http://www.canadabizmart.com/bootstr...ockpit-photos/
This web site has some nice pictures of aircraft cockpits, including two gliders. If you scroll down you will find an LS-4 flying inverted. What caught my eye is that there appears to be four (4) varios in the instrument panel. My soaring friends have been scratching our heads trying to understand why you would ever need four varios in a single glider. Can anyone give some valid reasons why this would be useful? Thanks, John DeRosa |
On Jul 16, 10:57*am, ContestID67 wrote:
http://www.canadabizmart.com/bootstr...ectacular-cock... This web site has some nice pictures of aircraft cockpits, including two gliders. *If you scroll down you will find an LS-4 flying inverted. What caught my eye is that there appears to be four (4) varios in the instrument panel. *My soaring friends have been scratching our heads trying to understand why you would ever need four varios in a single glider. Can anyone give some valid reasons why this would be useful? Thanks, John DeRosa Hmm looks like he has a Peschges VP4 installed which would account for three of the four varios. The VP4 has a vario, and a speed to fly output. I think those are the 2 top ones. So in essence there are only 2 vario systems installed in the LS. One electronic, and one manual. Pete |
ContestID67 wrote:
What caught my eye is that there appears to be four (4) varios in the instrument panel. Hmm, I only see three. Still, seems a bit much. I usually fly with the electric and one mechanical. I'm interested in hearing rationale for more than that. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...aring/200807/1 |
Kloudy wrote:
What caught my eye is that there appears to be four (4) varios in the instrument panel. Hmm, I only see three. Duuuh. I see the Peschges now. -- Message posted via http://www.aviationkb.com |
Not at all. I fly with one mechanical (in case of battery failure) and two electric -- a 302 that is my backup logger, and an LX7007 that is my primary. The mechanical uses pure TE compensation, of course. The 302 is set to netto compensation, the LX's to relative netto. So while there are three varios, there is no redundant information. ~ted/2NO |
Just a thought - why would you install a mechanical vario in a new glider? (flame suit on)
Just thinking - you can easily have two completely separate electrical systems. Solar panels are expensive, but not relative to the cost of all that carbon. It causes all sorts of nasty interference mixing capacity flasks and transducer varios on a single TE probe. So why would you not have two electronic varios - there is so much more you can do with them. They have no- or virtually no moving parts to wear, and they are in my experience faster and more accurate. So why install mechanical varios in a new high tech glide? Convince me. Bruce Tuno wrote: I only see three. Still, seems a bit much. Not at all. I fly with one mechanical (in case of battery failure) and two electric -- a 302 that is my backup logger, and an LX7007 that is my primary. The mechanical uses pure TE compensation, of course. The 302 is set to netto compensation, the LX's to relative netto. So while there are three varios, there is no redundant information. ~ted/2NO |
Well, to tell you the truth, my "mechanical" vario, isn't -- it's a
B40 (electric), that lets me switch to an internal battery if I have a problem with the main batteries, bus, or fuse. But it was mechanical in my last glider -- a Sage that came with the V2C. 2NO |
On 16 Jul, 20:37, Bruce wrote:
So why install mechanical varios in a new high tech glide? Convince me. How well do electric ones react to nearby lightning bolts? Apart from that, isn't it an awful lot easier to fit a mechanical vario than it is to fit a complete second electrical system? Ian "All mechanical cockpit" J |
Hi Ian
Lightning is best avoided. But in the event it is not avoidable, my limited experience is that a strike that is near enough to knock out a GPS has no effect on a Tasman vario. Presume this is because of the aerial on the GPS. My guess would be that - If you get hit hard enough to knock out your electronic varios you will probably not be particularly worried about thermalling. Bruce Ian wrote: On 16 Jul, 20:37, Bruce wrote: So why install mechanical varios in a new high tech glide? Convince me. How well do electric ones react to nearby lightning bolts? Apart from that, isn't it an awful lot easier to fit a mechanical vario than it is to fit a complete second electrical system? Ian "All mechanical cockpit" J |
On Jul 16, 4:35*pm, Ian wrote:
On 16 Jul, 20:37, Bruce wrote: So why install mechanical varios in a new high tech glide? Convince me. How well do electric ones react to nearby lightning bolts? Apart from that, isn't it an awful lot easier to fit a mechanical vario than it is to fit a complete second electrical system? Ian "All mechanical cockpit" J I'm totally in the "all electric" camp. Tossed my mechanical 8 years ago, replaced with a nice Ilec electric backup (with audio), and haven't had a problem since. Primary is an SN10. Both agree all the time. And 2 electrical systems are only slightly more work than one, if done at the same time. Given more funds, I would replace the Ilec with something that has electronic TE, so that losing the probe wouldn't fail both varios - my current single point of failure... Mechanical varios belong with barographs - on the shelf behind the club bar. Especially on club ships, where good varios with audio are really needed, yet rare (at least in the US). Cheers, Kirk 66 |
| Thread Tools | |
| Display Modes | |
| Sage Varios-Williams Soaring | Tom Hubbard | Soaring | 0 | April 2nd 07 08:12 PM |
| How about this for computing power in your glider cockpit | Gary Emerson | Soaring | 9 | May 17th 06 09:56 PM |
| What camera for pictures from a glider cockpit? | Eric Greenwell | Soaring | 34 | December 10th 05 07:19 AM |
| Opinions on Varios | Bruce | Soaring | 8 | March 1st 05 04:57 PM |
| Super Varios | John Scott | Soaring | 1 | February 25th 05 03:14 AM |
