AV gas prices
Old June 3rd 08, 04:45 AM posted to rec.aviation.homebuilt
Drew Dalgleish
Default AV gas prices
I've heard that the gravity fed fuel systems don't seem to experience the
vapor locking and I've never experienced carb ice in any vehicle but my VW.
I'd think a pressure system would be more immune than gravity fed.
Roger (K8RI) ARRL Life Member
N833R (World's oldest Debonair)
www.rogerhalstead.com
I think If it sucks it's more immune but if it blows it's less.
That's why new cars have the pump in the tank. Unfortunately most
planes don't.
  #52
Old June 3rd 08, 05:10 AM posted to rec.aviation.homebuilt
"Drew Dalgleish" wrote in message
VW.
planes don't.
My Model A Ford's gravity flow system never had problems. I have had two
fuel tank pump failures in "modern" cars.
I agree with Ronger, a gravity fuel system seems to work well in high wing
airplanes.
HP14 "Six Foxtrot"
(All fuel system problems are solved if you don't carry any fuel)
http://www.soaridaho.com/Schreder
  #53
Old June 4th 08, 05:15 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Ernest Christley wrote:
I'm going to get some 10% Ethanol Supreme and put one of my A/C
quality fuel lines in it and let it soak.
It takes time. You might run several years without problems. My Deb
has bladder tanks (Neoprene impregnated canvas I believe) they would
not stand up. The tip tanks are bare fiberglass and resin. They too
dislike Alcohol.
However the big Continental needs 100 octane.
Jim Maher ran auto-gas in his rotary powered Dyke Delta. Cranked the
engine once a month in the years that he was finishing the rest of the
plane. First flight went without a hitch. First few hours with no
problem. The he lost partial power in flight. Luckily near his home
airport. He couldn't maintain altitude, but he had time. Took it home
safely.
On inspection, the fiberglass fuel tank flaked apart and crumpled like
paper. I wasn't there. I haven't seen it. But Jim isn't the sort to
lie about these sort of things.
I believe he said he used Aeropoxy (though, don't hold me to that one).
Most epoxies will do that.
That's why vinyl ester is recommended for fuel tanks.
Some chemical resistance info he
http://www.epoxy.com/vester.htm
Lots more he
http://www.derakane.com/derakaneCont...comend ations
WHere to get some:
http://www.aircraftspruce.com/catalo...vinylester.php
  #54
Old June 5th 08, 02:58 PM posted to rec.aviation.homebuilt
Blueskies
"cavelamb himself" wrote in message ...
I'm going to get some 10% Ethanol Supreme and put one of my A/C quality fuel lines in it and let it soak.
dislike Alcohol.
Jim Maher ran auto-gas in his rotary powered Dyke Delta. Cranked the engine once a month in the years that he was
finishing the rest of the plane. First flight went without a hitch. First few hours with no problem. The he lost
partial power in flight. Luckily near his home airport. He couldn't maintain altitude, but he had time. Took it
home safely.
On inspection, the fiberglass fuel tank flaked apart and crumpled like paper. I wasn't there. I haven't seen it.
But Jim isn't the sort to lie about these sort of things.
Lots more he
100°F is the max temperature recommended for the Derakane 470 with 'gasohol' 10-100% alcohol. Don't want to be sitting
out on the ramp in Arizona with thqat stuff in the tanks...although the 470 stuff seems to be the best in there product
line for this application.
WHere to get some:
  #55
Old June 5th 08, 03:58 PM posted to rec.aviation.homebuilt
"Blueskies" wrote in message
'gasohol' 10-100% alcohol. Don't want to be sitting out on the ramp in
the best in there product line for this application.
You don't have to be in Arizona to have internal wing temps above 100°F.
http://www.soaridaho.com/Schreder/Co...olor_Temp.html
HP-14 "Six Foxtrot"
Pheobus C prices in the US? [email protected] Soaring 3 January 10th 07 06:15 PM
Gas Prices Newps Piloting 0 October 27th 05 09:17 PM
Fuel prices Paul kgyy Owning 14 October 19th 05 10:55 PM
Gas Prices -- Help at last? Jay Honeck Piloting 327 October 16th 05 01:09 PM
Gas Prices Tony Owning 19 April 16th 04 02:38 AM
