Russian Air Force may receive fifth-generation fighter in 2013
Old July 11th 08, 06:28 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Mike[_7_]
Default Russian Air Force may receive fifth-generation fighter in 2013
ZHUKOVSKY (Moscow Region), July 7 (RIA Novosti) - Russia is expecting
a new fifth-generation fighter to enter service in 2013, the Air Force
commander said on Monday.
"We will begin test flights [of the new fighter] in 2009, and hope to
receive the aircraft in 2013," Col. Gen. Alexander Zelin said.
The new fighter aircraft, tentatively designated as the Sukhoi PAK FA
or T-50, will be built at the Komsomolsk-on-Amur aircraft
manufacturing plant in Russia's Far East.
The T-50 fighter, equipped with two powerful engines with thrust
vectoring, will feature high maneuverability and stealth to ensure air
superiority and precision in destroying ground and sea targets.
Some experts believe the PAK FA fighter has been designed to be
comparable to both the American F-22 Raptor and F-35 Lightning II.
It will eventually replace the MiG-29 Fulcrum and Su-27 Flanker
fighters in the Russian Air Force and will be exported to other
countries.
Old July 11th 08, 06:56 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
countries.
Interesting, it hasn't even flown yet and is at least two years late.
Typical Russian
http://en.rian.ru/russia/20071206/91196743.html
Russia to test fifth-generation fighter in 2009
16:52 | 06/ 12/ 2007
LANGKAWI, December 6 (RIA Novosti) - Flight tests of a fifth-
generation Russian-Indian fighter will begin as early as 2009 and mass
production of the aircraft may start by 2015, the Sukhoi aircraft
maker said Wednesday.
A Russian-Indian advanced multirole fighter is being developed from a
Russian prototype by Sukhoi, which is part of Russia's United Aircraft
Corporation (UAC), and India's Hindustan Aeronautics Limited, under an
intergovernmental agreement signed in October.
"At present we are building prototypes of the fifth-generation fighter
and will soon start preparation for flight-testing, which is planned
for 2009," Sukhoi CEO Mikhail Pogosyan announced at the Langkawi
International Maritime and Aerospace (LIMA) 2007 exhibition in
Malaysia.
Pogosyan said mass production of the future fighter could begin by
2015.
The new fighter aircraft, which will feature high maneuverability and
stealth to ensure air superiority and precision in destroying ground
and sea targets, will be built at the Komsomolsk-on-Amur aircraft-
Discussing the future implementation of the Russian-Indian project,
Pogosyan said joint efforts should be focused on three areas:
coordination of technical specifications, application of advanced
technologies, and preparation of a legal framework for future
cooperation.
"We have conducted preliminary discussions on these issues and now we
have to work out a detailed program for the implementation of the
[fifth-generation fighter] project," the official said.
India and Russia have a long history of military cooperation, going
back almost half a century. The existing Russian-Indian military-
technical cooperation program, which lasts until 2010, lists up to 200
projects worth about $18 billion in all, according to Russia's defense
ministry.
Old July 11th 08, 10:14 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
eyeball
countries.
Will this be before or after the USAF announces the beginning phases
of a search for it's SIXTH gen fighter?
Old July 12th 08, 08:06 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Ian B MacLure
Mike wrote in news:429d734c-7a9e-41eb-acd2-
[snip]
So will it have the avionics a 5G aircraft needs or is it simply
another wowee airframe?
IBM
Old July 12th 08, 09:15 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eunometic
This is actually total vindication of the F-22 concepts. Congress
better keep production lines open or make sure a follow on aircraft is
funded.
countries.
Old July 12th 08, 03:28 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Mark Test
"Jack Linthicum" wrote in message
countries.
Typical Russian
The russians are also late on the delivery of India's Akula IIRC....
** Posted from http://www.teranews.com **
Old July 13th 08, 05:13 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
David E. Powell
This is actually total vindication of the F-22 concepts. * Congress
funded.
countries.
Outspend em again?
Old July 13th 08, 06:48 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Eunometic
On Jul 13, 2:13 pm, "David E. Powell"
On Jul 12, 4:15 am, Eunometic wrote:
SNIP
Outspend em again?
Ultimately that's what it often gets down to. It is best to produce a
cost effective aircraft.
I think it was correct to make the bold decision to produce a stealthy
air superiority fighter. The appropriate work had been done in the
Have Blue program and experience had been gained with the F-117.
Aiming higher rather than lower was appropriate. The F-15 and to a
lessor extent F-16 were still outstanding aircraft with outstanding
radar and missiles that were in the same performance league as the Su
27 series and the MiG 29. What slight advantages these soviet
aircraft might have had in some areas in some variants of the aircraft
(helmet queuing of infrared missiles, miniature canards and thrust
vectoring for super maneuverability in some small production run odd
ball versions of that aircraft were not a decisive advantage. All of
these features were adaptable to the F-15 should it have been desired
and indeed all of them were at one point. Upgrading F-15 radars
(such as the AESA radars) or adding thrust vectoring still gives the
USAF one of the finest aircraft in the world. The USAF could afford
to gamble on the F-22. The aircraft is proving to be no more
expensive than an Eurofighter typhoon. In the end all of the fart
arseing around on the Su-27 and MiG 29 series to make them outstanding
dogfighters was a mere distraction from the reality that the new
generation of Soviet aircraft was going to be engaged and and
destroyed by stealthy aircraft at ranges well before a dogfight could
take place.
By the time the new generation of stealthy soviet aircraft go to
market in 5 or more like it 8 years time the F-22 will have radar
upgrades and probably upgrades to its thrust vectoring nozzles and
flight control software
Old July 15th 08, 11:05 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Vaughn Simon
"David E. Powell" wrote in message
Outspend em again?
That will probably never happen again. Russia is quickly becoming an
important oil exporter.
Vaughn
Old July 17th 08, 11:45 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
JG
On Jul 11, 12:56 pm, Jack Linthicum
countries.
Typical Russian
Its taking longer for their Indian correspondents to gather the
designs and software from US "sources"...JG
New Russian fighter...wow! Ricky Piloting 25 March 21st 08 01:42 AM
New Russian Fighter? [email protected] Piloting 9 March 15th 08 01:13 PM
What is a nth Generation fighter? Tom Nealon Military Aviation 64 December 17th 03 10:18 PM
Russian Fighter Book Charles Talleyrand Military Aviation 11 September 13th 03 08:21 PM
Joint Russian-French 5th generation fighter? lihakirves Military Aviation 1 July 5th 03 01:36 AM
