Towing with a Husky
Old June 10th 08, 03:44 PM posted to rec.aviation.soaring
BDS[_2_]
Default Towing with a Husky
Our club has a Husky on leaseback as one of our tow planes.
In order to keep the temps within desired limits on the Husky (I think they
shoot for 425 cht max) we have to tow at higher speeds than would be typical
for say, a Pawnee. This isn't necessarily a problem for glass ships but it
is for our 2-33s which we end up towing at speeds as high as 80-90 mph.
Does this seem typical for those of you who might also be using a Husky as a
tow plane? If not, what speeds are you able to tow a 2-33 at and what temps
are you typically seeing?
Thanks.
BDS
Old June 10th 08, 04:19 PM posted to rec.aviation.soaring
sisu1a
Thanks.
BDS
At our club we use a C 150 with a 180hp motor, and have the sane
problem. The 180/150 is so tightly cowled it also has to tow the
club's 2-33 at 80-90mph as well( try boxing the wake at those
speeds...). However, we sometimes have a fellow that brings in a Husky
to tow, and behind him a 2-33 can tool along at a much more tame
50-60mph. Field elevation is only 790', so our density altitudes are
not very high. Under those conditions the Husky seems to work just
fine other than kicking up a giant dustball to fly through (IFR
takeoff- I Follow Rope) on our dirt airfield due to being a
taildragger.
Paul
Old June 10th 08, 06:11 PM posted to rec.aviation.soaring
Darryl Ramm
Thanks.
BDS
BTW just by way of comment, there is a "cooling lip" option on current
Husky's that claims to reduce CHT's 10-15F.
Darryl
Old June 11th 08, 09:16 PM posted to rec.aviation.soaring
Andy[_1_]
tow plane? *If not, what speeds are you able to tow a 2-33 at and what temps
Sorry no time on the front of the rope with a Husky, lots of tows on
the other end and also flying one without the rope.
Bob Lynn has years of experience towing with 180 and more recently the
200 hp Husky. He's a regular tow pilot at SW USA contests. He may be
able to advise you. http://lynn.org/
Do you run full takeoff power for the whole tow or reduce power?
Andy
Old June 11th 08, 09:45 PM posted to rec.aviation.soaring
BDS[_2_]
Thanks for the replies thus far. In answer to your question, I was told
they are running at full power and full forward on the prop for the entire
tow.
I have sent an email to Bob to see what he has to say as well.
BDS
"Andy" wrote...
a
temps
Andy
EAA Husky [email protected] Piloting 4 November 17th 06 04:53 PM
Husky as a tow plane? bumper Soaring 6 August 24th 05 02:23 AM
Amphib Husky for Sale Doug Aviation Marketplace 0 April 22nd 05 08:04 PM
Amphib Husky For Sale [email protected] Aviation Marketplace 0 January 23rd 05 11:56 PM
Amphibian Aviat Husky Doug Aviation Marketplace 0 November 22nd 04 07:03 AM
