CFI oral intel
"Michael Ash" wrote in message
... In rec.aviation.student gatt wrote: A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" In addition to all the other factors discussed, your airspeed will be slightly lower than what you had trimmed due to the weight of your soul departing the aircraft. OK, so I don't really believe that, but I'd love to see what the guy would say if you told him that answer! Your airspeed may also be slightly lower due to the weight of the fuel that has departed the aircraft (through the engine) |
CFI oral intel
Everyone who has replied has made one significant and incorrect assumption.
I would have replied, "Really really fast, yellow arc at least, perhaps at or above Vne depending on the aircraft." Why? Because all posts have made the (probably) incorrect assumption that the aircraft somehow fly wings-levels to its demise. That just won't happen. Forget dihedral, that won't stop it going into a spiral. Another factor worth considering is that when the pilot dies, there is a really good chance that the pilot will fall forward and possibly push on the yoke. With a side stick, this will probably cause a bank as the pilot pulls sideways on the stick. Anyway, my point is, is that since no wings leveler or autopilot was mentioned, it is almost guaranteed that the aircraft would enter a spiral and trim speed does not apply in a spiral. Hilton "gatt" wrote in message . .. One of the folks around the hangar took his CFI practical last week. He had his AGI so they threw out all of the Fundamentals of Instruction stuff entirely during the oral. A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" Another was, "You're turning final and you enter a cross-control stall. Is it better to be in a slip, or a skid?" -c |
CFI oral intel
Hilton wrote:
Everyone who has replied has made one significant and incorrect assumption. I would have replied, "Really really fast, yellow arc at least, perhaps at or above Vne depending on the aircraft." Why? Because all posts have made the (probably) incorrect assumption that the aircraft somehow fly wings-levels to its demise. That just won't happen. Forget dihedral, that won't stop it going into a spiral. Another factor worth considering is that when the pilot dies, there is a really good chance that the pilot will fall forward and possibly push on the yoke. With a side stick, this will probably cause a bank as the pilot pulls sideways on the stick. Anyway, my point is, is that since no wings leveler or autopilot was mentioned, it is almost guaranteed that the aircraft would enter a spiral and trim speed does not apply in a spiral. Hilton "gatt" wrote in message . .. One of the folks around the hangar took his CFI practical last week. He had his AGI so they threw out all of the Fundamentals of Instruction stuff entirely during the oral. A question the examiner asked him: "You're flying cross-country and trimmed at 110 knots. You die, and the engine quits. At what airspeed will the aircraft strike the ground?" Another was, "You're turning final and you enter a cross-control stall. Is it better to be in a slip, or a skid?" -c Really getting nitty here Hilton :-) With the engine dead, and assuming good rigging, there is no specific reason to assume a spiral. The initial question specified the engine "quit". Again, assuming proper trim and no aerodynamic forces to induce bank, the aircraft for all practical purposes anyway, can be assumed a straight path into the ground. Take out the proper trim and an idling engine and perhaps you have a case for a spiral. Also, few aircraft are rigged perfectly so that also could be a factor for a spiral. Other than these things being present and considering the "spirit" of the question, trim speed would be the answer for ground impact in my opinion. -- Dudley Henriques |
CFI oral intel
Dudley Henriques wrote: Really getting nitty here Hilton :-) With the engine dead, and assuming good rigging, there is no specific reason to assume a spiral. The initial question specified the engine "quit". Again, assuming proper trim and no aerodynamic forces to induce bank, the aircraft for all practical purposes anyway, can be assumed a straight path into the ground. Take out the proper trim and an idling engine and perhaps you have a case for a spiral. Also, few aircraft are rigged perfectly so that also could be a factor for a spiral. Turbulence would increase the likelihood of a spiral departure from level flight, wouldn't it? Other than these things being present and considering the "spirit" of the question, trim speed would be the answer for ground impact in my opinion. |
CFI oral intel
Steve Hix wrote:
In article , Dudley Henriques wrote: Really getting nitty here Hilton :-) With the engine dead, and assuming good rigging, there is no specific reason to assume a spiral. The initial question specified the engine "quit". Again, assuming proper trim and no aerodynamic forces to induce bank, the aircraft for all practical purposes anyway, can be assumed a straight path into the ground. Take out the proper trim and an idling engine and perhaps you have a case for a spiral. Also, few aircraft are rigged perfectly so that also could be a factor for a spiral. Turbulence would increase the likelihood of a spiral departure from level flight, wouldn't it? Other than these things being present and considering the "spirit" of the question, trim speed would be the answer for ground impact in my opinion. Yes. Anything that changed the basic balance equation that was in effect when the trim was set would do that. -- Dudley Henriques |
CFI oral intel
On May 30, 3:36*am, "Hilton" wrote:
Why? *Because all posts have made the (probably) incorrect assumption that the aircraft somehow fly wings-levels to its demise. *That just won't happen. *Forget dihedral, that won't stop it going into a spiral. You're right, of course. The only way that will happen is with artificial stability augmentation (a single axis autopilot). With a two axis autopilot the plane will hit at stall speed. It may or may not be wings level, depending on the stall characteristics. See, this is what made the question such a good one. It allows lots of room to explore different aspects of aerodynamic stability. Michael |
CFI oral intel
Michael wrote:
