the aerodynamic center is forward of
the center of gravity. If the wing root is sufficiently aft and the
AC stays aft of the CG, stability remains.
Why? Well it was tried with the X-29 but I never have read why no one
has pursued it since. The advantage was supposed to be that the
boundary layer (the thick air right next to the surface caused by
friction and very annoying) builds up as the air moves aftward along
the wing. With a FSW, the thickest part of the BL is at the root
rather than near the control surfaces, enhancing control while at high
angles of attack. There are other advantages but it's been a while so
I can't recall them off the top of my head.
I knew the USAF pilot on the X-29 project...he said it flew fine and
had no issues with it.
As I recall the X-29 project, one of the objectives was evaluation of
the instability as a means of gaining agility for future highly
maneuverable aircraft. The "urban legend" was that the aircraft
required minimum of triple redundant FBW augmentation as loss of the
augmentation would result in immediate excursions from stable flight
and structural failure within seconds. The ultimate in "JC maneuvers".
Always thought it made for an extremely ugly airplane.
Wasn't the basic structure from an F-16A?
Grumman modified an F-5.
Old January 11th 04, 08:10 PM
Kevin Brooks
snip
Ed, I believe the basic structure was from an F-5.
Brooks
Ed Rasimus
Old January 11th 04, 10:00 PM
WaltBJ
All rearward swept wings suffer a loss of lift to some degree because
of span-wise flow. Hence wing fences on some. Forward swept wings do
not, for obvious reasons. Forward swept wings do suffer a weight
penalty because the bending moments are self-generating - any twist
results in a force tending to increase that twist, thus they must be
considerably stronger than the alternative. IMHO aircraft designed for
lower G limits would profit efficiency-wise from forward sweep.
Walt BJ
Old January 12th 04, 03:35 AM
Tarver Engineering
"Alan Dicey" wrote in message
As far as I can recall, forward sweep confers the advantage that
spanwise flow is now inwards, and the wingtips (with associated control
surfaces) stall last instead of first, so control authority is retained
at higher angles of attack or "deeper into the stall". In the X-29 they
were combined with canards, a supercritical wing and aerodynamic
instabilty in a search for enhanced maneuverability. See here
http://www.dfrc.nasa.gov/Newsroom/Fa...-008-DFRC.html
for the NASA Dryden infosheet. I seem to remember that the advantages
gained did not warrant the construction costs/difficulties (aeroelastic
tailoring with composites in the wing structure, as I recall) and so the
technique was not carried forward into new fighter design. Perhaps Mary
Shafer may know more of the projects findings?
LOL
Old January 12th 04, 07:52 AM
machf
On Sun, 11 Jan 2004 09:57:12 -0800, "Tarver Engineering"
Actually, once the notch filter was adjusted such that the wing did not
delaminate, there was no benifit to forward swept wings.
Uh... excuse me, but what's a "notch filter" in this context?
__________ ____---____ Marco Antonio Checa Funcke
\_________D /-/---_----' Santiago de Surco, Lima, Peru
_H__/_/ http://machf.tripod.com
'-_____|(
remove the "no_me_j." and "sons.of." parts before replying
Old January 12th 04, 03:28 PM
Kevin Brooks
Here is a photo; the F-5 ancestry is evident in this view:
http://www.dfrc.nasa.gov/Gallery/Pho...EC90-357-7.jpg
Brooks
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
Old January 12th 04, 04:04 PM
Tarver Engineering
"machf" wrote in message
news
In the feedback control system of the X-29 was a z-transform type filter at
3.2 Hz. This was a simple third order filter in the original airframe.
Once the filter was altered to eliminate the flutter problem on the second
airframe, there was no manuverability advantage. The first airframe having
a delaminated wing by that time.
Old January 13th 04, 02:29 PM
machf
On Mon, 12 Jan 2004 08:04:07 -0800, "Tarver Engineering"
news
Oh, I see... I forgot that the X-29 had to rely heavily on electronics, and
thought maybe it was some mechanical equivalent or something. Thanks for
clearing that up.
Ah, z-transforms... It's been quite a while, but I used to be pretty good at
that stuff.
'-_____|(
Old January 14th 04, 02:06 AM
Tarver Engineering
news
not
at
second
having
and
clearing that up.
It could have been done mechanically, as the Russians have proven.
at
that stuff.
One of the people that worked for me at NASA got tasked with commenting the
original FORTRAN and came to me for help understanding what Mr. Main had
written. He was completely dissatisfied with what a third order filter does
and was certain the software did nothing.
Old January 14th 04, 03:27 AM
Tony
"James Dandy" wrote in message
m...
Pardon my ignorance on all matters concerning modern aviation but just
why the hell would you want to sweep a wing forward?
..........manuaverability
Doesn't that make any aircraft unstable?
..........Yes
If so, why would any pilot feel safe in it?
..........Computers
Has anyone ever made one work?
..........Yes, several
German forward swept wing WWII fighter projects. Charles Gray Military Aviation 4 January 11th 04 01:49 PM
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
