WWII Fighter Bombers
Old March 21st 04, 01:41 PM
Peter Stickney
"M. H. Greaves" writes:
I read a book recently about a fighter group who flew with one under wing
tank, and a bomb under the other, with P51's, the drag must have been
hellish!
The U.S. used the P47, and the P38's to great advantake for ground attack,
the RAF used the typhoon, the tempest, the beaufort, these are the most
prominent ones i can remember.
Not a whole lot of Beuforts used as Firgter-Bombers or Light Bombers.
They were tasked as Torpedo Bombers, for antishipping work. (As were,
in fact, most Beaufighters) By mid '44, the usual RAF Light Bomber was
the Mosquito FB.VI.
The P51's mainly carried two under wing tanks, which they used first, them
when the time came to dog fight, they would let them go; they had a big fuel
tank in behind the pilot to fall back on.
A little bit oof there. For P-51s with the aft fuel tank, the
sequence was to burn the fuel in the aft tank first, then the drops.
A full aft tank moved the Center of Gravity to the extreme back end of
its allowable range, and caused a tendency to overshoot in pitch
(pulling G, for instance) that wasn't acceptable in combat. Return
fuel would have been in the normal wing tanks.
Any fighter bomber that had say small bombs would execute their primary
objectives first,i.e. drop the bombs first because to dog fight with a bomb
under neath could be too risky, the drag, extra weight, and the damger of
the bombs being hit while still attached., they would not be required to go
any great distance with the bombs; this was the medium, and heavy bombers
task, if the fighters carried a bomb or two they would be used to soften a
target with aswell as others straffing, and perhaps those doing the
straffing would cover thos carrying the bombs.
It perhaps should also be pointed out that the bombs were the
fighter-bomber's most effective weapons, so naturally they'd be used
first. Bombs are pretty inseneitive to damage from things like
bullets & fragments. That's why they require special fuzes and
booster charges (Which are in the fuze wells in the center of the
bomb) to set them off. The danger of a hung bomb comes from two
sources - if the arming wire's been pulled, allowing the vanes onthe
fuze to turn, moving the firing mechanism into alignment, then it can
go off with a sufficient impact in the right direction. If the rack
didn't release all the way, or if one lug has released and the other
hasn't then the bomb could fall of its own accord at just about any
time, and if it doesn't release cleanly can casue severe damage to teh
airframe. USAAF firghter-bombers, (And RAF Mustangs used as
fighter-bombers) were quite wide-ranging. The first RAF fighter over
Germany were Mustang Is (Allison engines, and no fuselage tank) flying
Armed Recce missions past Kiel in early 1942. (Brit built fighters
just never had much in the way of range, carrying bombs or not).
Ta answer the previous poster's question (And this is why Top Posting
is abhorrent - it breaks up the flow of the conversation):
It depends on the situation. If the fighter-bombers are being
escorted, and the escorts can handle teh attackers, then they'd
probably keep the bombs and press on to the target. If the attacking
fighters don't have enough of a performance advantage to be able to
catch the fighter bombers in good time - tail chases are slow - then
it would be a jusdgement call. The drag of bombs was about the same
as that of an equivalaently sized drop tank.
"zxcv" wrote in message
Would a fighter plane (say a P-51 or P-40 for example) that was on mission
to drop some tactgical bombs and encountered some any fighters generally
drop its bombs before engaging the enemy? or just try to run away? or
fight
with them still hanging on (sounds pretty dangerous to me with the extra
weight and the BOMBs hanging under their wings)?
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old March 21st 04, 06:01 PM
M. H. Greaves
Okay Peter, thanks for setting me straight on a point or two there! it seems
on the top posting/bottom posting that i'm stuck between a rock and a hard
place: if i top post people complain, if i bottom post people complain, i'm
not getting at you, its just that i was in another n/g that had a rather
large debate cum argument online about people that top or bottom post;
nowadays i dont bother either way, if it annoys people that much whether i
top post or bottom post then thats just too bad, i'm sorry and all that but
who really cares!??? i dont, i just scroll down to where the latest comments
are!
"Peter Stickney" wrote in message
wing
hellish!
attack,
the Mosquito FB.VI.
them
fuel
bomb
of
go
bombers
a
mission
generally
fight
extra
Pete Stickney
Old March 21st 04, 07:05 PM
Keith Willshaw
"M. H. Greaves" wrote in message
seems
i'm
but
comments
are!
There are several very good reason for bottom posting.
Firstly and most importantly replies can read in the
context of the original post.
Secondly in a post to which there are several responses its
much easier to keep track of who said what and when.
Keith
Old March 21st 04, 08:28 PM
M. H. Greaves
yes, thats true, i appreciate that, and like i say i wasnt getting at you
mate! just expressing an opinion thats all
regards, Mark {:-)}
"Keith Willshaw" wrote in message
seems
hard
i'm
i
but
comments
are!
Keith
Old March 22nd 04, 03:24 AM
"Keith Willshaw" wrote:
-cut-
Keith
But only if people would keep the quoted amount within reason...I
hate it when I select a msg in an interesting thread, scroll down
to see what it's about then scroll through innumerable lines to
see the new stuff then again and again...how come people can't
learn to remove all that superfluous text? Why quote the old
stuff over and over? I think there's a conspiracy afoot to
change me over to a top-poster!...
-Gord.
Old March 22nd 04, 03:38 AM
Mortimer Schnerd, RN
I generally hate top posting if there's more than a paragraph quoted. Frankly,
I hate bottom posting under the same conditions. I do believe that bottom
posting under a very sparse quotation makes for an easier flow of ideas, as in
who said what. There's no need to requote an entire conversation in order to
give context.
http://www.mortimerschnerd.com.
Old March 22nd 04, 07:40 AM
Keith Willshaw
"Gord Beaman" wrote in message
snip
Agreed
Keith
Old March 22nd 04, 10:32 AM
Cub Driver
On Mon, 22 Mar 2004 03:24:15 GMT, "Gord Beaman" )
Amen!
all the best -- Dan Ford
email: (requires authentication)
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old March 22nd 04, 11:54 AM
M. H. Greaves
ya never know!!???
-cut-
Keith
-Gord.
Old March 24th 04, 11:16 PM
Peter Stickney
he dropped the wing tank firstm then the bomb!
"Cub Driver" wrote in message
hellish!
Did the pilot pickle them off at the same time?
I rather doubt it. I had occasion to pull out the F-51's -1, and
there isn't any provision to drop from each station individually.
Both stations go at the same time.
Pete Stickney
Canadian fighter squadrons during WWII Ed Majden Military Aviation 10 March 8th 04 05:34 AM
German forward swept wing WWII fighter projects. Charles Gray Military Aviation 4 January 11th 04 01:49 PM
Guns on a WWII fighter... Kurt Jeffery Military Aviation 15 December 14th 03 11:48 PM
Kadena honors legendary WWII fighter ace Otis Willie Military Aviation 0 November 23rd 03 02:58 AM
V engined bombers (was: #1 Piston Fighter was British) John Keeney Military Aviation 0 July 1st 03 06:06 AM