On May 30, 3:36 am, "Hilton" wrote: Why? Because all posts have made the (probably) incorrect assumption that the aircraft somehow fly wings-levels to its demise. That just won't happen. Forget dihedral, that won't stop it going into a spiral. You're right, of course. The only way that will happen is with artificial stability augmentation (a single axis autopilot). With a two axis autopilot the plane will hit at stall speed. It may or may not be wings level, depending on the stall characteristics. See, this is what made the question such a good one. It allows lots of room to explore different aspects of aerodynamic stability. Michael I would respectfully disagree with you and Hilton on this one :-)There should be no "of course" and no autopilot issues are involved in the question that I can see. The aircraft, if in trim at 110 kts will be trimmed for whatever angle of attack is producing that airspeed. Unless there is something added to the problem and assuming all factors normal with balance and stability issues, what should be expected normally is a phugoid starting nose low as the engine quits to recover the trim speed. I'm assuming no fuel imbalance or rigging issues that could cause a bank input entry into the problem. So using just the aspects of the problem as presented; Where the aircraft is along that phugoid and the exact airspeed to expect at ground impact would depend on the altitude remaining and the dampening properties present determining the decreasing phases of the phugoid. Just what is it that you are expecting to happen to cause the necessary bank/lift imbalance to enter a nose low spiral? -- Dudley Henriques |
CFI oral intel
On May 30, 2:47*pm, Dudley Henriques wrote:
Just what is it that you are expecting to happen to cause the necessary bank/lift imbalance to enter a nose low spiral? Well, I am expecting normal behavior for a light airplane. Most light airplanes have approximately neutral static and weakly negative dynamic lateral (roll) stability. Thus, if left with no pilot input, they will eventually roll into a turn. Maintaining AOA (which the trim will do) will result in the increased airspeed. Now the real question is why this is the case. Airplanes could be built with positive dynamic lateral stability, and in fact ram-air (square) parachutes (powered and unpowered) are built that way, which is what makes it possible for them to be flown through clouds (absent the legalities) with no gyros at all. However, airplanes are generally not built that way. It's been tried before, and the results were generally unsatisfactory. Making the airplane too stable also made it too sluggish, and because of the yaw-roll coupling involved gave it a really nasty ride in turbulence. A pretty good primer on stability issues can be found he http://selair.selkirk.bc.ca/aerodyna...ity/Page5.html Michael |
CFI oral intel
Michael wrote:
On May 30, 2:47 pm, Dudley Henriques wrote: Just what is it that you are expecting to happen to cause the necessary bank/lift imbalance to enter a nose low spiral? Well, I am expecting normal behavior for a light airplane. Most light airplanes have approximately neutral static and weakly negative dynamic lateral (roll) stability. I would respectfully disagree. An Extra 300, as do most high performance aerobatic airplanes has neutral static stability, but your vanilla Cessna or Piper with dihedral is designed with positive static stability in mind. Even a high wing Cessna like the 190 or 195 with little dihedral has positive static stability due to wing position. High performance airplanes like a Pitts or Extra have neutral static stability. As for dynamic stability, it really isn't much of a factor in lateral stability. The ailerons if mass balanced around the hinge line by weight, and if comparatively free in movement, usually assure that the pure lateral movement is heavily damped. However, cross effects in yaw displacement can result in lateral oscillations and Dutch Roll. I totally agree that excessive dihedral is bad. It works against good rolling qualities and as you say, makes for an overly stable aircraft. It's for this reason that airplanes requiring a fast roll rate like the Extra or a fighter for example, don't have excessive dihedral. Thus, if left with no pilot input, they will eventually roll into a turn. Remember, we're dealing here with a dead engine. I'm still going to stick with the spiel :-)) that says with a light GA airplane with positive lateral stability built in with the normal dihedral found on such airplanes and the engine dead, we're going to need a source for an outside the system force strong enough to offset the countering dihedral to any roll input to initiate the roll or yaw (or coupling if you wish) that would end up with the aircraft banked enough to counter the dihedral correcting it back into the normal phugoid I'm expecting. Now the real question is why this is the case. Airplanes could be built with positive dynamic lateral stability, If the aircraft has dihedral, it has positive static lateral stability. I don't see dynamic lateral stability as an issue here. and in fact ram-air (square) parachutes (powered and unpowered) are built that way, which is what makes it possible for them to be flown through clouds (absent the legalities) with no gyros at all. That's interesting. I never knew that. I knew Steve Snyder quite well. I believe Steve had something to do with the design of the square chute. I know he designed the sentinel as well as a thousand other things related to parachuting. Quite a guy. I miss him. He morted in his F86 a while back. Making the airplane too stable also made it too sluggish, and because of the yaw-roll coupling involved gave it a really nasty ride in turbulence. I completely agree. A pretty good primer on stability issues can be found he http://selair.selkirk.bc.ca/aerodyna...ity/Page5.html I know the site. His stuff is generally very good. I do have some very minor issues with his presentation on a few things. DH Michael -- Dudley Henriques |
CFI oral intel
On 2008-05-30, Michael wrote:
the legalities) with no gyros at all. However, airplanes are generally not built that way. It's been tried before, and the results were generally unsatisfactory. Well, unless you consider a Champ unsatisfactory! This one flew for two hours sans pilot, after it was hand propped with the throttle wide open: http://www.ntsb.gov/ntsb/brief.asp?e...28X02460&key=1 There was another one in similar circumstances which I think was is Illinois, which flew until it ran out of fuel. I think that may have been a Taylorcraft - it made what looked like a passable forced landing into a cornfield. -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
Similar Threads | ||||
U.S. Navy Plans EPX Intel-Gathering Aircraft | [email protected] | Naval Aviation | 0 | February 23rd 08 02:38 AM |
FOI...lol... CFI oral? | gatt[_2_] | Piloting | 29 | January 5th 08 05:01 PM |
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software | Ruud | Soaring | 1 | October 31st 06 01:02 AM |
INTEL BILL CON JOB | Cribsheet | Piloting | 0 | December 7th 04 05:40 PM |
