My Terra radio installation instruction says "Porper attachment of any
antenna to the aircraft surface is of primary importance. Carefull clean all paint and corrosion off the mounting surface and apply an anti-corrosion treatment." Question 1, does "clean all paint" mean strip all paint to bare aluminum? Question 2, what type of "anti-corrosion treatment" should I use? Thanks in advance, Robin Hou |
In article
, " wrote: My Terra radio installation instruction says "Porper attachment of any antenna to the aircraft surface is of primary importance. Carefull clean all paint and corrosion off the mounting surface and apply an anti-corrosion treatment." Question 1, does "clean all paint" mean strip all paint to bare aluminum? Question 2, what type of "anti-corrosion treatment" should I use? Thanks in advance, Robin Hou The antenna MUST have a good electrical contact with the aluminum, in order to have a ground plane. You might get by if you strip the aluminum at the bolt holes on the inside of the aircraft, as the ground gets contact through those bolts. Alodine is a good anticorrosion treatment. Be sure to make provision to keep any water away from the antenna/airframe contact. -- Remove _'s from email address to talk to me. |
Remove paint which includes primer to the bare metal...
Wipe the metal with an aluminum prep.. Then install the antenna... Now, some details where the devil lives of how "I" do it... You can put a tape dam outlining the area of the base of the antenna... Make the area of the dam just slightly smaller than the base of the antenna so there is a thin rim of paint projecting under the base - 1/4" will work... Thin line striping tape from the auto body store works like gangbusters... Then tape a plastic bib around that to protect the sorrounding paint... Then remove paint and primer inside the dam with a paint stripper... Do not sand or abrade the exposed metal because you will scratch through the cladding (the thin outer surface of pure aluminum that protects the aluminum alloy from oxygen and water)... Then put a thin smear of NOALOX on the exposed metal and install your antenna... It also will not hurt to put a thin layer of non hardening gasket on the paint rim to seal against water intrusion - Permatex FORM-A-GASKET #2 has always worked for me... Work carefully and be neat... Once the antenna is installed than use a rag with a bit of mineral spirits to clean up the Permatex that squeezes out... Now on the inside of the skin where the clamp plate squeezes the metal, also take that area back to bare metal... No need to leave a rim of primer here (dry interior)... Just a dab of NOALOX and you are good to go... denny |
Except for the fact that the antenna ships with a thin rubber gasket to keep
water out of the airframe (and insulates the antenna from the airframe mechaincally). The antenna "grounds" to the airframe mechanically through the three bolts holding it to the airframe. Make sure that they are cutting through to the metal of the antenna base/airframe. Electrically, the antenna is connecting to the airframe through the capacitor formed by the base of the antenna to the airframe with the rubber gasket as the dielectric. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Denny" wrote in message ... Remove paint which includes primer to the bare metal... Wipe the metal with an aluminum prep.. Then install the antenna... Now, some details where the devil lives of how "I" do it... You can put a tape dam outlining the area of the base of the antenna... Make the area of the dam just slightly smaller than the base of the antenna so there is a thin rim of paint projecting under the base - 1/4" will work... Thin line striping tape from the auto body store works like gangbusters... Then tape a plastic bib around that to protect the sorrounding paint... Then remove paint and primer inside the dam with a paint stripper... Do not sand or abrade the exposed metal because you will scratch through the cladding (the thin outer surface of pure aluminum that protects the aluminum alloy from oxygen and water)... Then put a thin smear of NOALOX on the exposed metal and install your antenna... It also will not hurt to put a thin layer of non hardening gasket on the paint rim to seal against water intrusion - Permatex FORM-A-GASKET #2 has always worked for me... Work carefully and be neat... Once the antenna is installed than use a rag with a bit of mineral spirits to clean up the Permatex that squeezes out... Now on the inside of the skin where the clamp plate squeezes the metal, also take that area back to bare metal... No need to leave a rim of primer here (dry interior)... Just a dab of NOALOX and you are good to go... denny |
RST Engineering wrote:
Except for the fact that the antenna ships with a thin rubber gasket to keep water out of the airframe (and insulates the antenna from the airframe mechaincally). The antenna "grounds" to the airframe mechanically through the three bolts holding it to the airframe. Make sure that they are cutting through to the metal of the antenna base/airframe. Electrically, the antenna is connecting to the airframe through the capacitor formed by the base of the antenna to the airframe with the rubber gasket as the dielectric. Jim Effectively, the capacitor Jim mentions is shorted by the three/four mounting bolts, so the mounting bolts must make a good electrical contact with the aluminum skin on the inside of the aircraft. I like the NoAlOx, too. Dont forget a doubler plate. Mounting the antenna directly only to the aircraft skin is a no-no. On the off chance you are using just a stainless whip mounted on the porcelin feed-thru bushing, then the coax cable shield needs to be grounded to the aircraft skin within an inch or two from the antenna base, and the coax center conductor connects to the whip. |
Would that it were true, Mike. That nice tough epoxy paint on the antenna
and the nice smooth side of the head of a flathead screw rarely cuts through to the metal of the antenna base. If you don't know the trick of grinding down the paint inside the screw well to bare antenna base metal, those screws aren't going to short anything out. Jim Effectively, the capacitor Jim mentions is shorted by the three/four mounting bolts, so the mounting bolts must make a good electrical contact with the aluminum skin on the inside of the aircraft. I like the NoAlOx, too. |
| Thread Tools | |
| Display Modes | |
| Antenna install | [email protected] | Piloting | 5 | May 26th 08 04:48 PM |
| Can't install FSX | Blue | Simulators | 6 | November 22nd 06 10:42 PM |
| 430 install price | Robert M. Gary | Piloting | 5 | October 7th 06 06:52 PM |
| New Lycoming Install | Evan Carew | Home Built | 2 | October 9th 04 05:10 AM |
| 337 to install a transponder? | Jay Honeck | Owning | 25 | December 22nd 03 11:31 PM |
