A little afterthought concerning trailer tongue failures. I have a
3/4 ton GMC pickup with a factory installed hitch. Last year I towed my glider 700 miles to do some repairs. When I got to my destination and went to unhitch the trailer I found the trailer tongue a few inches from the ground. My 10,000lb hitch had broken two of the four mounting ears where it bolts to the frame and the other two were very near breaking. The entire hitch was dangling loosely and I'm sure very near breaking free entirely. I have witnesses. Since the safety chains were attatched to the hitch they would have been worthless. I was very close to serious property damage and possibly much worse. Hitches are not bulletproof. I do tow a 4000lb travel trailer occasionally. The hitch shop that replaced the hitch said this was not an uncommon failure. I would recommend inspecting the hitch itself, especially the mounts for cracks and security. |
A good point to raise before the (northern) season gets going.
Heard of someone loosing a bumper hitch on a brand new pickup. The dealer claimed that it wasn't their responsibility, as it wasn't a factory- or dealer- installed ball on the hitch! Personally had a similar failure, but on the trailer. One of the front bolts holding the tongue to the trailer failed, the other loosened. Of course, on a drive from Ely back home along some of the "loneliest roads". Fortunately the loose front and both rear bolts held and the trailer had only sagged about an inch or so (25 - 30mm) when it was discovered. Replaced the bolts and it was back in business. Yes, the safety chain is attached to this part that could have fallen off, too! We probably don't preflight our trailers enough. There's more to them than checking lights and greasing the bearings. It takes very little time to check the hitch on the car, too. It helps to have a mechanic's creeper. (a dolly you lie on to get under the vehicle) Jim |
On Mar 15, 10:25 am, JS wrote:
A good point to raise before the (northern) season gets going. Heard of someone loosing a bumper hitch on a brand new pickup. The dealer claimed that it wasn't their responsibility, as it wasn't a factory- or dealer- installed ball on the hitch! Personally had a similar failure, but on the trailer. One of the front bolts holding the tongue to the trailer failed, the other loosened. Of course, on a drive from Ely back home along some of the "loneliest roads". Fortunately the loose front and both rear bolts held and the trailer had only sagged about an inch or so (25 - 30mm) when it was discovered. Replaced the bolts and it was back in business. Yes, the safety chain is attached to this part that could have fallen off, too! We probably don't preflight our trailers enough. There's more to them than checking lights and greasing the bearings. It takes very little time to check the hitch on the car, too. It helps to have a mechanic's creeper. (a dolly you lie on to get under the vehicle) Jim ah, northern season has started.... |
Jim.. we've been flying the last two weekends in low thermals and connecting
to upper level wave.. Bill "JS" wrote in message ... A good point to raise before the (northern) season gets going. Heard of someone loosing a bumper hitch on a brand new pickup. The dealer claimed that it wasn't their responsibility, as it wasn't a factory- or dealer- installed ball on the hitch! Personally had a similar failure, but on the trailer. One of the front bolts holding the tongue to the trailer failed, the other loosened. Of course, on a drive from Ely back home along some of the "loneliest roads". Fortunately the loose front and both rear bolts held and the trailer had only sagged about an inch or so (25 - 30mm) when it was discovered. Replaced the bolts and it was back in business. Yes, the safety chain is attached to this part that could have fallen off, too! We probably don't preflight our trailers enough. There's more to them than checking lights and greasing the bearings. It takes very little time to check the hitch on the car, too. It helps to have a mechanic's creeper. (a dolly you lie on to get under the vehicle) Jim |
Thanks for the "heads up" on this!
