I am looking at a worn out mechanical jack for the ramp on a Komet
trailer. The best repair I have come up with is to buy a set of scissor jacks and have them welded into the existing frame. Has anyone else tackled this job and had better luck with another type of repair? Thanks in advance, Roger |
Some years ago, I had exactly the same problem on a 1978 Komet. I
bought two extra strong jacks and had a local welding shop mount them for me. Worked great! Mike On Mar 23, 9:31 am, wrote: I am looking at a worn out mechanical jack for the ramp on a Komet trailer. The best repair I have come up with is to buy a set of scissor jacks and have them welded into the existing frame. Has anyone else tackled this job and had better luck with another type of repair? Thanks in advance, Roger |
On Mar 23, 1:10*pm, Sarah Anderson wrote:
I have an older Komet with the same problem. I'd be interested in pix as well as info on where exactly to buy a "lovejoy bearing". Boy, sometimes the advertising writes itself, doesn't it? Sarah Bullwinkle wrote: On 3/23/08 12:12 PM, in article , "Mike the Strike" wrote: Some years ago, I had exactly the same problem on a 1978 Komet. *I bought two extra strong jacks and had a local welding shop mount them for me. *Worked great! Mike On Mar 23, 9:31 am, wrote: I am looking at a worn out mechanical jack for the ramp on a Komet trailer. *The best repair I have come up with is to buy a set of scissor jacks and have them welded into the existing frame. *Has anyone else tackled this job and had better luck with another type of repair? Thanks in advance, Roger I recently had trouble with mine. I got two auto scissor jacks from AutoMax and a friend connected them with a Lovejoy bearing. Huge range of motion and great stability compared with the previous ramp jack. I've got photos, if you need them. Bullwinkle- Hide quoted text - - Show quoted text - I'm pretty sure Williams Soaring has the double jack setups for your ramp. Reasonably priced too, as I recall. I have the same problem, but hate scissor jacks. I'm hoping to knock out a simple lever type setup in the next couple weeks. I'll post something if it works out. |
I am looking at a worn out mechanical jack for the ramp on a Komet trailer. The best repair I have come up with is to buy a set of scissor jacks and have them welded into the existing frame. Has anyone else tackled this job and had better luck with another type of repair? Thanks in advance, Roger One of the scissor jacks for my trailer eventually stripped its threads. I repaired it with a Heli-Coil and a new all-thread. The jacks work ok but the force required to elevate the glider is higher than I would like. Unfortunately, the alternative is more money than I want to invest. Steve |
wrote in message ... On Mar 23, 9:31 am, wrote: I am looking at a worn out mechanical jack for the ramp on a Komet trailer. The best repair I have come up with is to buy a set of scissor jacks and have them welded into the existing frame. Has anyone else tackled this job and had better luck with another type of repair? Thanks in advance, Roger One of the scissor jacks for my trailer eventually stripped its threads. I repaired it with a Heli-Coil and a new all-thread. The jacks work ok but the force required to elevate the glider is higher than I would like. Unfortunately, the alternative is more money than I want to invest. Steve Bob Carl got tired of cranking his ramp jack so he bought a big, low-RPM cordless drill and fitted it with a large socket then replaced the scissor jack crank handle with a matching nut. Now he can zip his ramp jack up and down effortlessly even with the glider on it. Bill D |
On Mar 23, 1:36*pm, wrote:
One of the scissor jacks for my trailer eventually stripped its threads. I repaired it with a Heli-Coil and a new all-thread. The jacks work ok but the force required to elevate the glider is higher than I would like. Unfortunately, the alternative is more money than I want to invest. Jacks and other machines cycled under load usually use Acme thread, which is very different from the profile used on allthread and bolts and similar. Acme threads generally have lower maximum force limits, but their even pressure distribution across the thread profile gives them relatively low friction - lower than the triangular profile used on nuts and bolts at least. Just replacing the scissors jack can be pretty cost-effective. You can probably get a matched set at a scrapyard for like five bucks each. Thanks, Bob K. |
On Mar 23, 6:03*pm, Bob Kuykendall wrote:
On Mar 23, 1:36*pm, wrote: One of the scissor jacks for my trailer eventually stripped its threads. I repaired it with a Heli-Coil and a new all-thread. The jacks work ok but the force required to elevate the glider is higher than I would like. Unfortunately, the alternative is more money than I want to invest. Jacks and other machines cycled under load usually use Acme thread, which is very different from the profile used on allthread and bolts and similar. Acme threads generally have lower maximum force limits, but their even pressure distribution across the thread profile gives them relatively low friction - lower than the triangular profile used on nuts and bolts at least. Just replacing the scissorsjackcan be pretty cost-effective. You can probably get a matched set at a scrapyard for like five bucks each. Thanks, Bob K. http://store.williamssoaring.com/Mer...ory_C ode=TPA The only problem with the junkyard jacks is finding a PAIR that will fit between your wings when stowed in the trailer. I couldn't. I ended up buying a pair of Toyota jacks, then shortening all the parts to make a pair that would fit. They worked fine, but it took me a large part of a day to do it, and I won't do it again. Williams Soaring sells the units for $192.00 (or so) and IF I were going to use scissor jacks, that's what I'd do. However, I tested my NASCAR inspired lever jack (crude prototype) and it works nicely. Instead of getting on my knees and cranking it up, I stand up and pull on a 48 lever and raise the glider. With the fuselage empty it's quite easy. With a 240 pound pilot in the cockpit, it takes considerable (but doable by Joe Average) effort. (We didn't have adequate space to put wings on, so the pilot was substituted to simulate the weight of the wings). When in the 'down' position, the distance between the bottom of the ramp channels and the ground is slightly less than 2". When raised, it is right around 9 1/2", which should allow for removing the wheel on most gliders. |
| Thread Tools | |
| Display Modes | |
| Komet Trailer Gas Springs | P. Corbett | Soaring | 4 | March 12th 07 12:30 AM |
| Komet Trailer Rims | Tim Hanke | Soaring | 6 | February 28th 06 05:56 PM |
| Double scissor jack for trailer ramp? | Bullwinkle | Soaring | 15 | January 18th 06 06:18 PM |
| KOMET Trailer Cradle | [email protected] | Soaring | 3 | September 27th 04 05:33 AM |
| Komet trailer strut | John Shelton | Soaring | 5 | November 15th 03 06:04 PM |
