Greg Arnold wrote:
I see they want to require transponders in all gliders, with the transponders always on. Nice summary. And, in compensation we'd get the low, low transponder code of 0440 I've never heard that low codes would save power, maybe they just wouldn't ping it as often as 1200 Sarah |
On Mar 31, 6:50 pm, Sarah Anderson wrote:
Greg Arnold wrote: I see they want to require transponders in all gliders, with the transponders always on. Nice summary. And, in compensation we'd get the low, low transponder code of 0440 I've never heard that low codes would save power, maybe they just wouldn't ping it as often as 1200 Sarah Ah, that is not possible. The simple answer is all transponders seeing an interrogation signal will reply. The SSR can interrogate the transponder to send it's code (Mode A) or altitude (Mode C). There is no concept of the SSR being able to "address" a transponder. Darryl |
Darryl Ramm wrote:
On Mar 31, 6:50 pm, Sarah Anderson wrote: Greg Arnold wrote: I see they want to require transponders in all gliders, with the transponders always on. Nice summary. And, in compensation we'd get the low, low transponder code of 0440 I've never heard that low codes would save power, maybe they just wouldn't ping it as often as 1200 Sarah Ah, that is not possible. The simple answer is all transponders seeing an interrogation signal will reply. The SSR can interrogate the transponder to send it's code (Mode A) or altitude (Mode C). There is no concept of the SSR being able to "address" a transponder. I assume what the NTSB is referring to is the duty cycle of the reply transmission, I'm too tired right now to figure out the actual encoding, but if 0440 has a lower duty cycle than 1200, it will save some amount of power. How much, I don't know... Marc |
On Mar 31, 8:43 pm, Marc Ramsey wrote:
Darryl Ramm wrote: On Mar 31, 6:50 pm, Sarah Anderson wrote: Greg Arnold wrote: I see they want to require transponders in all gliders, with the transponders always on. Nice summary. And, in compensation we'd get the low, low transponder code of 0440 I've never heard that low codes would save power, maybe they just wouldn't ping it as often as 1200 Sarah Ah, that is not possible. The simple answer is all transponders seeing an interrogation signal will reply. The SSR can interrogate the transponder to send it's code (Mode A) or altitude (Mode C). There is no concept of the SSR being able to "address" a transponder. I assume what the NTSB is referring to is the duty cycle of the reply transmission, I'm too tired right now to figure out the actual encoding, but if 0440 has a lower duty cycle than 1200, it will save some amount of power. How much, I don't know... Marc Oh doh, thank you Mr. Governor. OK there is a basis to the claim, but definitely not because of differences "pinging". 0440 is just two pulses (binary 4 twice). And 1200 (binary 1 and 2) also has two pulses, and there are always two framing pulses, and maybe an ident pulse. So 1200 and 0440 should be no different in terms of radiated power. And usually every second interrogation/response is going to be an altitude code. So I guess they could pick a worse code and have several more pulses (would have to look at the map of available codes to see how bad it could be, luckily 7xxx is taken :-)) I'd be curious to see actual differences in power consumption measurements. Darryl |
Darryl Ramm wrote:
Oh doh, thank you Mr. Governor. OK there is a basis to the claim, but definitely not because of differences "pinging". 0440 is just two pulses (binary 4 twice). And 1200 (binary 1 and 2) also has two pulses, and there are always two framing pulses, and maybe an ident pulse. So 1200 and 0440 should be no different in terms of radiated power. And usually every second interrogation/response is going to be an altitude code. So I guess they could pick a worse code and have several more pulses (would have to look at the map of available codes to see how bad it could be, luckily 7xxx is taken :-)) I'd be curious to see actual differences in power consumption measurements. Uh, no Mr. Boffin, tis not quite that simple. It's been a while since I looked at this stuff, but I believe the actual transponder code is encoded using a modified Gray code (as is the altitude code), so the actual duty cycle is not quite that obvious. Second, the fashion in which the transponder code and the altitude code are transmitted differ significantly, as the transponder code portion of the transmission dates back to WW II IFF, and the Mode C stuff came much later. I doubt the NTSB would have brought it up, unless there was something to it. Personally, I'm not interested enough to try to figure it out... Marc |
Marc Ramsey wrote:
Uh, no Mr. Boffin, tis not quite that simple. It's been a while since I looked at this stuff, but I believe the actual transponder code is encoded using a modified Gray code (as is the altitude code), so the actual duty cycle is not quite that obvious. Second, the fashion in which the transponder code and the altitude code are transmitted differ significantly, as the transponder code portion of the transmission dates back to WW II IFF, and the Mode C stuff came much later. I doubt the NTSB would have brought it up, unless there was something to it. Personally, I'm not interested enough to try to figure it out... I'll take it back, Mode A and Mode C are transmitted the same way, and while altitude is Gray encoded, the squawk code is straight binary. So, I have no idea what the NTSB was talking about. Marc |
| Thread Tools | |
| Display Modes | |
| go to NTSB.GOV | [email protected] | Piloting | 0 | August 15th 05 09:34 PM |
| FAA-NTSB | [email protected] | Piloting | 4 | January 25th 05 02:34 PM |
| NTSB | EDR | Piloting | 22 | July 2nd 04 04:03 AM |
| Is the the EX-NTSB Guy? | Gig Giacona | Piloting | 2 | January 16th 04 05:01 PM |
| NTSB 830.5 & 830.15? | Mike Noel | Owning | 2 | July 8th 03 06:51 AM |
