Is there a place for Traditional CAS in the 21st century?
Old March 14th 04, 08:32 PM
Tarver Engineering
"Ed Rasimus" wrote in message
On Sun, 14 Mar 2004 10:50:56 -0800, "Tarver Engineering"
I see UAVs under the direct control of the men on the ground as the
replacement for the A-10. Some sort of game boy type interface to
designate
targets would be all the human interface required. In that manner the
tendancy of the A-10 to make blue on blue incursions might be eliminated.
That would take a quantum leap in sensor technology as well as an
incredible level of logistic support. What you suggest would require
some sort of UAV platoon attached to a maneuver element with
pre-packaged UAV rounds, a launch/recovery capability, a cadre of
trained operators, reload munitions, etc. etc. etc. Not a low-tech,
mud-reliable sort of weapon.
I fail to see how it is any different from an A-10, without the operator and
operator support requirements. UAVs are already flying in US airspace using
existing comercially available sensors. My vehicle in atonomous mode could
come to the battle and then go home when exhasted. Such UAVs are already
envisioned as loiterers, where a battle may occur in the future, or along a
transportation link.
Then there is the question of battle-field view. While the guy on the
ground may be able to see the enemy immediately in front of him, he
seldom knows what else is out there and threatening. That takes a
detached, at altitude, observer. Hunkering in a foxhole or a tracked
vehicle buttoned-up, looking at a 12.1 inch LCD display that reports
what the eye in the nose of the UAV happens to be looking at is a
difficult perspective from which to manipulate CAS.
CAS is now done with a JDAM from a B-one at thousands of feet. The only
thing that was holding back the technology was the moral issue of having a
flying machine kill without an operator, but that was answered by CIA years
ago.
You proposal also doesn't address the complexities of airspace
coordination for employment of a CAS system within the mix of
aviation, indirect fire assets and direct fire from supporting or
flanking units. Letting "game-boy" operators fly armed UAVs to deliver
ordinance at the engagement level is not a trivial problem.
Atonomous UAVs are the future, reguardless of the screeching of the fighter
mafia.
And, the "tendency of the A-10 to make blue on blue incursions" is an
unsupported cheap shot. The A-10 (and any other CAS system) has made
few friendly fire mistakes. They happen, but it isn't epidemic.
The A-10's record vs the rotary wing equivalents for blue on blue incidents
is poor. I would rather blame the machine than the inter-service reality in
this forum.
Old March 14th 04, 08:56 PM
Ed Rasimus
On Sun, 14 Mar 2004 12:32:07 -0800, "Tarver Engineering"
designate
OK, I misunderstood your initial post. When you said "direct control
of the men on the ground" I assumed you were suggesting an organic UAV
capability in the maneuver element. What you explain now, is simply a
full-blown tactical system with everything but the pilot-in-the-loop.
At some future time, data processing may make that practical, but
right now the wetware is still the most size/weight effective
solution.
The loiterer doesn't seem a practical model over an ongoing
engagement. Much too MANPAD intensive to be tolerated. Certainly the
current use of UAVs as recce platforms or even very limited (due to
small payload) interdiction systems is working well. CAS, however is
often very critical in terms of "danger close" criteria, run-in
directions, and other factors.
ago.
Some CAS is done from a heavy type at altitude with JDAM, but I think
the questioner's phrase "Traditional CAS" refers to troops-in-contact
and immediate fire support situations which may require a nose-to-nose
look at the enemy. I'll be the first to agree that modern weapons with
stand-off capability and high accuracy make the definitions of what
CAS really is more debatable.
I don't think there is any moral issue involved with or without an
operator. If the targeting is against a military objective, I'm
comfortable.
mafia.
I don't think I was screeching. I agree that there is a bright future
for UAVs with increasing missions. But, I don't go so far as to accept
the sensationalized concept of video game whiz-kids snapped off the
back streets of the inner city to do the job. If you check out the
operators of the current crop of UAVs, you'll find a lot of active and
former fighter types. The hands and the mind still function pretty
well long after the body quits tolerating the high-G environment.
this forum.
Sorry, I won't accept that assertion. The A-10s record is very good
with regard to CAS. And, there is nothing inherent about "the
machine"--it is as vulnerable to fratricide mistakes as any other
system. Taking the pilot out of the loop is the real issue and there's
no evidence to indicate that the potential for fratricide goes down.
I'd contend that taking the man out of the system will increase the
probability of error.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
Old March 14th 04, 09:44 PM
Tarver Engineering
designate
eliminated.
and
using
could
a
solution.
The ground operator would have the capability of designating targets and the
ability to change the level of agression of the autonomous vehicle. I want
to get pilots out of the mud, not send them into harm's way. There is a
similar autonomous vehicle envisioned for the F-35, but it can wait until
the F-22 is either produced, or cancelled.
The loiter vehicle is moving forward first, as it is funded for paper
investigation of the idea. That way it stays out of the obvious reality
check issues for "silver bullet" type assets.
a
years
ago.
A 2000 pound bomb dropped accurate does the same job from 15,000 feet as it
does from 200 feet; perhaps even better, as the man on the ground has better
control of the target's coordinates. That is not always true, as my brother
has a story of his company commander calling a strike on his own company's
position, but that is another issue. The CO got his bronze star and never
went out again. (ie heroin addict)
comfortable.
How about a wedding? (Afghanistan)
fighter
mafia.
Which is why we are discussing autonomous vehicles for filling the role of
"traditional CAS". I have the impression that the Infantry is as pleased to
stay out of that type of situation as a fighter pilot is to have BVR
weapons.
incidents
in
this forum.
with regard to CAS.
