Why a Swept-Wing?
Old January 15th 04, 04:30 AM
Mary Shafer
On Sun, 11 Jan 2004 18:20:34 GMT, Ed Rasimus
As I recall the X-29 project, one of the objectives was evaluation of
the instability as a means of gaining agility for future highly
maneuverable aircraft. The "urban legend" was that the aircraft
required minimum of triple redundant FBW augmentation as loss of the
augmentation would result in immediate excursions from stable flight
and structural failure within seconds. The ultimate in "JC maneuvers".
Well, it didn't have to have all three computers working, just one,
which could have been the fourth, back-up one. But that wasn't a
long-term sort of thing.
However, it didn't hang around for seconds before it pitched up.
stalled, and departed controlled flight. Time to double amplitude was
a small fraction of a second, although I can't remember the number.
It was smaller than that of the F-16, but the F-16 isn't very unstable
(it's neutrally stable clean and full of fuel and could be flown,
albeit rather oddly, without augmentation until enough fuel burned
off, not that anyone except VISTA would try this).
The X-29 was statically unstable because the project was a technology
demonstrator for agile aircraft with forward-swept wings, aircraft
that were stall-resistant. It wasn't statically unstable because it
had a forward-swept wing.
Always thought it made for an extremely ugly airplane.
I thought it wasn't all that bad looking, myself. The X-31 was rather
plain, but the X-29 was OK.
Wasn't the basic structure from an F-16A?
No, that was the X-31, I think, at least for the gear and cockpit.
The X-29 used a couple of F-5s for the fuselages. I don't remember
how far aft the F-5 airframe went, but it definitely included the
cockpit and surrounding structure, as well as the gear, as I recall.
Mary
Mary Shafer Retired aerospace research engineer
Old January 15th 04, 04:04 PM
Tarver Engineering
"Mary Shafer" wrote in message
snip
This is closer than Mary's claim that the F-16 is statically unstable, but
the F-16 continues to remain 5% pitch stable.
Old January 19th 04, 08:14 AM
JasiekS
Uzytkownik "Alan Dicey"
napisal w wiadomosci ...
As far as I can recall, forward sweep confers the advantage that
spanwise flow is now inwards, and the wingtips (with associated control
surfaces) stall last instead of first, so control authority is retained
at higher angles of attack or "deeper into the stall". In the X-29 they
were combined with canards, a supercritical wing and aerodynamic
instabilty in a search for enhanced maneuverability. See here
http://www.dfrc.nasa.gov/Newsroom/Fa...-008-DFRC.html
for the NASA Dryden infosheet. I seem to remember that the advantages
gained did not warrant the construction costs/difficulties (aeroelastic
tailoring with composites in the wing structure, as I recall) and so the
technique was not carried forward into new fighter design. Perhaps Mary
Shafer may know more of the projects findings?
I dug through my old notices on X-29A and X-31X and found these references:
[1] Bandyopadhyay G. - "Low-Speed Aerodynamic Characteristics of
Close-Coupled Canard Configuration at Incidence and Sideslip", Journal of
Aircraft, Vol. 28, No. 10, October 1991
[2] Er-El J. - "Effect of Wing/Canard Interference on the Loading of a Delta
Wing", Journal of Aircraft, Vol. 25, No. 1, January 1988
[3] Manoeuvring Aerodynamics, AGARD CP 497, Toulouse, France, May 1991
(especially papers)
[3.a] Ross Hannes - "X-31 Enhancement of Aerodynamics for Maneuvering beyond
Stall", Paper 2
[3.b] Kraus W. - "X-31, Discussion of Steady State and Rotary Derivatives",
Paper 13
[3.c] Ferretti A., Bartoli A., Salvatore A. - "Prediction of Aerodynamic
Phenomena Limiting Aircraft Manoeuvrability", Paper 5
[3.d] Visintini L., Pertile R., Mentasti A. - "Parametric Effects of some
Aircraft Components on High-Alpha Aerodynamic Characteristics", Paper 6
Close-Coupled Canard was my main area of interest these days so sweep
(-forward or -back) can be treated mariginally in these papers, but I hope
they can help you.
Regards
JasiekS
Warsaw, Poland
Old January 23rd 04, 03:35 AM
Tarver Engineering
"JasiekS" wrote in message
they can help you.
The major interesting fearure of the X-29 was the two poles in the right
half of the s-plane.
Old January 23rd 04, 06:34 PM
W. D. Allen Sr.
Two poles in the right half s plane made it inherently unstable, right?
Does that mean LOT, the Polish airlines, can have seats only on the lefthand
side of their airplanes.
WDA
end
"Tarver Engineering" wrote in message
hope
they can help you.
Old January 25th 04, 01:31 AM
Tarver Engineering
"W. D. Allen Sr." wrote in message
Pitch unstable, but the poles being complex in nature eliminates most folks
(including aero engineers) from the discussion.
lefthand
No.
Old January 25th 04, 06:54 AM
machf
On Fri, 23 Jan 2004 10:34:23 -0800, "W. D. Allen Sr."
Engineering humor... LOL.
__________ ____---____ Marco Antonio Checa Funcke
\_________D /-/---_----' Santiago de Surco, Lima, Peru
_H__/_/ http://machf.tripod.com
'-_____|(
remove the "no_me_j." and "sons.of." parts before replying
Old November 28th 11, 11:00 PM
tonini tonini is offline
Junior Member
First recorded activity by AviationBanter: Nov 2011
Quote:
Originally Posted by James Dandy View Post
Pardon my ignorance on all matters concerning modern aviation but just
why the hell would you want to sweep a wing forward?
Doesn't that make any aircraft unstable? If so, why would any pilot
feel safe in it?
Has anyone ever made one work?
James Dandy
Swept-wing spread - low speed and manouverability.
Unspread - higher speed and intercepting
German forward swept wing WWII fighter projects. Charles Gray Military Aviation 4 January 11th 04 01:49 PM
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