-- Hartley Falbaum wrote in message ... A little afterthought concerning trailer tongue failures. I have a 3/4 ton GMC pickup with a factory installed hitch. Last year I towed my glider 700 miles to do some repairs. When I got to my destination and went to unhitch the trailer I found the trailer tongue a few inches from the ground. My 10,000lb hitch had broken two of the four mounting ears where it bolts to the frame and the other two were very near breaking. The entire hitch was dangling loosely and I'm sure very near breaking free entirely. I have witnesses. Since the safety chains were attatched to the hitch they would have been worthless. I was very close to serious property damage and possibly much worse. Hitches are not bulletproof. I do tow a 4000lb travel trailer occasionally. The hitch shop that replaced the hitch said this was not an uncommon failure. I would recommend inspecting the hitch itself, especially the mounts for cracks and security. |
I used to tow my lightweight homebuilt trailer with Honda Accords. I
never weighed the trailer, but both the older four cylinder Accord and the newer six cylinder Accord pulled that trailer with ease. Now, "easy towing" was the ONLY good thing about that old trailer. My new trailer is MUCH heavier, I'm sure. While the six cylinder Accord towed the heavier trailer easily enough, the hitch didn't like it at all. The first of two hitches bolted to the Honda at three points: Two through the Oh Too Thin sheet metal at the bottom of the trunk and one at the tie-down loop at the center rear. Well, after a couple thousand miles of towing, I noticed the bottom of the trunk completely broken up and the spare tire about to fall out! Needless to say, I had that hitch removed and the trunk floor repaired. I found another hitch that bolted not through the Oh Too Thin sheet metal, but to the vestiges of "frame rails" near the rear of the car, plus one bolt through the tie-down loop as the previous hitch. This hitch also began to rip out the bottom of the Honda trunk. I really think this time was induced when, with trailer attached, I exited a gravel road onto a paved road too quickly, causing the hitch to bottom out on the ground as I drove through a low spot and punch up through the thin metal trunk via the central tie-down loop bolt attachment point. It was not long after that incident that I weighed the trailer: 2,040 lbs and 180 lbs tongue weight. The Honda was rated for only 1,000 lbs and 100 lb tongue weight. Lordy, was I overgrossing the poor beast! The Honda has been sold and replaced by a Subaru Forester (normally aspirated). It's rated to tow 2,400 lbs with a maximum of 200 lbs (or 240, I have forgotten) tongue weight. The hitch is a factory hitch. I will definitely keep an eye on this hitch after the problems I had with the Honda. I have noted the Subaru's rear end doesn't sag with the trailer attached as did the Honda's. Ray Lovinggood Carrboro, North Carolina, USA |
On Mar 15, 8:55 am, wrote:
A little afterthought concerning trailer tongue failures. I have a 3/4 ton GMC pickup with a factory installed hitch. Last year I towed my glider 700 miles to do some repairs. When I got to my destination and went to unhitch the trailer I found the trailer tongue a few inches from the ground. My 10,000lb hitch had broken two of the four mounting ears where it bolts to the frame and the other two were very near breaking. The entire hitch was dangling loosely and I'm sure very near breaking free entirely. I have witnesses. Since the safety chains were attatched to the hitch they would have been worthless. I was very close to serious property damage and possibly much worse. Hitches are not bulletproof. I do tow a 4000lb travel trailer occasionally. The hitch shop that replaced the hitch said this was not an uncommon failure. I would recommend inspecting the hitch itself, especially the mounts for cracks and security. Heck I once saw the whole step bumper and hitch depart a pickup towing a 28ft cabin cruiser. The boat and trailer crossed the five or six lanes of I-5 a couple of times in grand arcs and stopped without damage. Pretty amazing. Spring would seem a good time to check all hitch bolts and welds. Frank Whiteley |
"Frank Whiteley" wrote in message ... On Mar 15, 8:55 am, wrote: Heck I once saw the whole step bumper and hitch depart a pickup towing a 28ft cabin cruiser. The boat and trailer crossed the five or six lanes of I-5 a couple of times in grand arcs and stopped without damage. Pretty amazing. Spring would seem a good time to check all hitch bolts and welds. Frank Whiteley Sometimes it may be helpful to have a weak tow hitch? See http://www.youtube.com/watch?v=QsPnwi0nb2Q bumper "dare to be different . . . circle in sink" QV and MKII |
| Thread Tools | |
| Display Modes | |
| The FAA Failure | FAA Civil Rights | Instrument Flight Rules | 0 | October 8th 07 06:57 PM |
| Oleo 'strut' inside tongue | Robert Gaines | Soaring | 3 | July 14th 07 08:08 AM |
| Failure #10 | Capt.Doug | Piloting | 7 | April 13th 05 03:49 AM |
| US source for wheel on the tongue of Cobra trailer? | Mark Zivley | Soaring | 3 | January 18th 05 04:51 AM |
| Cobra Tongue Strut Removed Finally | Brian Iten | Soaring | 0 | December 4th 04 08:54 PM |
