Best homebuilt for ~700 nm commute
On Jul 7, 1:48�am, es330td wrote:
Are there any good alternatives outside the canard family? Check out the Tango 2 at www.teamtango.com. The standard configuration carries 58 gallons which will give you an approximate 1,100 nm ifr range at 175-180 KTAS. You can go with the 90 gallon full wet wing and make your 1,400 nm round trip without refueling, or fly LAX-to-JAX nonstop if you can stand it. Useful load is 800lb or 1,000 with the wet wing. Basically, it will carry what ever you can pack in for luggage. I have an older version with 40 gallon tanks and consider 750 nm a comfortable day vfr range, no wind. I have several trips over 800 nm, with some tail wind, burning 33-35 gallons. The owner of the first wet wing airplane has one trip of 1,540 nm on 65 gallons. I just passed 1,550 hours in my airplane, N99GE, using it primarily for business trips, many matching your profile. I average about 7.5 gallons per hour, switch on to switch off. I routinely operate off a grass strip. The panel is big enough to put in about anything you want or can afford. Our EFIS 1200 has been popular. We are currently fitting up the first airplane with Precise Flight speed brakes, which been a perfect fit. We are testing an affordable laser horizon line, like the SR-71 used to have. I am now flying with our new plenum chamber for engine cooling, which is working almost too well, giving CHTs in the low 300s. Autopilots are optional. Denny Funnemark Team Tango |
On Jul 7, 8:17Â*am, denny wrote:
On Jul 7, 1:48�am, es330td wrote: Are there any good alternatives outside the canard family? Â* Â* Â*Check out the Tango 2 atwww.teamtango.com. Â*The standard configuration carries 58 gallons which will give you an approximate 1,100 nm ifr range at 175-180 KTAS. Â*You can go with the 90 gallon full wet wing and make your 1,400 nm round trip without refueling, or fly LAX-to-JAX nonstop if you can stand it. Â*Useful load is 800lb or 1,000 with the wet wing. Â*Basically, it will carry what ever you can pack in for luggage. Â*I have an older version with 40 gallon tanks and consider 750 nm a comfortable day vfr range, no wind. Â*I have several trips over 800 nm, with some tail wind, burning 33-35 gallons. Â*The owner of the first wet wing airplane has one trip of 1,540 nm on 65 gallons. Â* Â* Â*I just passed 1,550 hours in my airplane, N99GE, using it primarily for business trips, many matching your profile. Â*I average about 7.5 gallons per hour, switch on to switch off. Â*I routinely operate off a grass strip. Â* Â* Â*The panel is big enough to put in about anything you want or can afford. Â*Our EFIS 1200 has been popular. Â*We are currently fitting up the first airplane with Precise Flight speed brakes, which been a perfect fit. Â*We are testing an affordable laser horizon line, like the SR-71 used to have. Â*I am now flying with our new plenum chamber for engine cooling, which is working almost too well, giving CHTs in the low 300s. Â*Autopilots are optional. Denny Funnemark Team Tango This looks like a great plane and well within my idea of a reasonable budget with full IFR avionics installed. Reading your review really piqued my interest; I grew up in San Antonio, TX, within sight distance of the flight patterns for Randolph AFB where the T-38s flew while I was growing up. I loved watching them fly and while I will never get to fly a T-38/F-5 the fact that someone who has thinks so highly of this plane definitely makes me interested in the Tango 2. |
"es330td" == es330td writes:
es330td As I have past es330td experience as an auto mechanic, being able to work on the es330td plane to keep costs down is important so I'm going to es330td have to go with something I build myself. Just curious, any build will take a year or two at least, will you have time for this living away from home? -- Mom always told me I could be whatever I wanted to be when I grew up, 'within reason.' When I asked her what she meant by 'within reason,' she said, 'You ask a lot of questions for a garbage man.' - Jack Handey |
On Jul 7, 6:32*pm, Bob Fry wrote:
Just curious, any build will take a year or two at least, will you have time for this living away from home? -- Living by myself, I think I should. I am assuming that the time I spend now on the "honey-do" list at home (lawn, dishes, errands) will be mine since I simply won't be there. I usually spend an hour or so each night playing with my kids so I get that time back too. I am most likely going to go with something that is kit built, rather than plans built, to reduce my build time. I am not going to be one of the homebuilders that in reality pays somebody to build a plane but I am going to base my choice in part on getting one that I can buy major pieces already constructed so this rules out the Cozy. I know someone at both airports who is an A&P mechanic so I'll have expertise available for hire as needed. Even if it takes me 3 years, I still get an airplane at the end of it. |
"es330td" wrote in message