Not as good as the Army's own rotary wings.
system.
That depends on how well the operator can see the battle and follow
instructions.
The Army's own assets are statistically less likely to blue on blue.
My man is on the ground, saving his own life.
Do you think Cleland was fragged?
Old March 14th 04, 10:36 PM
Ed Rasimus
On Sun, 14 Mar 2004 13:44:13 -0800, "Tarver Engineering"
No, Cleland was a victim of his own clumsiness. He dropped the grenade
out of his own hand. That story is pretty well known.
Ed Rasimus
ISBN #1-58834-103-8
Old March 14th 04, 10:57 PM
Bob McKellar
Ed Rasimus
ISBN #1-58834-103-8
Actually, recently the story was changed due to another soldier coming
forth and admitting that it was his grenade, and that he had straightened
the pin, having been told that was the warrior like thing to do.
The story was well covered here in Georgia.
I guess I could find a link if you wish.
Bob McKellar, former Cleland constituent
Old March 14th 04, 11:00 PM
Peter Kemp
On Sun, 14 Mar 2004 18:42:08 GMT, "Thomas Schoene"
In general, however, the Navy is migrating to no gun-based CIWS at all.
LPD-17 has just RAM and 30mm Mk 46 turrets for small-baot defense. Unless
things change from what was shown at concept design, DD(X) will have 40mm
guns for close-in defnse, but not for anti-missile duties. If they do
change, I think the most likely swap will be to 30mm MK 46 turrets in place
of the 40mm, but still with no missile-defense role. For anti-missile
defense, it will rely on ESSM.
What's the 40mm proposed for the DD(X)? I had assumed from the few
concept drawings they'd be using the Mk 46 turrets for commonality to
start with.
Peter Kemp
Life is short - drink faster
Old March 14th 04, 11:11 PM
Kevin Brooks
designate
eliminated.
and
using
could
a
solution.
Actually, the ground forces are well on their way to having UAV's as an
organic element, even down to the platoon level. The USMC has already
initiated production of the small Dragoneye, which is essentially about a
two man load--the operator uses a laptop to control the aircraft and observe
the intel feed (and no, it is unlikely to be any kind of weapons carrier).
The Army has established a squadron/battalion sized ISR element to serve in
its new Stryker Brigade Combat Teams, and I believe the plan is to have them
operate their own small UAV's in the not-too-distant future.
snip
The objective right now for the ground forces is to get useful UAV's into
operation at the lowest possible echelons. From what I have seen regarding
Dragoneye, it is a pretty simple system to operate. I would imagine the
Army's new focus on rotary UAV's will also emphasize ease of operation (I
doubt the Army wants to commit rated pilots to flying its UAV's as the USAF
has been doing); trying to attach additional qualified pilots to each and
every meneuver brigade/battalion, etc., to operate their organic UAV's would
impinge upon the pool of pilots available to fly the manned aircraft in the
AVN BDE's.
incidents
in
this forum.
You are correct there. IIRC there were two A-10 frat incidents during ODS
(one engagement of a British Warrior AFV and one of a USMC LAV); on the
other hand, there was also a rather nasty AH-64 frat incident (hit a Bradley
IIRC). So there is no real preponderance of evidence to support the idea
that the A-10 was "poor" in comparison to the rotary assets in this
regard--one incident versus two incidents is statistically meaningless.
Yep. It will be quite a while before the crunchies would be comfortable with
the idea of autonomous UCAV's flying the CAS missions, especially those TIC
missions you mentioned earlier.
Brooks
Ed Rasimus
ISBN #1-58834-103-8
Old March 14th 04, 11:13 PM
Kevin Brooks
Actually, Ed, if you do a Google on it there is some evidence to support
that may not have been the case. Cleland thought that was what must have
happened, but another man who was on the ground with him now claims it was
another individual who dropped the grenade. Nobody can no for sure, and it
really does not matter in the end.
Brooks
Ed Rasimus
ISBN #1-58834-103-8
Old March 14th 04, 11:18 PM
Thomas Schoene
all. LPD-17 has just RAM and 30mm Mk 46 turrets for small-baot
defense. Unless things change from what was shown at concept
design, DD(X) will have 40mm guns for close-in defnse, but not for
anti-missile duties. If they do change, I think the most likely
swap will be to 30mm MK 46 turrets in place of the 40mm, but still
with no missile-defense role. For anti-missile defense, it will
rely on ESSM.
start with.
Northrop Grumman bid two Bofors 40mm Mk 3. (BIW proposed three 30mm Mk 46)
In the latest pictures they're still there, sitting on top of the helo
hangar in low-RCS enclosures.
http://raytheon.com/businesses/rids/gallery/300_ddx.jpg
(very big picture)
But I will not be at all surprised to see them replaced by 30mm.
Tom Schoene Replace "invalid" with "net" to e-mail
"Our country, right or wrong. When right, to be kept right, when
wrong to be put right." - Senator Carl Schurz, 1872
Old March 15th 04, 12:45 AM
Peter Kemp
On Sun, 14 Mar 2004 23:18:29 GMT, "Thomas Schoene"
rely on ESSM.
start with.
Thanks for the info and the pic Tom, much appreciated.
Peter Kemp
Funky place to store your fuel? BllFs6 Home Built 5 August 23rd 04 01:27 AM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 1 October 17th 03 02:04 AM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 0 October 17th 03 01:25 AM
Grumman 2 place Wanted Jerry Aviation Marketplace 1 September 13th 03 11:59 PM
4 place portable intercom For Sale Snowbird Aviation Marketplace 0 August 26th 03 12:41 AM