... On Jul 7, 6:32 pm, Bob Fry wrote: Just curious, any build will take a year or two at least, will you have time for this living away from home? -- Living by myself, I think I should. I am assuming that the time I spend now on the "honey-do" list at home (lawn, dishes, errands) will be mine since I simply won't be there. I usually spend an hour or so each night playing with my kids so I get that time back too. I am most likely going to go with something that is kit built, rather than plans built, to reduce my build time. I am not going to be one of the homebuilders that in reality pays somebody to build a plane but I am going to base my choice in part on getting one that I can buy major pieces already constructed so this rules out the Cozy. I know someone at both airports who is an A&P mechanic so I'll have expertise available for hire as needed. Even if it takes me 3 years, I still get an airplane at the end of it. ___________new messages begins___________ It appears that you might be moving both to and from locations with multiple EAA chapters, and they are a very good source of second hand experience. Visit each chapter a couple of times; because every member does not attend every meeting. You can then gain a lot of additional information by visiting some of the builders and/or participating in the chapter's "hangar invasions". As to some of wheat you might look for: 1 Kits are not all equal--some kits take more time than some plans and some need different kinds of workspace. 2 Builders are not all equal--both skills and priorities vary. Some builders have good three dimensional thinking and manufacturing skills--and they can build a good solid aircraft in a few hundred hours. Others will spend a tremendous amount of time staring at the project and reinventing one wheel after another--so that the project takes thousands of hours if it is ever finished. All the best for your project--even if you only buy a slower airplane are convert part of what would have been your building time to be used as commuting time instead. Peter |
es330td wrote:
On Jul 7, 6:32 pm, Bob Fry wrote: Just curious, any build will take a year or two at least, will you have time for this living away from home? -- Living by myself, I think I should. I am assuming that the time I spend now on the "honey-do" list at home (lawn, dishes, errands) will be mine since I simply won't be there. I usually spend an hour or so each night playing with my kids so I get that time back too. I am most likely going to go with something that is kit built, rather than plans built, to reduce my build time. I am not going to be one of the homebuilders that in reality pays somebody to build a plane but I am going to base my choice in part on getting one that I can buy major pieces already constructed so this rules out the Cozy. I know someone at both airports who is an A&P mechanic so I'll have expertise available for hire as needed. Even if it takes me 3 years, I still get an airplane at the end of it. That last sentence you wrote is as close as I've seen you say the one thing you need to say before you start a build project but it isn't quite there yet. Building itself needs to be one of your goals otherwise you probably won't ever finish and then at the end of 3 years you will have a pile of very expensive aluminum. The old saying "If you want to build, build. If you want to fly, buy." is as true as it ever was even if the quick build kits make the building easier. |
I Are there any good alternatives outside the canard family? This discussion seems to have come down to whether you should build with aluminum or composites, leaving out wood and tube & fabric. The way I see it, if you build your own composite airplane, you are the manufacturer and should be pretty good at repairing hanger rash by the time you are ready to fly. I know of at least one compostite airplane that flipped over and was damaged, as one would expect. The spar and wings were intact. The insurance adjuster said repair it. Had it been an aluminum airplane he would have scrapped it. What does all this prove? Not much. If one method was clearly superior, the other would disappear. Sunlight may not bother aluminum, but corrosion sure does. Until we start mining nonobtainium, you're stuck with compromises. Take your pick. More important in picking your plane is your mission requirement. When you start your IFR training you will find the true meaning of the old saying "The only time you can have too much fuel on board is when you are on fire". You need to plan on at least a 20 knot headwind for some of those trips to TX, sometimes both ways, (like the day you actually get to go). If the destination is imc, you need altenate fuel plus 45 minute reserve (minimum). If you have a barely 700 nm, no wind, VFR range, you will need to make an enroute fuel stop on some trips. A five hour duration becomes more like three if you have to plan the whole trip IFR. Better to land with two hours fuel in your tanks than zero while diverting. Fuel exhaustion is still a leading cause of accidents. Your four hour trip just became closer to six. Good luck in your research. Denny |
"John Smith" wrote Have you given Budd Davidson's BEARHAWK a look? http://www.bearhawkaircraft.com/ The problem is that you have to be using the 260 HP engine to get that 150 MPH, where you could be doing closer to 200 MPH (or more) on a 180 HP engine. With fuel prices, that would be a significant difference. -- Jim in NC |
" With fuel prices, that would be a significant difference. -- Jim in NC Following that I would suggest Airtran to DFW. They can handle almost any weather that you couldn't and a ticket is about the same as 25 gal of avgas. Alot more practical and a lot less likely to make a smoking hole due to got to get there pressure. If you want to fly a homebuilt do it, just don't try to reliably commute in it. My 2 cents worth. Jim Stockton |
Similar Threads | ||||
An Icy Commute | Michelle P | Piloting | 12 | December 7th 05 03:50 AM |
Fox Homebuilt | [email protected] | Home Built | 0 | December 3rd 05 01:58 AM |
Big guy considering a homebuilt... | Rutger | Home Built | 3 | August 11th 04 05:57 PM |
OT? write-offs for business commute | Chad Munroe | General Aviation | 10 | January 16th 04 01:02 AM |
OT? write-offs for business commute | Chad Munroe | Piloting | 8 | January 16th 04 01:02 AM |
